05-17-2022, 12:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | LMX210APMAT unlock issue [Asnwered] Card S/N : 0000002918 -------------------------------------------------------------------------------- Work ID: 0000000001C528E3 Checking data...OK Platform: LG Qualcomm Selected port: COM55 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-155993-3 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: Oct 24 2019 Firmware compiled time: 07:00:00 Firmware released date: Dec 4 2019 Firmware released time: 18:17:26 SW Version: MPSS.JO.3.0.c12-00036-8937_GENNS_PACK-1.220702.1.229846.1 IMEI: 355437-10-155993-3 Bluetooth address: AC:F6:F7:2D:AD:A0 Wi-Fi MAC address: 64:C2E:98:20:93 SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Dubr509 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 140 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20l-310-410-DEC-04-2019-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190511006939 IMEI: 355437-10-155993-3 Target operator: ATT Hardware: rev_10 Failed! Please, perform the following steps: 1. Connect SD card via SD card reader to PC. 2. Put phone into Download mode manually. 3. Repeat Unlock operation. Rebooting phone... Performed by 3.1.8.01 Software version. |
05-17-2022, 12:23 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello Have you tried to do this steps? 1. Connect SD card via SD card reader to PC. 2. Put phone into Download mode manually. 3. Repeat Unlock operation. |
The Following User Says Thank You to Octopus support For This Useful Post: |
05-17-2022, 17:13 | #3 (permalink) | |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Another problem persist Quote:
Card S/N : 0000002918 -------------------------------------------------------------------------------- Work ID: 0000000001C544D4 Checking data...OK Platform: LG Qualcomm Selected port: COM116 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-155993-3 Android version: 8.1.0 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20l-310-410-DEC-04-2019-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190511006939 IMEI: 355437-10-155993-3 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Dubr509 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 140 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Can't found Micro SD cards Please, connect Micro SD card to PC then repeat operation again. NOTE: SD card must be formatted in FAT or FAT32 file system and size must be lower than 32 GB! Failed! Rebooting phone... Performed by 3.1.8.01 Software version. | |
05-18-2022, 08:51 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, repeat Unlock operation via SD card method follow software manual. Quote:
