12-31-2021, 14:01 | #1 (permalink) |
Junior Member Join Date: Jan 2017 Location: senegal
Member: 2678914 Status: Offline Sonork: DOU Thanks Meter: 2 | LM-Q730MM Repair IMEI Question [Answered] Card S/N : 00000084BD -------------------------------------------------------------------------------- Connecting to server 0...OK Username: ndongoafia7754 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000020D3DEC Checking data...OK Platform: LG MTK Selected port: COM50 Selected baudrate: 921600 Selected model: Q730MM Connecting to phone... Phone found at port COM69 Mode: Emergency Initializing flash...OK Model ID: LM-Q730MM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730MMAT-02-V10r-310-160-FEB-18-2021-ARB00 +0 LAF Version: 1.1 Product ID: VS03S200721002580 IMEI: 354525-11-431341-2 Target operator: LAO Hardware: rev_11 Battery level: 87% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354525-11-431341-2 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ndongoafia7754 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM69 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM6 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .13014E47.314A3950.38100705.2BD667C9 eMMC flash chip: Unknown: G1J9P8 Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q730MM_354525114313412_31-12-2021_12- 41-04.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: ndongoafia7754 Authorizing...OK Checking balance...OK Your balance: 0 credits. |
01-03-2022, 08:56 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. We added your one more attempt. Please, download and install latest test Software v. 3.1.6.01 from Support Area (Path:/SOFTWARE/Octoplus LG/TEST SOFTWARE/install_octoplus_octopus_LG_3.1.6.01.exe) Then repeat operation once again and post here results. We will check it. Note: Read attentive Software instructions. Quote:
02-17-2022, 00:32 | #3 (permalink) |
Major Poster Join Date: May 2014 Location: Tegucigalpa
Member: 2182084 Status: Offline Thanks Meter: 4 | for me the OK button doesnt activate then the pop up disappeared is there a way to get another go at it ? ---------------------------------------------------------------------- Log file "C:\Program Files\Octoplus\Octoplus_LG\LOG\15-02-2022_19-10-23.log" created. 15/02/2022 7:10:29 PM > Searching for server... 15/02/2022 7:10:31 PM > Trying to ping server...0 15/02/2022 7:10:34 PM > Trying to ping server...115/02/2022 7:10:34 PM > ok 15/02/2022 7:10:34 PM > Trying connect to server... 15/02/2022 7:10:35 PM > Searching installed cards... 15/02/2022 7:10:35 PM > Found card with s/n: 00032096 15/02/2022 7:10:35 PM > Server check... 15/02/2022 7:10:36 PM > Server Check succesfull! 15/02/2022 7:10:36 PM > Server Check succesfull! 15/02/2022 7:10:37 PM > Welcome to Octoplus/Octopus Box LG Software version 3.1.7 15/02/2022 7:10:37 PM > Card S/N : 0000032096 15/02/2022 7:10:49 PM > INI FUpdateInfo Done! 15/02/2022 7:10:49 PM > INI FShowUpdateInfo start 15/02/2022 7:10:49 PM > INI FShowInfo start 15/02/2022 7:11:06 PM > -------------------------------------------------------------------------------- 15/02/2022 7:11:06 PM > Selected USB connection type 15/02/2022 7:11:07 PM > Transport: Connected 15/02/2022 7:11:10 PM > Authorized. 15/02/2022 7:11:13 PM > Work ID: 00000000024069A7 15/02/2022 7:11:14 PM > Checking data...15/02/2022 7:11:15 PM > OK 15/02/2022 7:11:15 PM > Platform: LG MTK 15/02/2022 7:11:15 PM > Selected port: COM117 15/02/2022 7:11:15 PM > Selected baudrate: 921600 15/02/2022 7:11:15 PM > Selected model: Q730MM 15/02/2022 7:11:15 PM > Connecting to phone... 15/02/2022 7:11:16 PM > Phone found at port COM12 15/02/2022 7:11:16 PM > Mode: Emergency 15/02/2022 7:11:16 PM > Initializing flash...15/02/2022 7:11:18 PM > OK 15/02/2022 7:11:19 PM > Model ID: LM-Q730MM 15/02/2022 7:11:19 PM > Platform: mt6765 15/02/2022 7:11:19 PM > Code name: mdh50lm 15/02/2022 7:11:19 PM > Android version: 10 15/02/2022 7:11:19 PM > SW version: LMQ730MMAT-00-V10x-LAO-COM-OCT-01-2021-ARB00+1 15/02/2022 7:11:19 PM > LAF Version: 1.1 15/02/2022 7:11:19 PM > Product ID: VS01S210122001306 15/02/2022 7:11:19 PM > IMEI: 350305-26-000000-1 15/02/2022 7:11:19 PM > Target operator: LAO 15/02/2022 7:11:19 PM > Hardware: rev_11 15/02/2022 7:11:19 PM > Battery level: 1% 15/02/2022 7:11:19 PM > Reading partitions...15/02/2022 7:11:19 PM > OK 15/02/2022 7:11:19 PM > LAF Error: 80000119. 15/02/2022 7:11:20 PM > Checking security...15/02/2022 7:11:20 PM > OK 15/02/2022 7:11:21 PM > Reading is Blocked! 15/02/2022 7:11:21 PM > -------------------------------------------------------------------------------- 15/02/2022 7:11:21 PM > IMEI: 350305-26-000000-1 15/02/2022 7:11:21 PM > Bluetooth address: Unknown 15/02/2022 7:11:21 PM > Wi-Fi MAC address: Unknown 15/02/2022 7:11:21 PM > -------------------------------------------------------------------------------- 15/02/2022 7:11:21 PM > Checking operation... 15/02/2022 7:11:23 PM > Execute : 0x00A7 15/02/2022 7:11:23 PM > Writing cmd... 15/02/2022 7:11:23 PM > reading cmd... 15/02/2022 7:11:23 PM > Read: EXEC... 15/02/2022 7:11:23 PM > Trying second method... 15/02/2022 7:11:23 PM > Checking Resource File... 15/02/2022 7:11:23 PM > Step 1... 15/02/2022 7:11:30 PM > Check FTP file List 15/02/2022 7:11:31 PM > FTP file List is obtained! 15/02/2022 7:11:31 PM > Step 2... 15/02/2022 7:11:36 PM > Check FTP file List 15/02/2022 7:11:37 PM > FTP file List is obtained! 15/02/2022 7:11:39 PM > Please, disconnect cable, then press "Ok" button 15/02/2022 7:11:48 PM > Connecting to server 0...15/02/2022 7:11:50 PM > Failed!15/02/2022 7:11:50 PM > OK 15/02/2022 7:11:50 PM > Connecting to server 1...15/02/2022 7:11:51 PM > OK 15/02/2022 7:11:51 PM > Octopus smart card is present. 15/02/2022 7:11:51 PM > Checking smart card...15/02/2022 7:12:01 PM > OK 15/02/2022 7:12:01 PM > Username: faramisimo 15/02/2022 7:12:01 PM > Authorizing...15/02/2022 7:12:09 PM > OK 15/02/2022 7:12:09 PM > Checking balance...15/02/2022 7:12:14 PM > OK 15/02/2022 7:12:14 PM > Checking operation...15/02/2022 7:12:19 PM > OK 15/02/2022 7:12:19 PM > Sending device information...15/02/2022 7:12:22 PM > OK 15/02/2022 7:12:22 PM > Get credits, needed for current operation...15/02/2022 7:12:24 PM > OK 15/02/2022 7:12:24 PM > Your balance: 100 credits. 15/02/2022 7:12:24 PM > To perform "Repair IMEI" operation you need to have 100 credits. 15/02/2022 7:12:55 PM > Please, connect powered OFF phone with USB cable. 15/02/2022 7:13:01 PM > Found port COM12 15/02/2022 7:13:02 PM > Detecting Chip Version... 15/02/2022 7:13:02 PM > Platform: MT6765: 0766.0000 15/02/2022 7:13:02 PM > HW version: 8A00.CA00.0000.0000 15/02/2022 7:13:02 PM > Connecting... 15/02/2022 7:13:02 PM > Target config: 0005 15/02/2022 7:13:02 PM > Brom Version: FF 15/02/2022 7:13:02 PM > BootLoader Version: 03 15/02/2022 7:13:02 PM > Sending auth... 15/02/2022 7:13:02 PM > Prepairing loader... 15/02/2022 7:13:02 PM > Sending loader... 15/02/2022 7:13:02 PM > Download Agent is not compatible! 15/02/2022 7:13:04 PM > Found port COM38 15/02/2022 7:13:04 PM > Detecting Chip Version... 15/02/2022 7:13:04 PM > Platform: MT6765: 0766.0000 15/02/2022 7:13:04 PM > HW version: 8A00.CA00.0000.0000 15/02/2022 7:13:04 PM > Connecting... 15/02/2022 7:13:04 PM > Target config: 00E5 15/02/2022 7:13:04 PM > Brom Version: 05 15/02/2022 7:13:05 PM > BootLoader Version: FE 15/02/2022 7:13:05 PM > Disabling protection... 15/02/2022 7:13:05 PM > Reconnecting phone... 15/02/2022 7:13:05 PM > Detecting Chip Version... 15/02/2022 7:13:05 PM > Platform: MT6765: 0766.0000 15/02/2022 7:13:05 PM > HW version: 8A00.CA00.0000.0000 15/02/2022 7:13:05 PM > Target config: 00E0 15/02/2022 7:13:05 PM > Prepairing loader... 15/02/2022 7:13:06 PM > Sending loader... 15/02/2022 7:13:06 PM > DA send successfully 15/02/2022 7:13:07 PM > Executing loader... 15/02/2022 7:13:07 PM > Synchronizing with loader... 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x14) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Device status: SYNC 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Device status: brom 15/02/2022 7:13:08 PM > Initializing flash... 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x4) 15/02/2022 7:13:08 PM > Secure Write: (0x390) 15/02/2022 7:13:09 PM > Initializing flash... 15/02/2022 7:13:09 PM > Secure Write: (0x4) 15/02/2022 7:13:09 PM > Sending loader... 15/02/2022 7:13:09 PM > Secure Write: (0x10) 15/02/2022 7:13:09 PM > Secure Write: (0x4540C) 15/02/2022 7:13:10 PM > Device status: SYNC 15/02/2022 7:13:10 PM > Reading info... 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > EMMC rpmb size: 16 Mb 15/02/2022 7:13:10 PM > EMMC boot1 size: 4 Mb 15/02/2022 7:13:10 PM > EMMC boot2 size: 4 Mb 15/02/2022 7:13:10 PM > EMMC gp1 size: 0 Mb 15/02/2022 7:13:10 PM > EMMC gp2 size: 0 Mb 15/02/2022 7:13:10 PM > EMMC gp3 size: 0 Mb 15/02/2022 7:13:10 PM > EMMC gp4 size: 0 Mb 15/02/2022 7:13:10 PM > EMMC user area size: 59640 Mb 15/02/2022 7:13:10 PM > eMMC flash chip: .13014E47.314A3950.38100D74.33C5C7B3 15/02/2022 7:13:10 PM > eMMC flash chip: Unknown: G1J9P8 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Secure Write: (0x4) 15/02/2022 7:13:10 PM > Internal RAM size: 224 Kb 15/02/2022 7:13:10 PM > External RAM size: 3072 Mb 15/02/2022 7:13:14 PM > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 15/02/2022 7:13:26 PM > Reading partitions... 15/02/2022 7:13:26 PM > Secure Write: (0x4) 15/02/2022 7:13:26 PM > Secure Write: (0x38) 15/02/2022 7:13:26 PM > Secure Write: (0x4) 15/02/2022 7:13:29 PM > Reading SUPER partition... 15/02/2022 7:13:29 PM > Secure Write: (0x4) 15/02/2022 7:13:29 PM > Secure Write: (0x38) 15/02/2022 7:13:29 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Reading security area... 15/02/2022 7:13:30 PM > Reading 1/3... 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x38) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x38) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x38) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:30 PM > Secure Write: (0x38) 15/02/2022 7:13:30 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x38) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x38) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x38) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x38) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:31 PM > Secure Write: (0x38) 15/02/2022 7:13:31 PM > Secure Write: (0x4) 15/02/2022 7:13:32 PM > Secure Write: (0x4) 15/02/2022 7:13:32 PM > Secure Write: (0x38) 15/02/2022 7:13:32 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x38) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x38) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x38) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x38) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:33 PM > Secure Write: (0x38) 15/02/2022 7:13:33 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x38) 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Reading 2/3... 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x38) 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x38) 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x4) 15/02/2022 7:13:34 PM > Secure Write: (0x38) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x38) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x38) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x38) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:35 PM > Secure Write: (0x38) 15/02/2022 7:13:35 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x38) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x38) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x38) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x38) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:36 PM > Secure Write: (0x38) 15/02/2022 7:13:36 PM > Secure Write: (0x4) 15/02/2022 7:13:37 PM > Secure Write: (0x4) 15/02/2022 7:13:37 PM > Secure Write: (0x38) 15/02/2022 7:13:37 PM > Secure Write: (0x4) 15/02/2022 7:13:37 PM > Secure Write: (0x4) 15/02/2022 7:13:37 PM > Secure Write: (0x38) 15/02/2022 7:13:37 PM > Secure Write: (0x4) 15/02/2022 7:13:37 PM > Secure Write: (0x4) 15/02/2022 7:13:37 PM > Secure Write: (0x38) 15/02/2022 7:13:37 PM > Secure Write: (0x4) 15/02/2022 7:13:38 PM > Secure Write: (0x4) 15/02/2022 7:13:38 PM > Secure Write: (0x38) 15/02/2022 7:13:38 PM > Secure Write: (0x4) 15/02/2022 7:13:38 PM > Reading 3/3... 15/02/2022 7:13:38 PM > Secure Write: (0x4) 15/02/2022 7:13:38 PM > Secure Write: (0x38) 15/02/2022 7:13:38 PM > Secure Write: (0x4) 15/02/2022 7:13:38 PM > Secure Write: (0x4) 15/02/2022 7:13:39 PM > Secure Write: (0x38) 15/02/2022 7:13:39 PM > Secure Write: (0x4) 15/02/2022 7:13:39 PM > Secure Write: (0x4) 15/02/2022 7:13:39 PM > Secure Write: (0x38) 15/02/2022 7:13:39 PM > Secure Write: (0x4) 15/02/2022 7:13:39 PM > Secure Write: (0x4) 15/02/2022 7:13:39 PM > Secure Write: (0x38) 15/02/2022 7:13:39 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x38) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x38) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x38) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x38) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:40 PM > Secure Write: (0x38) 15/02/2022 7:13:40 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x38) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x38) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x38) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x38) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x4) 15/02/2022 7:13:41 PM > Secure Write: (0x38) 15/02/2022 7:13:42 PM > Secure Write: (0x4) 15/02/2022 7:13:42 PM > Secure Write: (0x4) 15/02/2022 7:13:42 PM > Secure Write: (0x38) 15/02/2022 7:13:42 PM > Secure Write: (0x4) 15/02/2022 7:13:42 PM > Secure Write: (0x4) 15/02/2022 7:13:42 PM > Secure Write: (0x38) 15/02/2022 7:13:42 PM > Secure Write: (0x4) 15/02/2022 7:13:42 PM > Backup saved to "Q730MM_350305260000001_15-02-2022_19-13-30.SEC" 15/02/2022 7:13:45 PM > Erasing part 1... 15/02/2022 7:13:45 PM > AllowWrite operation started 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Secure Write: (0x38) 15/02/2022 7:13:45 PM > readed0 0x0000 15/02/2022 7:13:45 PM > readed1 0x40040004 15/02/2022 7:13:45 PM > readed2 0x0064 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Erasing part 2... 15/02/2022 7:13:45 PM > AllowWrite operation started 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:45 PM > Secure Write: (0x38) 15/02/2022 7:13:45 PM > readed0 0x0000 15/02/2022 7:13:45 PM > readed1 0x40040004 15/02/2022 7:13:45 PM > readed2 0x0064 15/02/2022 7:13:45 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Erasing part 3... 15/02/2022 7:13:49 PM > AllowWrite operation started 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Secure Write: (0x38) 15/02/2022 7:13:49 PM > readed0 0x0000 15/02/2022 7:13:49 PM > readed1 0x40040004 15/02/2022 7:13:49 PM > readed2 0x0064 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Erasing part 4... 15/02/2022 7:13:49 PM > AllowWrite operation started 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Secure Write: (0x4) 15/02/2022 7:13:49 PM > Secure Write: (0x38) 15/02/2022 7:13:49 PM > readed0 0x0000 15/02/2022 7:13:50 PM > readed1 0x40040004 15/02/2022 7:13:50 PM > readed2 0x0064 15/02/2022 7:13:50 PM > Secure Write: (0x4) 15/02/2022 7:13:51 PM > Secure Write: (0x4) 15/02/2022 7:13:51 PM > Secure Write: (0x18) 15/02/2022 7:13:53 PM > To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! |
02-17-2022, 08:36 | #4 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello We added your one more attempt. Please, repeat Repair IMEI operation once again and post here results. Note: Please, read attentively Software instructions. |
02-19-2022, 08:40 | #6 (permalink) | |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Quote:
You can try re-install Main driver for LG devices. Also, you can download Main driver from "Cable & Manual" tab on Software window. | |
02-25-2022, 03:16 | #7 (permalink) |
Member: 2182084 Status: Offline Thanks Meter: 4 | i made sure the drivers were installed properly before starting. ended up at this message again . To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! ok button was not active. reconnected the phone still not active. so i put the phone in firmware update mode and the ok button activated. i pressed okay and it got stuck at "New IMEI A: 353xxx-xx-xxx54-3" for a long time the second i disconnected it since nothing was happening it finalized and ofcource null imei. should i dry again ? if not can i get the credits back to use it on something else? -------------------------------------------------------------------------------- 24/02/2022 7:49:50 PM > Checking operation... 24/02/2022 7:49:52 PM > Execute : 0x00A7 24/02/2022 7:49:52 PM > Writing cmd... 24/02/2022 7:49:53 PM > reading cmd... 24/02/2022 7:49:53 PM > Read: EXEC... 24/02/2022 7:49:53 PM > Trying second method... 24/02/2022 7:49:53 PM > Checking Resource File... 24/02/2022 7:49:53 PM > Step 1... 24/02/2022 7:49:57 PM > Check FTP file List 24/02/2022 7:49:58 PM > FTP file List is obtained! 24/02/2022 7:49:58 PM > Step 2... 24/02/2022 7:50:04 PM > Check FTP file List 24/02/2022 7:50:05 PM > FTP file List is obtained! 24/02/2022 7:50:07 PM > Please, disconnect cable, then press "Ok" button 24/02/2022 7:50:15 PM > Connecting to server 0...24/02/2022 7:50:16 PM > OK 24/02/2022 7:50:16 PM > Octopus smart card is present. 24/02/2022 7:50:16 PM > Checking smart card...24/02/2022 7:50:26 PM > OK 24/02/2022 7:50:26 PM > Username: faramisimo 24/02/2022 7:50:26 PM > Authorizing...24/02/2022 7:50:29 PM > OK 24/02/2022 7:50:29 PM > Checking balance...24/02/2022 7:50:30 PM > OK 24/02/2022 7:50:30 PM > Checking operation...24/02/2022 7:50:35 PM > OK 24/02/2022 7:50:35 PM > Sending device information...24/02/2022 7:50:37 PM > OK 24/02/2022 7:50:37 PM > Get credits, needed for current operation...24/02/2022 7:50:38 PM > OK 24/02/2022 7:50:38 PM > Your balance: 100 credits. 24/02/2022 7:50:38 PM > To perform "Repair IMEI" operation you need to have 100 credits. 24/02/2022 7:50:41 PM > Please, connect powered OFF phone with USB cable. 24/02/2022 7:50:50 PM > Found port COM82 24/02/2022 7:50:51 PM > Detecting Chip Version... 24/02/2022 7:50:51 PM > Platform: MT6765: 0766.0000 24/02/2022 7:50:51 PM > HW version: 8A00.CA00.0000.0000 24/02/2022 7:50:51 PM > Connecting... 24/02/2022 7:50:51 PM > Target config: 0005 24/02/2022 7:50:51 PM > Brom Version: FF 24/02/2022 7:50:51 PM > BootLoader Version: 03 24/02/2022 7:50:51 PM > Sending auth... 24/02/2022 7:50:51 PM > Prepairing loader... 24/02/2022 7:50:51 PM > Sending loader... 24/02/2022 7:50:51 PM > Download Agent is not compatible! 24/02/2022 7:50:52 PM > Found port COM38 24/02/2022 7:50:53 PM > Detecting Chip Version... 24/02/2022 7:50:53 PM > Platform: MT6765: 0766.0000 24/02/2022 7:50:53 PM > HW version: 8A00.CA00.0000.0000 24/02/2022 7:50:53 PM > Connecting... 24/02/2022 7:50:53 PM > Target config: 00E5 24/02/2022 7:50:53 PM > Brom Version: 05 24/02/2022 7:50:53 PM > BootLoader Version: FE 24/02/2022 7:50:53 PM > Disabling protection... 24/02/2022 7:50:53 PM > Reconnecting phone... 24/02/2022 7:50:54 PM > Detecting Chip Version... 24/02/2022 7:50:54 PM > Platform: MT6765: 0766.0000 24/02/2022 7:50:54 PM > HW version: 8A00.CA00.0000.0000 24/02/2022 7:50:54 PM > Target config: 00E0 24/02/2022 7:50:54 PM > Prepairing loader... 24/02/2022 7:50:54 PM > Sending loader... 24/02/2022 7:50:54 PM > DA send successfully 24/02/2022 7:50:56 PM > Executing loader... 24/02/2022 7:50:56 PM > Synchronizing with loader... 24/02/2022 7:50:56 PM > Secure Write: (0x4) 24/02/2022 7:50:56 PM > Secure Write: (0x4) 24/02/2022 7:50:56 PM > Secure Write: (0x14) 24/02/2022 7:50:56 PM > Secure Write: (0x4) 24/02/2022 7:50:56 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Device status: SYNC 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Device status: brom 24/02/2022 7:50:57 PM > Initializing flash... 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x4) 24/02/2022 7:50:57 PM > Secure Write: (0x390) 24/02/2022 7:50:58 PM > Initializing flash... 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Sending loader... 24/02/2022 7:50:58 PM > Secure Write: (0x10) 24/02/2022 7:50:58 PM > Secure Write: (0x4540C) 24/02/2022 7:50:58 PM > Device status: SYNC 24/02/2022 7:50:58 PM > Reading info... 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > EMMC rpmb size: 16 Mb 24/02/2022 7:50:58 PM > EMMC boot1 size: 4 Mb 24/02/2022 7:50:58 PM > EMMC boot2 size: 4 Mb 24/02/2022 7:50:58 PM > EMMC gp1 size: 0 Mb 24/02/2022 7:50:58 PM > EMMC gp2 size: 0 Mb 24/02/2022 7:50:58 PM > EMMC gp3 size: 0 Mb 24/02/2022 7:50:58 PM > EMMC gp4 size: 0 Mb 24/02/2022 7:50:58 PM > EMMC user area size: 59640 Mb 24/02/2022 7:50:58 PM > eMMC flash chip: .13014E47.314A3950.38100D74.33C5C7B3 24/02/2022 7:50:58 PM > eMMC flash chip: Unknown: G1J9P8 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Secure Write: (0x4) 24/02/2022 7:50:58 PM > Internal RAM size: 224 Kb 24/02/2022 7:50:58 PM > External RAM size: 3072 Mb 24/02/2022 7:51:03 PM > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 24/02/2022 7:51:14 PM > Reading partitions... 24/02/2022 7:51:15 PM > Secure Write: (0x4) 24/02/2022 7:51:15 PM > Secure Write: (0x38) 24/02/2022 7:51:15 PM > Secure Write: (0x4) 24/02/2022 7:51:16 PM > Reading SUPER partition... 24/02/2022 7:51:16 PM > Secure Write: (0x4) 24/02/2022 7:51:16 PM > Secure Write: (0x38) 24/02/2022 7:51:16 PM > Secure Write: (0x4) 24/02/2022 7:51:16 PM > Reading security area... 24/02/2022 7:51:16 PM > Reading 1/3... 24/02/2022 7:51:16 PM > Secure Write: (0x4) 24/02/2022 7:51:16 PM > Secure Write: (0x38) 24/02/2022 7:51:16 PM > Secure Write: (0x4) 24/02/2022 7:51:16 PM > Secure Write: (0x4) 24/02/2022 7:51:16 PM > Secure Write: (0x38) 24/02/2022 7:51:16 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x38) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x38) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x38) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x38) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x4) 24/02/2022 7:51:17 PM > Secure Write: (0x38) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x38) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x38) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x38) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x4) 24/02/2022 7:51:18 PM > Secure Write: (0x38) 24/02/2022 7:51:19 PM > Secure Write: (0x4) 24/02/2022 7:51:19 PM > Secure Write: (0x4) 24/02/2022 7:51:19 PM > Secure Write: (0x38) 24/02/2022 7:51:19 PM > Secure Write: (0x4) 24/02/2022 7:51:19 PM > Secure Write: (0x4) 24/02/2022 7:51:19 PM > Secure Write: (0x38) 24/02/2022 7:51:19 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x38) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x38) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x38) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Reading 2/3... 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:20 PM > Secure Write: (0x38) 24/02/2022 7:51:20 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x38) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x38) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x38) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x38) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:21 PM > Secure Write: (0x38) 24/02/2022 7:51:21 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x38) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x38) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x38) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:22 PM > Secure Write: (0x38) 24/02/2022 7:51:22 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x38) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x38) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x38) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x38) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:23 PM > Secure Write: (0x38) 24/02/2022 7:51:23 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Secure Write: (0x38) 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Reading 3/3... 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Secure Write: (0x38) 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Secure Write: (0x38) 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:24 PM > Secure Write: (0x4) 24/02/2022 7:51:25 PM > Secure Write: (0x38) 24/02/2022 7:51:25 PM > Secure Write: (0x4) 24/02/2022 7:51:25 PM > Secure Write: (0x4) 24/02/2022 7:51:25 PM > Secure Write: (0x38) 24/02/2022 7:51:25 PM > Secure Write: (0x4) 24/02/2022 7:51:25 PM > Secure Write: (0x4) 24/02/2022 7:51:25 PM > Secure Write: (0x38) 24/02/2022 7:51:25 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x38) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x38) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x38) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x38) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:26 PM > Secure Write: (0x38) 24/02/2022 7:51:26 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x38) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x38) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x38) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x38) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x4) 24/02/2022 7:51:27 PM > Secure Write: (0x38) 24/02/2022 7:51:28 PM > Secure Write: (0x4) 24/02/2022 7:51:28 PM > Secure Write: (0x4) 24/02/2022 7:51:28 PM > Secure Write: (0x38) 24/02/2022 7:51:28 PM > Secure Write: (0x4) 24/02/2022 7:51:28 PM > Backup saved to "Q730MM_350305260000001_24-02-2022_19-51-16.SEC" 24/02/2022 7:51:30 PM > Erasing part 1... 24/02/2022 7:51:31 PM > AllowWrite operation started 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Secure Write: (0x38) 24/02/2022 7:51:31 PM > readed0 0x0000 24/02/2022 7:51:31 PM > readed1 0x40040004 24/02/2022 7:51:31 PM > readed2 0x0064 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Erasing part 2... 24/02/2022 7:51:31 PM > AllowWrite operation started 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:31 PM > Secure Write: (0x38) 24/02/2022 7:51:31 PM > readed0 0x0000 24/02/2022 7:51:31 PM > readed1 0x40040004 24/02/2022 7:51:31 PM > readed2 0x0064 24/02/2022 7:51:31 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Erasing part 3... 24/02/2022 7:51:33 PM > AllowWrite operation started 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Secure Write: (0x38) 24/02/2022 7:51:33 PM > readed0 0x0000 24/02/2022 7:51:33 PM > readed1 0x40040004 24/02/2022 7:51:33 PM > readed2 0x0064 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Erasing part 4... 24/02/2022 7:51:33 PM > AllowWrite operation started 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Secure Write: (0x4) 24/02/2022 7:51:33 PM > Secure Write: (0x38) 24/02/2022 7:51:33 PM > readed0 0x0000 24/02/2022 7:51:34 PM > readed1 0x40040004 24/02/2022 7:51:34 PM > readed2 0x0064 24/02/2022 7:51:34 PM > Secure Write: (0x4) 24/02/2022 7:51:35 PM > Secure Write: (0x4) 24/02/2022 7:51:35 PM > Secure Write: (0x18) 24/02/2022 7:51:37 PM > To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! 24/02/2022 7:59:43 PM > New IMEI A: 353889-80-133754-3 24/02/2022 8:00:43 PM > Finalizing... 24/02/2022 8:00:46 PM > Rebooting phone... 24/02/2022 8:00:47 PM > IMEI successfully fixed! 24/02/2022 8:00:47 PM > Performed by 3.1.7 Software version. 24/02/2022 8:00:47 PM > Elapsed Time: 12:11:29 AM 24/02/2022 8:01:51 PM > -------------------------------------------------------------------------------- 24/02/2022 8:01:51 PM > Connecting to server 0...24/02/2022 8:01:54 PM > OK 24/02/2022 8:01:54 PM > Username: faramisimo 24/02/2022 8:01:54 PM > Authorizing...24/02/2022 8:01:57 PM > OK 24/02/2022 8:01:57 PM > Checking balance...24/02/2022 8:01:58 PM > OK 24/02/2022 8:01:58 PM > Your balance: 0 credits. |
02-25-2022, 09:47 | #8 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello We have refunded credits to your balance. Unfortunately, at the moment, we don't have solution for your problem. We are working on it. We will let you know, when you can perform the operation again. |
