M255 successfully unlocked Welcome to Octoplus/Octopus Box LG Software version 2.7.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: M255 Reading info... Model ID: LG-M255 IMEI: 355574-08-181629-5 Android version: 7.0 Battery level: 21% SW Version: M25510l Trying to enable Diagnostics ports... Found model LGM255AT: ÿh at port COM13 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "M255_355574081816295_30-12-2017_18-11-59.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "M255_355574081816295_30-12-2017_18-18-22.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Diagnostics ports are enbled! Switching to Serial Port... Found model LGM255AT* ÿh at port COM13 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.7.8 Software version. |
BUT HOW TO ROOT Welcome to Octoplus/Octopus Box LG Software version 2.7.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: M255 Reading info... Could not detect mode! Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM418 Selected model: M255 Reading info... Model ID: LG-M255 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 7% SW Version: M25510l Mode: Emergency Initializing flash...OK SW version: LGM255AT-01-V10l-310-410-OCT-23-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CY15S171118003154 IMEI: 355574-08-207987-7 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.7.6 Software version. |
Please share root, i have 2 that require unlock. |
Also got succesful but using m257 model after failing with m255 model I TRIED TO SELECT THE REAL MODEL M255 BUT I DID NOT GET SUCCESS, UNTIL I READ SOMEONE'S POST SOMEWHERE AND HE SUGGESTED TO SELECT M257 MODEL AND EVERYTHING WENT FINE.. -------------------------------------------------------------------------------- 6/13/2019 3:42:37 PM > Checking data...6/13/2019 3:42:38 PM > OK 6/13/2019 3:42:38 PM > Platform: LG Qualcomm 6/13/2019 3:42:38 PM > Selected port: COM47 6/13/2019 3:42:38 PM > Selected model: M257 6/13/2019 3:42:38 PM > Reading info... 6/13/2019 3:42:39 PM > Model ID: LG-M255 6/13/2019 3:42:39 PM > IMEI: 355574-08-281106-3 6/13/2019 3:42:39 PM > Android version: 8.1.0 6/13/2019 3:42:39 PM > Battery level: 94% 6/13/2019 3:42:40 PM > Mode: Normal 6/13/2019 3:42:40 PM > Firmware compiled date: May 07 2018 6/13/2019 3:42:40 PM > Firmware compiled time: 06:00:00 6/13/2019 3:42:40 PM > Firmware released date: Aug 24 2018 6/13/2019 3:42:40 PM > Firmware released time: 16:08:31 6/13/2019 3:42:40 PM > SW Version: 6/13/2019 3:42:40 PM > MPSS.JO.2.0.c1.2-00044-8937_GENNS_PACK-1 6/13/2019 3:42:40 PM > IMEI: 355574-08-281106-3 6/13/2019 3:42:40 PM > Bluetooth address: 00:3D:E8:34:1A:AE 6/13/2019 3:42:40 PM > Wi-Fi MAC address: 00:3D:E8:BA:E9:5A 6/13/2019 3:42:40 PM > SPC: 000000 6/13/2019 3:42:41 PM > Unlocking... 6/13/2019 3:42:43 PM > Reading QCN... 6/13/2019 3:42:43 PM > Send SPC...6/13/2019 3:42:43 PM > OK 6/13/2019 3:42:43 PM > Reading Mobile Property...6/13/2019 3:42:43 PM > OK 6/13/2019 3:42:43 PM > Reading Feature Mask...6/13/2019 3:42:44 PM > OK 6/13/2019 3:42:44 PM > Reading Roaming List 0...6/13/2019 3:42:44 PM > OK 6/13/2019 3:42:44 PM > Reading NV_Numbered Items...6/13/2019 3:44:46 PM > OK 6/13/2019 3:44:46 PM > Reading NV_Numbered SIM1 Items...6/13/2019 3:46:48 PM > OK 6/13/2019 3:46:48 PM > Reading NV_Numbered SIM2 Items...6/13/2019 3:48:57 PM > OK 6/13/2019 3:48:57 PM > Reading NV Items...6/13/2019 3:49:01 PM > OK 6/13/2019 3:49:01 PM > Reading EFS...6/13/2019 3:49:01 PM > OK 6/13/2019 3:49:01 PM > Reading Provisioning Items...6/13/2019 3:49:11 PM > OK 6/13/2019 3:49:11 PM > Reading QCN done! 6/13/2019 3:49:11 PM > Backup saved to "M257_355574082811063_13-06-2019_15-42-43.qcn" 6/13/2019 3:49:11 PM > Switching to Download mode...6/13/2019 3:49:36 PM > OK 6/13/2019 3:49:36 PM > Initializing flash...6/13/2019 3:49:38 PM > OK 6/13/2019 3:49:38 PM > Reading partitions...6/13/2019 3:49:38 PM > OK 6/13/2019 3:49:38 PM > Detecting writing method... 6/13/2019 3:49:39 PM > LAF Error: 80000121. 6/13/2019 3:49:39 PM > Trying second method... 6/13/2019 3:49:39 PM > Trying third method... 6/13/2019 3:49:39 PM > Eroor: Reading at first PARTITION block6/13/2019 3:49:39 PM > Failed! 6/13/2019 3:49:39 PM > Reading security area...6/13/2019 3:49:39 PM > Failed! 6/13/2019 3:49:39 PM > LAF Error: 80000119. 6/13/2019 3:49:39 PM > Writing security area...6/13/2019 3:49:51 PM > OK 6/13/2019 3:49:51 PM > Switching to Normal mode... 6/13/2019 3:50:28 PM > Found model LGM255AT* ÿh at port COM47 6/13/2019 3:50:28 PM > Send SPC...6/13/2019 3:50:28 PM > OK 6/13/2019 3:50:28 PM > Writing QCN... 6/13/2019 3:50:28 PM > Writing NV_Numbered Items...6/13/2019 3:50:48 PM > OK 6/13/2019 3:50:48 PM > Writing NV_Numbered SIM1 Items...6/13/2019 3:51:21 PM > OK 6/13/2019 3:51:21 PM > Writing NV_Numbered SIM2 Items...6/13/2019 3:51:56 PM > OK 6/13/2019 3:51:56 PM > Writing QCN done! 6/13/2019 3:51:56 PM > Phone successfully unlocked! 6/13/2019 3:51:56 PM > Rebooting phone... 6/13/2019 3:51:56 PM > Performed by 2.9.5 Software version. 6/13/2019 3:51:56 PM > Elapsed Time: 12:09:21 AM :):):)THANKS TO OCTOPLUS TEAM::):):) |
Please, post here full Software log of perfomed operation |
i unlocked one but NO SERVICE...please help |
another lg k20 m25510q 7.0 without root: Welcome to Octoplus/Octopus Box LG Software version 2.9.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: Selected model: M255 Reading info... Could not detect mode! Performed by 2.9.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM257 Selected model: M255 Reading info... Model ID: LG-M255 IMEI: 355574-08-289507-4 Android version: 7.0 Battery level: 100% Mode: Normal Firmware compiled date: Apr 17 2017 Firmware compiled time: 03:00:00 Firmware released date: Dec 6 2017 Firmware released time: 13:00:09 SW Version: MPSS.JO.2.0.c1.2-00029-8937_GENNS_PACK-1 IMEI: 355574-08-289507-4 Bluetooth address: 00:3D:E8:4B:52:04 Wi-Fi MAC address: 00:3D:E8:C9:18:90 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "M255_355574082895074_15-10-2019_16-22- 55.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "M255_355574082895074_15-10-2019_16-30- 24.SEC" Writing security area...OK Switching to Normal mode... Found model LGM255AT* ÿh at port COM257 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.9.6 Software version. |
