02-24-2022, 12:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | LM-K520EMW Unlock Question [Solved] Code: Welcome to Octoplus/Octopus Box LG Software version 3.1.7 Card S/N : 010002A782 -------------------------------------------------------------------------------- Connecting to server 0...Failed! Coud not connect to the server! Connecting to server 1...Failed! Coud not connect to the server! Connecting to server 2...OK Username: maisondegsm Authorizing...Failed! Login error: Wrong password! -------------------------------------------------------------------------------- Connecting to server 0...Failed! Coud not connect to the server! Connecting to server 1...Failed! Coud not connect to the server! Connecting to server 2...OK Username: maisondegsm Authorizing...Failed! Login error: Wrong password! -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000024A8D54 Checking data...OK Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Mode: Normal Switching to Download mode...Canceled! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Connecting to server 0...Failed! Coud not connect to the server! Connecting to server 1...Failed! Coud not connect to the server! Connecting to server 2...OK Username: BEN00000000000 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000024A8EC4 Checking data...OK Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM48 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 10% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...Failed!OK Connecting to server 1...Failed!OK Connecting to server 2...OK Octopus smart card is present. Checking smart card...OK Username: BEN0000000000 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM48 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM45 |
02-24-2022, 13:47 | #3 (permalink) | |
Member: 411207 Status: Offline Thanks Meter: 164 | Quote:
some problem.i reinstal driver and no other lg software open in procces to unlock this phone Code: -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000024AA3B9 Checking data...OK Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Mode: Normal Switching to Download mode... Phone found at port COM48 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 21% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: BE000000000 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM48 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM45 | |
02-25-2022, 10:01 | #6 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello Unfortunately, currently we don't have stable solution for your issue with using downgraded firmware but you can try perform it. Downgrade phone's firmware may lead damage the phone. |
The Following User Says Thank You to Octopus support For This Useful Post: |
02-25-2022, 17:23 | #7 (permalink) |
Member: 411207 Status: Offline Thanks Meter: 164 | Solved hi the only solution is downgrade phone firmware with correct file. i think with first firmware installed in phone with patch janvir 2022 firmware closed somtinhg like mediatek port Code: Welcome to Octoplus/Octopus Box LG Software version 3.1.7 Card S/N : 010002A782 -------------------------------------------------------------------------------- Selected USB connection type Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Mode: Normal Switching to Download mode... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E356B Checking data...OK Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Opening "K520EMW20d_00_0110.kdz"...OK Firmware version: K52020d Firmware model: LM-K520 Firmware type: 0100 Prepairing firmware... Selecting firmware partitions...Canceled! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E35EC Checking data...OK Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E35FF Checking data...OK Platform: LG MTK Selected port: COM55 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Platform: LG MTK Selected port: COM45 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E364D Checking data...OK Platform: LG MTK Selected port: COM45 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Opening "K520EMW10b_00_1201.kdz"...OK Firmware version: K52010i Firmware model: LM-K520 Firmware type: 0100 Prepairing firmware... Selecting firmware partitions...OK Selected default partitions!OK Sending signature...OK Setting options...OK Reading partitions...OK Do you want to format User Data? Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/82 preloader.img_0...OK Writing 2/82 patched_pgpt_0...OK Writing 3/82 efuse.img_25600...OK Writing 5/82 md1img.img_753664...OK Writing 6/82 spmfw.img_950272...OK Writing 7/82 scp.img_952320...OK Writing 8/82 sspm.img_954368...OK Writing 9/82 lk.img_956416...OK Writing 10/82 tee.img_960512...OK Writing 11/82 logo.bin_983040...OK Writing 12/82 dtbo.img_999424...OK Writing 13/82 vbmeta_COM4_EU.img_1015808...OK Writing 14/82 boot.img_1064960...OK Writing 15/82 laf.img_1146880...OK Writing 16/82 md1img.img_1228800...OK Writing 17/82 spmfw.img_1425408...OK Writing 18/82 scp.img_1427456...OK Writing 19/82 sspm.img_1429504...OK Writing 20/82 lk.img_1431552...OK Writing 21/82 tee.img_1435648...OK Writing 22/82 logo.bin_1458176...OK Writing 23/82 dtbo.img_1474560...OK Writing 24/82 vbmeta_COM4_EU.img_1490944...OK Writing 25/82 boot.img_1540096...OK Writing 26/82 laf.img_1622016...OK Writing 27/82 rct.img_1705984...OK Writing 28/82 super_8.img_2113544...OK Writing 29/82 super_2048.img_2115584...OK Writing 30/82 super_265440.img_2378976...OK Writing 31/82 super_789728.img_2903264...OK Writing 32/82 super_1314016.img_3427552...OK Writing 33/82 super_1838304.img_3951840...OK Writing 34/82 super_2362592.img_4476128...OK Writing 35/82 super_2362592.img_5000416...OK Writing 36/82 super_2362592.img_5524704...OK Writing 37/82 super_2362592.img_6048992...OK Writing 38/82 super_2362592.img_6573280...OK Writing 39/82 super_4720752.img_6834288...OK Writing 40/82 super_4982896.img_7096432...OK Writing 41/82 super_5063288.img_7176824...OK Writing 42/82 super_5144592.img_7258128...OK Writing 43/82 super_5146624.img_7260160...OK Writing 44/82 super_5409664.img_7523200...OK Writing 45/82 super_5933952.img_8047488...OK Writing 46/82 super_6458240.img_8571776...OK Writing 47/82 super_6982528.img_9096064...OK Writing 48/82 super_7506816.img_9620352...OK Writing 49/82 super_7506816.img_10144640... LAF Error: 80000202.Failed! LAF Error: 80000202. Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E373B Checking data...OK Platform: LG MTK Selected port: COM45 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E374B Checking data...OK Platform: LG MTK Selected port: COM45 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMK520EMWAT-64-V20d-EEA-XX-JAN-10-2022+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Opening "K520EMW10d_00_1027.kdz"...OK Firmware version: K52010d Firmware model: LM-K520 Firmware type: 0100 Prepairing firmware... Selecting firmware partitions...OK Selected default partitions!OK Sending signature...OK Setting options...OK Reading partitions...OK Do you want to format User Data? Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/81 preloader.img_0...OK Writing 2/81 patched_pgpt_0...OK Writing 3/81 efuse.img_25600...OK Writing 5/81 md1img.img_753664...OK Writing 6/81 spmfw.img_950272...OK Writing 7/81 scp.img_952320...OK Writing 8/81 sspm.img_954368...OK Writing 9/81 lk.img_956416...OK Writing 10/81 tee.img_960512...OK Writing 11/81 logo.bin_983040...OK Writing 12/81 dtbo.img_999424...OK Writing 13/81 vbmeta_COM1_EU.img_1015808...OK Writing 14/81 boot.img_1064960...OK Writing 15/81 laf.img_1146880...OK Writing 16/81 md1img.img_1228800...OK Writing 17/81 spmfw.img_1425408...OK Writing 18/81 scp.img_1427456...OK Writing 19/81 sspm.img_1429504...OK Writing 20/81 lk.img_1431552...OK Writing 21/81 tee.img_1435648...OK Writing 22/81 logo.bin_1458176...OK Writing 23/81 dtbo.img_1474560...OK Writing 24/81 vbmeta_COM1_EU.img_1490944...OK Writing 25/81 boot.img_1540096...OK Writing 26/81 laf.img_1622016...OK Writing 27/81 rct.img_1705984...OK Writing 28/81 super_8.img_2113544...OK Writing 29/81 super_2048.img_2115584...OK Writing 30/81 super_265440.img_2378976...OK Writing 31/81 super_789728.img_2903264...OK Writing 32/81 super_1314016.img_3427552...OK Writing 33/81 super_1838304.img_3951840...OK Writing 34/81 super_2362592.img_4476128...OK Writing 35/81 super_2362592.img_5000416...OK Writing 36/81 super_2362592.img_5524704...OK Writing 37/81 super_2362592.img_6048992...OK Writing 38/81 super_2362592.img_6573280...OK Writing 39/81 super_4720752.img_6834288...OK Writing 40/81 super_4982896.img_7096432...OK Writing 41/81 super_5054472.img_7168008...OK Writing 42/81 super_5135640.img_7249176...OK Writing 43/81 super_5136384.img_7249920...OK Writing 44/81 super_5399424.img_7512960...OK Writing 45/81 super_5923712.img_8037248...OK Writing 46/81 super_6448000.img_8561536...OK Writing 47/81 super_6972288.img_9085824...OK Writing 48/81 super_7496576.img_9610112...OK Writing 49/81 super_7496576.img_10134400...OK Writing 50/81 super_8544408.img_10657944...OK Writing 51/81 super_8748056.img_10861592...OK Writing 52/81 super_8806120.img_10919656...OK Writing 53/81 super_8806400.img_10919936...OK Writing 54/81 super_9068632.img_11182168...OK Writing 55/81 super_9121104.img_11234640...OK Writing 56/81 super_9126320.img_11239856...OK Writing 57/81 super_9127936.img_11241472...OK Writing 58/81 super_9390304.img_11503840...OK Writing 59/81 super_9914592.img_12028128...OK Writing 60/81 super_9914920.img_12028456...OK Writing 61/81 super_9998640.img_12112176...OK Writing 62/81 super_10012768.img_12126304...OK Writing 63/81 OP_COM1_EU.img_25935872...OK Writing 64/81 OP_COM1_EU.img_26460160...OK Writing 65/81 OP_COM1_EU.img_26984448...OK Writing 66/81 userdata_0.img_32243712...OK Writing 67/81 userdata_5656.img_32249368...OK Writing 68/81 userdata_262144.img_32505856...OK Writing 69/81 userdata_263688.img_32507400...OK Writing 70/81 userdata_786432.img_33030144...OK Writing 71/81 userdata_787976.img_33031688...OK Writing 72/81 userdata_1310720.img_33554432...OK Writing 73/81 userdata_1312264.img_33555976...OK Writing 74/81 userdata_1835008.img_34078720...OK Writing 75/81 userdata_1836552.img_34080264...OK Writing 76/81 userdata_2359296.img_34603008...OK Writing 77/81 userdata_2360840.img_34604552...OK Writing 78/81 userdata_2883584.img_35127296...OK Writing 79/81 userdata_2887696.img_35131408...OK Writing 80/81 userdata_6029312.img_38273024...OK Finalizing...OK Waiting for phone... Factory reset...OK Rebooting phone... Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: BEN000000 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000016E3A3D Checking data...OK Platform: LG MTK Selected port: COM45 Selected baudrate: 921600 Selected model: K520EMW Connecting to phone... Mode: Normal Switching to Download mode... Phone found at port COM51 Mode: Emergency Initializing flash...OK Model ID: LM-K520EMW Platform: mt6765 Code name: meh35lm Android version: 10 SW version: LMK520EMWAT-64-V10d-EEA-XX-OCT-27-2020+0 LAF Version: 1.1 Product ID: 09JADD13PYE1009GS IMEI: 356633-11-053829-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 356633-11-053829-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Connecting to phone... Initializing flash...OK Reading security area... Backup saved to "K520EMW_356633110538293_25-02-2022_17- 06-28.EEP" Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: BEN000000000 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Connecting to phone... Initializing flash...OK Writing security area...OK Connecting to phone... Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Connecting to phone... Initializing flash...OK Removing write protection...OK Connecting to phone... Initializing flash...OK Reading partitions...OK Erasing part 1...OK Connecting to phone... Initializing flash...OK Erasing part 2...OK Connecting to phone... Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Connecting to phone... Initializing flash...OK Restore write protection...OK Connecting to phone... Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.1.7 Software version. |
The Following User Says Thank You to blaw For This Useful Post: |
