04-14-2021, 00:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: mexico
Member: 461616 Status: Offline Thanks Meter: 32 | Octoplus LG Connecting to server ...Failed! [Solved] Work ID: 0000000000DF8F1B Checking data...OK Platform: LG Qualcomm Selected port: COM432 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: xxxxxxxxxxxxxxxxx Android version: 8.1.0 Battery level: 45% Trying to enable Diagnostics ports... Found model LMX210CM: ÿh at port COM432 Reading info... Model ID: LM-X210CM IMEI: xxxxxxxxxxxxxxx Android version: 8.1.0 Battery level: 46% Mode: Normal Firmware compiled date: Jul 08 2019 Firmware compiled time: 22:00:00 Firmware released date: Aug 26 2019 Firmware released time: 15:30:51 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1.205920.1.212452.1 IMEI: xxxxxxxxxxxxxxxx Bluetooth address: 084:6A:84:9A:14 Wi-Fi MAC address: 38:30:F9:71:5E:2E SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Connecting to server 0...Failed!OK Connecting to server 1...Failed!OK Connecting to server 2...Failed!OK Connecting to server 3...Failed!OK Connecting to server 4...Failed!OK Performed by 3.1.1.03 Software version. Yesterday was working good, today i get this error... any solution? waiting answer, THKS B.R |
04-14-2021, 18:39 | #3 (permalink) | |
Member: 461616 Status: Offline Thanks Meter: 32 | Quote:
Checking data...OK Platform: LG Qualcomm Selected port: COM432 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: xxxxxxxxxxxxxxxx Android version: 8.1.0 Battery level: 49% Mode: Normal Firmware compiled date: Jul 08 2019 Firmware compiled time: 22:00:00 Firmware released date: Aug 26 2019 Firmware released time: 15:30:51 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1.205920.1.212452.1 IMEI: xxxxxxxxxxxxxxxxxxxxx Bluetooth address: 084:6A:84:9A:14 Wi-Fi MAC address: 38:30:F9:71:5E:2E SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: oct_m3RnMj6 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 790 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Reading security area... Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Reading security area... Connecting to phone...OK Initializing flash...OK Checking data... Connecting to phone...OK Initializing flash...OK Switching to Normal mode... Connecting to phone... Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Connecting to phone... Backup saved to "LMX210CM_3xxxxxxxxxx_14-04-2021_09-55-34.SEC" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210CM* ÿh at port COM432 Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: oct_m3RnMj6 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 3.1.1.03 Software version. for now, works fine sorr for the delay, its 10:30am right now... | |
The Following User Says Thank You to mast3r mms For This Useful Post: |
