02-07-2022, 14:41 | #3 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | Log file "C:\Program Files\Octoplus\Octoplus_LG\LOG\10-12-2021_16-36-56.log" created. 10/12/2021 16:37:00 > Searching for server... 10/12/2021 16:37:02 > Trying to ping server...0 10/12/2021 16:37:03 > Trying to ping server...110/12/2021 16:37:03 > ok 10/12/2021 16:37:03 > Trying connect to server... 10/12/2021 16:37:04 > Searching installed cards... 10/12/2021 16:37:04 > Found card with s/n: 00006C06 10/12/2021 16:37:04 > Server check... 10/12/2021 16:37:05 > Server Check succesfull! 10/12/2021 16:37:05 > Server Check succesfull! 10/12/2021 16:37:07 > Welcome to Octoplus/Octopus Box LG Software version 3.1.5.02 10/12/2021 16:37:07 > Card S/N : 0000006C06 10/12/2021 16:37:19 > INI FUpdateInfo Done! 10/12/2021 16:37:19 > INI FShowUpdateInfo start 10/12/2021 16:37:19 > INI FShowUpdateInfo 1 10/12/2021 16:38:51 > -------------------------------------------------------------------------------- 10/12/2021 16:38:51 > Transport: Connected 10/12/2021 16:38:52 > Authorized. 10/12/2021 16:38:54 > Work ID: 0000000001F329C6 10/12/2021 16:38:55 > Checking data...10/12/2021 16:38:56 > OK 10/12/2021 16:38:56 > Platform: LG Qualcomm 10/12/2021 16:38:56 > Selected port: COM133 10/12/2021 16:38:56 > Selected model: LMX210CM 10/12/2021 16:38:56 > Reading info... 10/12/2021 16:38:58 > Model ID: LM-X210CM 10/12/2021 16:38:58 > IMEI: 355513-10-400361-4 10/12/2021 16:38:58 > Android version: 8.1.0 10/12/2021 16:38:58 > Battery level: 86% 10/12/2021 16:39:31 > Trying to enable Diagnostics ports... 10/12/2021 16:39:31 > Found model LMX210CM: ÿh at port COM133 10/12/2021 16:39:31 > Reading info... 10/12/2021 16:39:33 > Model ID: LM-X210CM 10/12/2021 16:39:33 > IMEI: 355513-10-400361-4 10/12/2021 16:39:33 > Android version: 8.1.0 10/12/2021 16:39:33 > Battery level: 86% 10/12/2021 16:39:34 > Mode: Normal 10/12/2021 16:39:34 > Firmware compiled date: Oct 24 2019 10/12/2021 16:39:34 > Firmware compiled time: 07:00:00 10/12/2021 16:39:34 > Firmware released date: Apr 1 2020 10/12/2021 16:39:34 > Firmware released time: 17:49:43 10/12/2021 16:39:34 > SW Version: 10/12/2021 16:39:34 > MPSS.JO.3.0.c12-00036-8937_GENNS_PACK-1.220702.1.229846.1 10/12/2021 16:39:34 > IMEI: 355513-10-400361-4 10/12/2021 16:39:34 > Bluetooth address: 7C:F3:1B:01:4A:4B 10/12/2021 16:39:34 > Wi-Fi MAC address: 98:B8:BA:6F:4B:F7 10/12/2021 16:39:34 > SPC: 000000 10/12/2021 16:39:35 > Please, select Unlock Method! 10/12/2021 16:39:56 > Selected Unlock via SD Card (with Unlock APK) 10/12/2021 16:39:56 > Unlock operation for LMX210CM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? 10/12/2021 16:40:30 > Connecting to server 0...10/12/2021 16:40:32 > OK 10/12/2021 16:40:32 > Octopus smart card is present. 10/12/2021 16:40:32 > Checking smart card...10/12/2021 16:40:38 > OK 10/12/2021 16:40:38 > Username: 10/12/2021 16:40:38 > Authorizing...10/12/2021 16:40:40 > Failed! 10/12/2021 16:40:40 > Login error: Wrong username! 10/12/2021 16:40:40 > Failed! 10/12/2021 16:40:40 > Performed by 3.1.5.02 Software version. 10/12/2021 16:40:40 > Elapsed Time: 0:01:49 10/12/2021 16:41:17 > -------------------------------------------------------------------------------- 10/12/2021 16:41:17 > Connecting to server 0...10/12/2021 16:41:18 > OK 10/12/2021 16:41:18 > Username: edwarddominguez1 10/12/2021 16:41:18 > Authorizing...10/12/2021 16:41:23 > OK 10/12/2021 16:41:23 > Checking balance...10/12/2021 16:41:25 > OK 10/12/2021 16:41:25 > Your balance: 100 credits. 10/12/2021 16:41:30 > -------------------------------------------------------------------------------- 10/12/2021 16:41:31 > Transport: Connected 10/12/2021 16:41:32 > Authorized. 10/12/2021 16:41:33 > Work ID: 0000000001F32A4B 10/12/2021 16:41:33 > Checking data...10/12/2021 16:41:34 > OK 10/12/2021 16:41:34 > Platform: LG Qualcomm 10/12/2021 16:41:34 > Selected port: COM133 10/12/2021 16:41:34 > Selected model: LMX210CM 10/12/2021 16:41:34 > Reading info... 10/12/2021 16:41:36 > Model ID: LM-X210CM 10/12/2021 16:41:36 > IMEI: 355513-10-400361-4 10/12/2021 16:41:36 > Android version: 8.1.0 10/12/2021 16:41:36 > Battery level: 87% 10/12/2021 16:41:36 > Mode: Normal 10/12/2021 16:41:36 > Firmware compiled date: Oct 24 2019 10/12/2021 16:41:36 > Firmware compiled time: 07:00:00 10/12/2021 16:41:36 > Firmware released date: Apr 1 2020 10/12/2021 16:41:36 > Firmware released time: 17:49:43 10/12/2021 16:41:36 > SW Version: 10/12/2021 16:41:36 > MPSS.JO.3.0.c12-00036-8937_GENNS_PACK-1.220702.1.229846.1 10/12/2021 16:41:36 > IMEI: 355513-10-400361-4 10/12/2021 16:41:37 > Bluetooth address: 7C:F3:1B:01:4A:4B 10/12/2021 16:41:37 > Wi-Fi MAC address: 98:B8:BA:6F:4B:F7 10/12/2021 16:41:37 > SPC: 000000 10/12/2021 16:41:37 > Please, select Unlock Method! 10/12/2021 16:41:48 > Selected Unlock via SD Card (with Unlock APK) 10/12/2021 16:41:48 > Unlock operation for LMX210CM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? 10/12/2021 16:41:50 > Connecting to server 0...10/12/2021 16:41:52 > OK 10/12/2021 16:41:52 > Octopus smart card is present. 10/12/2021 16:41:52 > Checking smart card...10/12/2021 16:41:59 > OK 10/12/2021 16:41:59 > Username: edwarddominguez1 10/12/2021 16:41:59 > Authorizing...10/12/2021 16:42:04 > OK 10/12/2021 16:42:04 > Checking balance...10/12/2021 16:42:05 > OK 10/12/2021 16:42:05 > Checking operation...10/12/2021 16:42:09 > OK 10/12/2021 16:42:09 > Sending device information...10/12/2021 16:42:12 > OK 10/12/2021 16:42:12 > Get credits, needed for current operation...10/12/2021 16:42:15 > OK 10/12/2021 16:42:15 > Your balance: 100 credits. 10/12/2021 16:42:15 > To perform "Unlock" operation you need to have 100 credits. 10/12/2021 16:42:25 > Prepairing loader... 10/12/2021 16:42:25 > Step 1... 10/12/2021 16:42:25 > Downloading... 10/12/2021 16:42:27 > Check FTP file List 10/12/2021 16:42:28 > FTP file List is obtained! 10/12/2021 16:42:28 > Step 2... 10/12/2021 16:42:28 > Extracting... 10/12/2021 16:42:29 > Step 3... 10/12/2021 16:42:29 > Initializing... 10/12/2021 16:42:30 > Copying on SD Card... 10/12/2021 16:42:30 > Found 2 portable devices 10/12/2021 16:42:30 > WPD_OBJECT_NAME: Fortune 2 10/12/2021 16:42:42 > transfer to F: 10/12/2021 16:43:32 > Switching to Download mode...10/12/2021 16:43:52 > OK 10/12/2021 16:43:52 > Initializing flash...10/12/2021 16:43:54 > OK 10/12/2021 16:43:55 > Platform: msm8937 10/12/2021 16:43:55 > SW version: 10/12/2021 16:43:55 > LMX210CMAT-01-V20n-310-150-APR-01-2020-ARB03+0 10/12/2021 16:43:55 > Android version: 8.1.0 10/12/2021 16:43:55 > LAF Version: 1.1 10/12/2021 16:43:55 > Product ID: VP01S191005005997 10/12/2021 16:43:55 > IMEI: 355513-10-400361-4 10/12/2021 16:43:55 > Target operator: CRK 10/12/2021 16:43:55 > Hardware: rev_11 10/12/2021 16:43:59 > Writing cmd... 10/12/2021 16:44:00 > reading cmd... 10/12/2021 16:44:00 > Read: EXEC... 10/12/2021 16:44:00 > Please, insert / reinsert SD Card into Phone. Then press "OK" button. 10/12/2021 16:44:24 > Writing cmd... 10/12/2021 16:44:25 > reading cmd... 10/12/2021 16:44:25 > Read: EXEC... 10/12/2021 16:44:29 > Reading partitions... 10/12/2021 16:44:29 > modem: #004000; #02FFFF 10/12/2021 16:44:29 > aboot: #030000; #030FFF 10/12/2021 16:44:29 > abootbak: #031000; #031FFF 10/12/2021 16:44:29 > tz: #032000; #032FFF 10/12/2021 16:44:29 > tzbak: #033000; #033FFF 10/12/2021 16:44:29 > sbl1: #034000; #0347FF 10/12/2021 16:44:29 > sbl1bak: #034800; #034FFF 10/12/2021 16:44:29 > rpm: #035000; #0353FF 10/12/2021 16:44:29 > rpmbak: #035400; #0357FF 10/12/2021 16:44:29 > devcfg: #035800; #035BFF 10/12/2021 16:44:29 > devcfgbak: #035C00; #035FFF 10/12/2021 16:44:29 > cmnlib: #036000; #0363FF 10/12/2021 16:44:29 > cmnlibbak: #036400; #0367FF 10/12/2021 16:44:29 > cmnlib64: #036800; #036BFF 10/12/2021 16:44:29 > cmnlib64bak: #036C00; #036FFF 10/12/2021 16:44:29 > keymaster: #037000; #0373FF 10/12/2021 16:44:29 > keymasterbak: #037400; #0377FF 10/12/2021 16:44:29 > spare1: #037800; #037BFF 10/12/2021 16:44:29 > spare2: #037C00; #037FFF 10/12/2021 16:44:29 > persistent: #038000; #0383FF 10/12/2021 16:44:29 > devinfo: #038400; #038BFF 10/12/2021 16:44:29 > spare3: #038C00; #03BFFF 10/12/2021 16:44:29 > modemst1: #03C000; #03CBFF 10/12/2021 16:44:29 > modemst2: #03CC00; #03D7FF 10/12/2021 16:44:29 > mcfg: #03D800; #03F7FF 10/12/2021 16:44:29 > fsc: #03F800; #03FBFF 10/12/2021 16:44:29 > ssd: #03FC00; #03FFFF 10/12/2021 16:44:29 > fsg: #040000; #040BFF 10/12/2021 16:44:29 > spare4: #040C00; #043FFF 10/12/2021 16:44:29 > dsp: #044000; #04BFFF 10/12/2021 16:44:29 > ftm: #04C000; #04FFFF 10/12/2021 16:44:29 > misc: #050000; #053FFF 10/12/2021 16:44:29 > drm: #054000; #057FFF 10/12/2021 16:44:29 > sns: #058000; #05BFFF 10/12/2021 16:44:29 > fota: #05C000; #060FFF 10/12/2021 16:44:29 > sec: #061000; #0613FF 10/12/2021 16:44:29 > keystore: #061400; #0617FF 10/12/2021 16:44:29 > rct: #061800; #061BFF 10/12/2021 16:44:29 > encrypt: #061C00; #061FFF 10/12/2021 16:44:29 > eksst: #062000; #0623FF 10/12/2021 16:44:29 > apdp: #062400; #0627FF 10/12/2021 16:44:29 > msadp: #062800; #062BFF 10/12/2021 16:44:29 > dpo: #062C00; #062FFF 10/12/2021 16:44:29 > DDR: #063000; #0633FF 10/12/2021 16:44:29 > spare5: #063400; #063FFF 10/12/2021 16:44:29 > boot: #064000; #073FFF 10/12/2021 16:44:29 > laf: #074000; #083FFF 10/12/2021 16:44:29 > lafbak: #084000; #093FFF 10/12/2021 16:44:29 > recovery: #094000; #0A3FFF 10/12/2021 16:44:29 > recoverybak: #0A4000; #0B3FFF 10/12/2021 16:44:29 > factory: #0B4000; #0CFFFF 10/12/2021 16:44:29 > raw_resources: #0D0000; #0D1FFF 10/12/2021 16:44:29 > raw_resourcesbak: #0D2000; #0D3FFF 10/12/2021 16:44:29 > persist: #0D4000; #0E3FFF 10/12/2021 16:44:29 > mpt: #0E4000; #0F3FFF 10/12/2021 16:44:29 > srtc: #0F4000; #0F7FFF 10/12/2021 16:44:29 > system: #0F8000; #7B7FFF 10/12/2021 16:44:29 > cache: #7B8000; #8B7FFF 10/12/2021 16:44:29 > userdata: #8B8000; #1D57FFF 10/12/2021 16:44:29 > grow: #1D58000; #1D59FDE 10/12/2021 16:44:29 > : #000000; #000000 10/12/2021 16:44:29 > Checking data... 10/12/2021 16:44:35 > Execute : 0x00D7 10/12/2021 16:44:35 > Writing cmd... 10/12/2021 16:44:35 > reading cmd... 10/12/2021 16:44:35 > Read: EXEC... 10/12/2021 16:44:47 > Connecting to phone...10/12/2021 16:44:50 > OK 10/12/2021 16:44:50 > Initializing flash...10/12/2021 16:44:53 > OK 10/12/2021 16:44:54 > ELF E01: 0019000000640000000000005D4A0000EF1800000000000002 00000002000000 10/12/2021 16:44:54 > Sending loader... 10/12/2021 16:45:05 > Execute : 0x00DD 10/12/2021 16:45:05 > Writing cmd... 10/12/2021 16:45:05 > reading cmd... 10/12/2021 16:45:07 > Read: EXEC... 10/12/2021 16:45:29 > Connecting to phone... 10/12/2021 16:45:45 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! 10/12/2021 16:46:26 > Initializing flash...10/12/2021 16:46:29 > OK 10/12/2021 16:46:30 > Prepairing loader... 10/12/2021 16:46:33 > Executing loader... 10/12/2021 16:46:36 > Writing cmd... 10/12/2021 16:46:37 > reading cmd... 10/12/2021 16:46:39 > Read: EXEC... 10/12/2021 16:47:22 > Connecting to phone...10/12/2021 16:47:25 > OK 10/12/2021 16:47:25 > Initializing flash...10/12/2021 16:47:27 > OK 10/12/2021 16:47:29 > Initializing device... 10/12/2021 16:47:33 > dem size00000160 10/12/2021 16:47:33 > verifying hash 1 10/12/2021 16:47:33 > verifying hash 2 10/12/2021 16:47:33 > Hashes OK 10/12/2021 16:47:35 > Checking data... 10/12/2021 16:48:34 > dem size00000037 10/12/2021 16:48:35 > Calculating. Please Wait... 10/12/2021 16:49:19 > dem size00000618 10/12/2021 16:49:20 > Unlocking... 10/12/2021 16:49:31 > dem size00000036 10/12/2021 16:49:33 > Phone successfully unlocked! 10/12/2021 16:49:35 > Rebooting phone... 10/12/2021 16:49:35 > Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! 10/12/2021 16:49:35 > Performed by 3.1.5.02 Software version. 10/12/2021 16:49:36 > Elapsed Time: 0:08:06 |
02-07-2022, 14:56 | #5 (permalink) | |
Member: 914220 Status: Offline Thanks Meter: 206 | Quote:
i unlock phone diciembre client come today and problem was same day algo i posted this error 12-21-2021 | |
02-07-2022, 15:20 | #7 (permalink) | |
client.. and client use more internet today and phone without option to buy internet or check your balance is a little problem thanks anyway | |
02-09-2022, 09:41 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Maybe your problem will solved with reflash the phone, but, unfortunately, we don't have firmware for it. Last edited by Octopus support; 02-09-2022 at 09:47. |
