12-09-2021, 10:21 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | LM-K500UM T.mobile unlocked problem [Solved] Work ID: 0000000000000000 Checking data...OK Platform: LG MTK Selected port: COM44 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Phone found at port COM44 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Platform: mt6765 Code name: mdh30xlm Android version: 10 SW version: LMK500UMT3AT-01-V10r-310-260-SEP-02-2021- ARB00+0 LAF Version: 1.1 Product ID: WI22S201221001988 IMEI: 356240-97-248598-3 Target operator: LAO Hardware: rev_10 Battery level: 54% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 356240-97-248598-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bP4j0brQh9 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM44 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Performed by 3.1.5.03 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001F10B76 Checking data...OK Platform: LG MTK Selected port: COM44 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Phone found at port COM44 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Platform: mt6765 Code name: mdh30xlm Android version: 10 SW version: LMK500UMT3AT-01-V10r-310-260-SEP-02-2021- ARB00+0 LAF Version: 1.1 Product ID: WI22S201221001988 IMEI: 356240-97-248598-3 Target operator: LAO Hardware: rev_10 Battery level: 54% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 356240-97-248598-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bP4j0brQh9 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM44 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Performed by 3.1.5.03 Software version. |
12-09-2021, 10:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please download and install this driver https://octoplusbox.com/files/driver...er-1.2.6.0.exe and repeat Unlock operation again via ADB method. |
12-09-2021, 11:18 | #3 (permalink) | |
Member: 153893 Status: Offline Thanks Meter: 266 | Quote:
Card S/N : 000101657E -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001F121FF Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: K500UM Please, select Unlock Method! Selected Unlock via ADB Initializing ADB...OK Waiting for phone...OK Model ID: LM-K500UM Phone firmware version: LMK500AT-00-V10r-LAO-COM-SEP-02- 2021-ARB00+0 Baseband version: MOLY.LR12A.R3.TC01.DH.SP.V1.P43, 2021/09/02 20:23 Android version: 10 Target operator: TMO Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bP4j0brQh9 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Sending loader... Reading info... IMEI: 356240972485983 Reading SIMLOCK... Obtained wrong response! Failed! Performed by 3.1.5.03 Software version. | |
12-09-2021, 11:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, download and install latest software version 3.1.6 then perform Unlock operation via Wipe security method and post here result. |
12-09-2021, 15:20 | #5 (permalink) | |
Selected USB connection type Work ID: 0000000001F18018 Checking data...OK Platform: LG MTK Selected port: COM17 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Phone found at port COM17 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Platform: mt6765 Code name: mdh30xlm Android version: 10 SW version: LMK500UMT3AT-01-V10r-310-260-SEP-02-2021- ARB00+0 LAF Version: 1.1 Product ID: WI22S201221001988 IMEI: 356240-97-248598-3 Target operator: LAO Hardware: rev_10 Battery level: 62% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 356240-97-248598-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bP4j0brQh9 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM17 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Performed by 3.1.6 Software version. | |
12-09-2021, 15:46 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please contact us to Skype, we will check remotely, where can be the problem in more details. Quote:
12-09-2021, 17:06 | #7 (permalink) | |
Selected USB connection type Platform: LG MTK Selected port: COM16 Selected baudrate: 921600 Selected model: K500UM Connecting to phone... Phone found at port COM17 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Platform: mt6765 Code name: mdh30xlm Android version: 10 SW version: LMK500UMT3AT-01-V10r-310-260-SEP-02-2021- ARB00+0 LAF Version: 1.1 Product ID: WI22S201221001988 IMEI: 356240-97-248598-3 Target operator: LAO Hardware: rev_10 Battery level: 85% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 356240-97-248598-3 MEID: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.6 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001F1A8D6 Checking data...OK Platform: LG MTK Selected port: COM16 Selected baudrate: 921600 Selected model: K500UM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Phone found at port COM17 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Platform: mt6765 Code name: mdh30xlm Android version: 10 SW version: LMK500UMT3AT-01-V10r-310-260-SEP-02-2021- ARB00+0 LAF Version: 1.1 Product ID: WI22S201221001988 IMEI: 356240-97-248598-3 Target operator: LAO Hardware: rev_10 Battery level: 85% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 356240-97-248598-3 MEID: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bP4j0brQh9 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM17 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM14 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC flash chip: .15010047.58364241.4209A634.066FA75D eMMC flash chip: Unknown: GX6BAB Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "K500UM_356240972485983_09-12-2021_08- 00-14.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... Phone successfully unlocked! Performed by 3.1.6 Software version. | |
The Following 2 Users Say Thank You to godwin For This Useful Post: |
