02-22-2022, 16:45 | #1 (permalink) |
Insane Poster Join Date: Mar 2018 Location: Vietnam
Member: 2823542 Status: Offline Sonork: 879.147.1541 Thanks Meter: 24 | LM-V405UA Unlock [Solved] Work ID: 00000000024844C0 Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: V405UA (SPR) Initializing ADB...OK Waiting for phone...OK Model ID: LM-V405UA Phone firmware version: LMV405AT-00-V10c-LAO-COM-OCT-18- 2018-ARB00+03 Short firmware version: V10c Kernel version: 4.9.65-perf (lgmobile@LGEACI5R9) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Oct 18 17:09:52 KST 201 Android version: 8.1.0 Hardware: Qualcomm Technologies, Inc SDM845 AArch64 Processor rev 13 (aarch64) Target operator: VZW Please, make sure the phone is locked to Sprint / Boost network. Continue? Unlock operation for V405UA (SPR) will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...Failed!OK Connecting to server 1...OK Octopus smart card is present. Checking smart card...OK Username: JpaPRqt3d6 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: sdm845 SW version: LMV405UA3AT-00-V10c-310-120-OCT-18-2018- ARB00+03 Android version: 8.1.0 LAF Version: 1.1 Product ID: PT01S181024003958 IMEI: 359583-09-069087-8 Target operator: LAO Hardware: rev_10 Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone... Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Failed! Performed by 3.1.7.01 Software version. |
