08-25-2021, 17:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: cameroon
Member: 1920581 Status: Offline Sonork: 100.1674372 Thanks Meter: 45 | Ls993 dead mode in frp remove [Answered] 25/08/2021 15:54:45 > Authorized. 25/08/2021 15:54:47 > Work ID: 000000000171DB89 25/08/2021 15:54:48 > Please, select Reset FRP Method! 25/08/2021 15:55:30 > Checking data...25/08/2021 15:55:32 > OK 25/08/2021 15:55:32 > INI FUpdateInfo Done! 25/08/2021 15:55:32 > Platform: LG Qualcomm 25/08/2021 15:55:32 > INI FShowUpdateInfo start 25/08/2021 15:55:32 > Selected port: COM4 25/08/2021 15:55:32 > INI FShowInfo start 25/08/2021 15:55:32 > INI FShowInfo show News Form 25/08/2021 15:55:32 > Selected model: LS993 25/08/2021 15:55:32 > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 25/08/2021 15:55:32 > Reading info... 25/08/2021 15:56:17 > Initializing ADB...25/08/2021 15:56:18 > OK 25/08/2021 15:56:18 > Waiting for phone... 25/08/2021 15:56:18 > Please, reconnect phone, enable USB debugging, and try again. 25/08/2021 15:56:18 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.25/08/2021 15:56:34 > Canceled! 25/08/2021 15:56:34 > Performed by 3.1.4 Software version. 25/08/2021 15:56:34 > Elapsed Time: 00:01:51 25/08/2021 15:56:37 > -------------------------------------------------------------------------------- 25/08/2021 15:56:38 > Transport: Connected 25/08/2021 15:56:39 > Authorized. 25/08/2021 15:56:40 > Work ID: 000000000171DC37 25/08/2021 15:56:40 > Please, select Reset FRP Method! 25/08/2021 15:56:57 > Checking data...25/08/2021 15:56:58 > OK 25/08/2021 15:56:58 > Platform: LG Qualcomm 25/08/2021 15:56:58 > Selected port: COM464 25/08/2021 15:56:58 > Selected model: LS993 25/08/2021 15:56:58 > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 25/08/2021 15:56:58 > Reading info... 25/08/2021 15:57:00 > IMEI: 355140-08-210882-5 25/08/2021 15:57:00 > Android version: 8.0.0 25/08/2021 15:57:00 > Battery level: 25% 25/08/2021 15:57:01 > Mode: Emergency 25/08/2021 15:57:01 > Initializing flash...25/08/2021 15:57:02 > OK 25/08/2021 15:57:03 > Platform: msm8996 25/08/2021 15:57:03 > SW version: 25/08/2021 15:57:03 > LS993ZVC_12 25/08/2021 15:57:04 > Android version: 8.0.0 25/08/2021 15:57:04 > LAF Version: 1.1 25/08/2021 15:57:04 > Product ID: YE03S180906000543 25/08/2021 15:57:04 > IMEI: 355140-08-210882-5 25/08/2021 15:57:04 > Target operator: SPR 25/08/2021 15:57:04 > Hardware: rev_10 25/08/2021 15:57:04 > Reading partitions...25/08/2021 15:57:10 > OK 25/08/2021 15:57:10 > Reading BOOT... 25/08/2021 15:57:11 > ID: 0005F0E100310000 25/08/2021 15:57:11 > Operation is not safe and exist risk to damage the device! Do You want to continue?25/08/2021 15:57:18 > OK 25/08/2021 15:57:18 > Backup saved to "LS993_355140082108825_25-08-2021_15-57-18.oct" 25/08/2021 15:57:18 > Switching to Qualcomm 9008 mode... 25/08/2021 15:59:03 > "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" and press "Continue" button 25/08/2021 15:59:03 > Performed by 3.1.4 Software version. 25/08/2021 15:59:03 > Elapsed Time: 00:02:26 25/08/2021 16:01:26 > Access violation at address 00C4E467 in module 'OctoplusLG.exe'. Read of address 00000004 |
08-26-2021, 07:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. To repair the device do the following: Reboot the phone, press and hold "Vol-"+ "Vol+" + "Power" buttons 15 seconds and then connect the device again. 1. Select LG LS993 in the list of Software. 2. Select this backup file "LS993_355140082108825_25-08-2021_15-57-18.oct" into the Firmware slot in Software. 3. Press "Reset FRP via TP (Qualcomm Mode)" button in Software and write backup file. 4. Post here the result. Last edited by Octopus box; 08-26-2021 at 11:27. |
