08-31-2020, 15:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: montreal
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | prob frp lg h873 [Answered] Selected port: COM158 Selected model: H873 Reading info... Model ID: LG-H873 IMEI: 355469-08-731873-7 Android version: 9 Battery level: 39% Mode: Normal Performed by 3.0.2.03 Software version. Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM158 Selected model: H873 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H873 IMEI: 355469-08-731873-7 Android version: 9 Battery level: 39% Mode: Normal Switching to Download mode...OK Reading partitions... Initializing flash...OKOK Reading BOOT...Failed! LAF Error: 80000119. Trying second method... Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: oct_v2E5FgQ Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 300 credits. To perform "Reset FRP" operation you need to have 100 credits. Reading partitions...OK Checking partition...Failed! Error code: 120CASEDZ0 Performed by 3.0.2.03 Software version. |
08-31-2020, 15:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, try to repeat operation with latest test Software version 3.0.2.4, after post here full Software log |
08-31-2020, 18:10 | #3 (permalink) | |
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Quote:
Platform: LG Qualcomm Selected port: COM158 Selected model: H873 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H873 IMEI: 355469-08-731873-7 Android version: 9 Battery level: 51% Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH873AT-00-V30b-CAN-XX-SEP-17-2019-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: CH32S181106002507 IMEI: 355469-08-731873-7 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Reading BOOT...Failed! LAF Error: 80000119. Trying second method... Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: oct_v2E5FgQ Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 300 credits. To perform "Reset FRP" operation you need to have 100 credits. Reading partitions...OK Checking partition...Failed! Error code: 120CASEDZ0 Performed by 3.0.2.04 Software version. | |
09-01-2020, 14:34 | #5 (permalink) | |
H87315c_00_OPEN_CA_OP_1026.kdz H87315d_00_OPEN_CA_OP_1226.kdz H87320c_00_OPEN_CA_OP_0424.kdz H87320g_00_OPEN_CA_OP_0809.kdz H87320h_00_OPEN_CA_OP_1112.kdz which one i use I can't find v30 | |
09-01-2020, 14:51 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately, we don't have any other firmwares at the Support Area, if we'll manage to find new one, well add it into Support Area |
09-01-2020, 17:14 | #8 (permalink) | |
Checking data...OK Platform: LG Qualcomm Selected port: COM158 Selected model: H873 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H873 IMEI: 355469-08-731873-7 Android version: 9 Battery level: 45% Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH873AT-00-V30b-CAN-XX-SEP-17-2019-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: CH32S181106002507 IMEI: 355469-08-731873-7 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Reading BOOT...Failed! LAF Error: 80000119. Trying second method... Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: oct_v2E5FgQ Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 300 credits. To perform "Reset FRP" operation you need to have 100 credits. Reading partitions...OK Checking partition...Failed! Error code: 120CASEDZ0 Performed by 3.0.2.04 Software version. | |
09-02-2020, 15:54 | #10 (permalink) | |
01/09/2020 11:55:00 AM > Searching for server... 01/09/2020 11:55:00 AM > Trying to ping server...01/09/2020 11:55:00 AM > ok 01/09/2020 11:55:00 AM > Trying connect to server... 01/09/2020 11:55:01 AM > Searching installed cards... 01/09/2020 11:55:01 AM > Found card with s/n: 01007F83 01/09/2020 11:55:01 AM > Server check... 01/09/2020 11:55:01 AM > Server Check succesfull! 01/09/2020 11:55:01 AM > Server Check succesfull! 01/09/2020 11:55:03 AM > Welcome to Octoplus/Octopus Box LG Software version 3.0.2.04 01/09/2020 11:55:03 AM > Card S/N : 0001007F83 01/09/2020 11:55:10 AM > INI FUpdateInfo Done! 01/09/2020 11:55:10 AM > INI FShowUpdateInfo start 01/09/2020 11:55:10 AM > INI FShowInfo start 01/09/2020 11:56:47 AM > -------------------------------------------------------------------------------- 01/09/2020 11:56:47 AM > Platform: LG Qualcomm 01/09/2020 11:56:47 AM > Selected port: COM8 01/09/2020 11:56:47 AM > Selected model: H873 01/09/2020 11:56:47 AM > Reading info... 01/09/2020 11:57:02 AM > Could not detect mode! 01/09/2020 11:57:03 AM > Performed by 3.0.2.04 Software version. 01/09/2020 11:57:03 AM > Elapsed Time: 12:00:16 AM 01/09/2020 11:57:10 AM > -------------------------------------------------------------------------------- 01/09/2020 11:57:10 AM > Platform: LG Qualcomm 01/09/2020 11:57:10 AM > Selected port: COM158 01/09/2020 11:57:10 AM > Selected model: H873 01/09/2020 11:57:10 AM > Reading info... 01/09/2020 11:57:12 AM > Model ID: LG-H873 01/09/2020 11:57:12 AM > IMEI: 355469-08-731873-7 01/09/2020 11:57:12 AM > Android version: 9 01/09/2020 11:57:12 AM > Battery level: 45% 01/09/2020 11:57:12 AM > Mode: Emergency 01/09/2020 11:57:12 AM > Initializing flash...01/09/2020 11:57:14 AM > OK 01/09/2020 11:57:15 AM > Platform: msm8996 01/09/2020 11:57:15 AM > SW version: 01/09/2020 11:57:15 AM > LGH873AT-00-V30b-CAN-XX-SEP-17-2019-ARB00+0 01/09/2020 11:57:15 AM > Android version: 9 01/09/2020 11:57:15 AM > LAF Version: 1.1 01/09/2020 11:57:15 AM > Product ID: CH32S181106002507 01/09/2020 11:57:15 AM > IMEI: 355469-08-731873-7 01/09/2020 11:57:15 AM > Target operator: GLOBAL 01/09/2020 11:57:15 AM > Hardware: rev_10 01/09/2020 11:57:15 AM > Performed by 3.0.2.04 Software version. 01/09/2020 11:57:15 AM > Elapsed Time: 12:00:06 AM 01/09/2020 11:57:28 AM > -------------------------------------------------------------------------------- 01/09/2020 11:57:28 AM > Checking data...01/09/2020 11:57:29 AM > OK 01/09/2020 11:57:29 AM > Platform: LG Qualcomm 01/09/2020 11:57:29 AM > Selected port: COM158 01/09/2020 11:57:29 AM > Selected model: H873 01/09/2020 11:57:29 AM > Reading info... 01/09/2020 11:57:30 AM > Model ID: LG-H873 01/09/2020 11:57:30 AM > IMEI: 355469-08-731873-7 01/09/2020 11:57:30 AM > Android version: 9 01/09/2020 11:57:30 AM > Battery level: 45% 01/09/2020 11:57:31 AM > Mode: Emergency 01/09/2020 11:57:31 AM > Initializing flash...01/09/2020 11:57:33 AM > OK 01/09/2020 11:57:34 AM > Platform: msm8996 01/09/2020 11:57:34 AM > SW version: 01/09/2020 11:57:34 AM > LGH873AT-00-V30b-CAN-XX-SEP-17-2019-ARB00+0 01/09/2020 11:57:34 AM > Android version: 9 01/09/2020 11:57:34 AM > LAF Version: 1.1 01/09/2020 11:57:34 AM > Product ID: CH32S181106002507 01/09/2020 11:57:34 AM > IMEI: 355469-08-731873-7 01/09/2020 11:57:34 AM > Target operator: GLOBAL 01/09/2020 11:57:34 AM > Hardware: rev_10 01/09/2020 11:57:34 AM > Opening "H87330b_00_OPEN_CA_OP_0917.kdz"...01/09/2020 11:57:34 AM > OK 01/09/2020 11:57:34 AM > Firmware version: LGH873AT-00-V30b-GLOBAL-CA-SEP-17-2019-ARB00+0 01/09/2020 11:57:34 AM > Firmware model: LG-H873 01/09/2020 11:57:34 AM > Firmware type: 0100 01/09/2020 11:57:34 AM > -------------------------------------------------------------------------------- 01/09/2020 11:57:34 AM > Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! 01/09/2020 11:57:34 AM > -------------------------------------------------------------------------------- 01/09/2020 11:57:44 AM > Prepairing firmware...01/09/2020 11:57:44 AM > OK 01/09/2020 11:57:44 AM > Selecting firmware partitions...01/09/2020 11:57:50 AM > OK 01/09/2020 11:57:50 AM > Selected default partitions! 01/09/2020 11:57:50 AM > Sending signature...01/09/2020 11:57:51 AM > OK 01/09/2020 11:57:51 AM > Setting options...01/09/2020 11:57:53 AM > OK 01/09/2020 11:57:53 AM > Do you want to format User Data? 01/09/2020 11:57:58 AM > Reading partitions...01/09/2020 11:58:03 AM > OK 01/09/2020 11:58:03 AM > Formating USERDATA...01/09/2020 11:58:08 AM > OK 01/09/2020 11:58:08 AM > Formating ENCRYPT...01/09/2020 11:58:12 AM > OK 01/09/2020 11:58:12 AM > Writing 1/131 gpt_main0.bin_0...01/09/2020 11:58:12 AM > OK 01/09/2020 11:58:12 AM > Writing 2/131 laf.img_6...01/09/2020 11:58:14 AM > OK 01/09/2020 11:58:14 AM > Writing 3/131 laf.img_12294...01/09/2020 11:58:16 AM > OK 01/09/2020 11:58:16 AM > Writing 4/131 misc.img_36870...01/09/2020 11:58:16 AM > Skipped! 01/09/2020 11:58:16 AM > Writing 5/131 factory_ramdisk.img_45062...01/09/2020 11:58:16 AM > OK 01/09/2020 11:58:16 AM > Writing 6/131 rct.img_62214...01/09/2020 11:58:16 AM > Skipped! 01/09/2020 11:58:16 AM > Writing 7/131 persist.img_62598...01/09/2020 11:58:17 AM > OK 01/09/2020 11:58:17 AM > Writing 8/131 system_1.img_70790...01/09/2020 11:58:23 AM > OK 01/09/2020 11:58:23 AM > Writing 9/131 system_2.img_103903...01/09/2020 11:58:23 AM > OK 01/09/2020 11:58:23 AM > Writing 10/131 system_3.img_104418...01/09/2020 11:58:30 AM > OK 01/09/2020 11:58:30 AM > Writing 11/131 system_4.img_136841...01/09/2020 11:58:37 AM > OK 01/09/2020 11:58:37 AM > Writing 12/131 system_5.img_169439...01/09/2020 11:58:37 AM > OK 01/09/2020 11:58:37 AM > Writing 13/131 system_6.img_169954...01/09/2020 11:58:43 AM > OK 01/09/2020 11:58:43 AM > Writing 14/131 system_7.img_202377...01/09/2020 11:58:49 AM > OK 01/09/2020 11:58:49 AM > Writing 15/131 system_8.img_234975...01/09/2020 11:58:49 AM > OK 01/09/2020 11:58:49 AM > Writing 16/131 system_9.img_235490...01/09/2020 11:58:56 AM > OK 01/09/2020 11:58:56 AM > Writing 17/131 system_10.img_267913...01/09/2020 11:59:02 AM > OK 01/09/2020 11:59:02 AM > Writing 18/131 system_11.img_300511...01/09/2020 11:59:02 AM > OK 01/09/2020 11:59:02 AM > Writing 19/131 system_12.img_301026...01/09/2020 11:59:09 AM > OK 01/09/2020 11:59:09 AM > Writing 20/131 system_13.img_333449...01/09/2020 11:59:14 AM > OK 01/09/2020 11:59:14 AM > Writing 21/131 system_14.img_366047...01/09/2020 11:59:15 AM > OK 01/09/2020 11:59:15 AM > Writing 22/131 system_15.img_366562...01/09/2020 11:59:19 AM > OK 01/09/2020 11:59:19 AM > Writing 23/131 system_16.img_398985...01/09/2020 11:59:24 AM > OK 01/09/2020 11:59:24 AM > Writing 24/131 system_17.img_431753...01/09/2020 11:59:29 AM > OK 01/09/2020 11:59:29 AM > Writing 25/131 system_18.img_464521...01/09/2020 11:59:34 AM > OK 01/09/2020 11:59:34 AM > Writing 26/131 system_19.img_497289...01/09/2020 11:59:38 AM > OK 01/09/2020 11:59:38 AM > Writing 27/131 system_20.img_530057...01/09/2020 11:59:42 AM > OK 01/09/2020 11:59:42 AM > Writing 28/131 system_21.img_562825...01/09/2020 11:59:46 AM > OK 01/09/2020 11:59:46 AM > Writing 29/131 system_22.img_595593...01/09/2020 11:59:50 AM > OK 01/09/2020 11:59:50 AM > Writing 30/131 system_23.img_628361...01/09/2020 11:59:56 AM > OK 01/09/2020 11:59:56 AM > Writing 31/131 system_24.img_661129...01/09/2020 12:00:01 PM > OK 01/09/2020 12:00:01 PM > Writing 32/131 system_25.img_693897...01/09/2020 12:00:06 PM > OK 01/09/2020 12:00:06 PM > Writing 33/131 system_26.img_726665...01/09/2020 12:00:12 PM > OK 01/09/2020 12:00:12 PM > Writing 34/131 system_27.img_759433...01/09/2020 12:00:18 PM > OK 01/09/2020 12:00:18 PM > Writing 35/131 system_28.img_792201...01/09/2020 12:00:24 PM > OK 01/09/2020 12:00:24 PM > Writing 36/131 system_29.img_824969...01/09/2020 12:00:30 PM > OK 01/09/2020 12:00:30 PM > Writing 37/131 system_30.img_857737...01/09/2020 12:00:37 PM > OK 01/09/2020 12:00:37 PM > Writing 38/131 system_31.img_890335...01/09/2020 12:00:37 PM > OK 01/09/2020 12:00:37 PM > Writing 39/131 system_32.img_890850...01/09/2020 12:00:42 PM > OK 01/09/2020 12:00:42 PM > Writing 40/131 system_33.img_923273...01/09/2020 12:00:49 PM > OK 01/09/2020 12:00:49 PM > Writing 41/131 system_34.img_955871...01/09/2020 12:00:49 PM > OK 01/09/2020 12:00:49 PM > Writing 42/131 system_35.img_956386...01/09/2020 12:00:55 PM > OK 01/09/2020 12:00:55 PM > Writing 43/131 system_36.img_988809...01/09/2020 12:01:00 PM > OK 01/09/2020 12:01:01 PM > Writing 44/131 system_37.img_1021577...01/09/2020 12:01:06 PM > OK 01/09/2020 12:01:06 PM > Writing 45/131 system_38.img_1054345...01/09/2020 12:01:12 PM > OK 01/09/2020 12:01:12 PM > Writing 46/131 system_39.img_1087113...01/09/2020 12:01:17 PM > OK 01/09/2020 12:01:17 PM > Writing 47/131 system_40.img_1119881...01/09/2020 12:01:23 PM > OK 01/09/2020 12:01:23 PM > Writing 48/131 system_41.img_1152649...01/09/2020 12:01:28 PM > OK 01/09/2020 12:01:28 PM > Writing 49/131 system_42.img_1185417...01/09/2020 12:01:29 PM > OK 01/09/2020 12:01:29 PM > Writing 50/131 system_43.img_1447046...01/09/2020 12:01:29 PM > OK 01/09/2020 12:01:29 PM > Writing 51/131 system_44.img_1480007...01/09/2020 12:01:34 PM > OK 01/09/2020 12:01:34 PM > Writing 52/131 cache_1.img_1502342...01/09/2020 12:01:34 PM > OK 01/09/2020 12:01:34 PM > Writing 53/131 cache_2.img_1502889...01/09/2020 12:01:35 PM > OK 01/09/2020 12:01:35 PM > Writing 54/131 cache_3.img_1535110...01/09/2020 12:01:35 PM > OK 01/09/2020 12:01:35 PM > Writing 55/131 cache_4.img_1535143...01/09/2020 12:01:35 PM > OK 01/09/2020 12:01:35 PM > Writing 56/131 cache_5.img_1567878...01/09/2020 12:01:35 PM > OK 01/09/2020 12:01:35 PM > Writing 57/131 cache_6.img_1568392...01/09/2020 12:01:35 PM > OK 01/09/2020 12:01:35 PM > Writing 58/131 cache_7.img_1600646...01/09/2020 12:01:35 PM > OK 01/09/2020 12:01:35 PM > Writing 59/131 cache_8.img_1600679...01/09/2020 12:01:36 PM > OK 01/09/2020 12:01:36 PM > Writing 60/131 OP_OPEN_CA.img_1633414...01/09/2020 12:01:52 PM > OK 01/09/2020 12:01:52 PM > Writing 61/131 OP_OPEN_CA.img_1698950...01/09/2020 12:01:56 PM > OK 01/09/2020 12:01:56 PM > Writing 62/131 userdata_1.img_2105222...01/09/2020 12:01:57 PM > OK 01/09/2020 12:01:57 PM > Writing 63/131 userdata_2.img_2106760...01/09/2020 12:01:57 PM > OK 01/09/2020 12:01:57 PM > Writing 64/131 userdata_3.img_2137990...01/09/2020 12:01:57 PM > OK 01/09/2020 12:01:57 PM > Writing 65/131 userdata_4.img_2139015...01/09/2020 12:01:57 PM > OK 01/09/2020 12:01:57 PM > Writing 66/131 userdata_5.img_2203526...01/09/2020 12:01:57 PM > OK 01/09/2020 12:01:57 PM > Writing 67/131 userdata_6.img_2204551...01/09/2020 12:01:57 PM > OK 01/09/2020 12:01:57 PM > Writing 68/131 userdata_7.img_2269062...01/09/2020 12:01:58 PM > OK 01/09/2020 12:01:58 PM > Writing 69/131 userdata_8.img_2270087...01/09/2020 12:01:58 PM > OK 01/09/2020 12:01:58 PM > Writing 70/131 userdata_9.img_2334598...01/09/2020 12:01:58 PM > OK 01/09/2020 12:01:58 PM > Writing 71/131 userdata_10.img_2335623...01/09/2020 12:01:58 PM > OK 01/09/2020 12:01:58 PM > Writing 72/131 userdata_11.img_2400134...01/09/2020 12:01:58 PM > OK 01/09/2020 12:01:58 PM > Writing 73/131 userdata_12.img_2401159...01/09/2020 12:01:58 PM > OK 01/09/2020 12:01:58 PM > Writing 74/131 userdata_13.img_2924422...01/09/2020 12:01:59 PM > OK 01/09/2020 12:01:59 PM > Writing 75/131 userdata_14.img_2925447...01/09/2020 12:01:59 PM > OK 01/09/2020 12:01:59 PM > Writing 76/131 userdata_15.img_2989958...01/09/2020 12:01:59 PM > OK 01/09/2020 12:01:59 PM > Writing 77/131 userdata_16.img_2990983...01/09/2020 12:01:59 PM > OK 01/09/2020 12:01:59 PM > Writing 78/131 userdata_17.img_3710854...01/09/2020 12:01:59 PM > OK 01/09/2020 12:01:59 PM > Writing 79/131 userdata_18.img_3711879...01/09/2020 12:01:59 PM > OK 01/09/2020 12:02:00 PM > Writing 80/131 userdata_19.img_4759430...01/09/2020 12:02:00 PM > OK 01/09/2020 12:02:00 PM > Writing 81/131 userdata_20.img_4760455...01/09/2020 12:02:00 PM > OK 01/09/2020 12:02:00 PM > Writing 82/131 userdata_21.img_4857734...01/09/2020 12:02:00 PM > OK 01/09/2020 12:02:00 PM > Writing 83/131 userdata_22.img_4858247...01/09/2020 12:02:00 PM > OK 01/09/2020 12:02:00 PM > Writing 84/131 userdata_23.img_4890502...01/09/2020 12:02:00 PM > OK 01/09/2020 12:02:00 PM > Writing 85/131 userdata_24.img_6201222...01/09/2020 12:02:01 PM > OK 01/09/2020 12:02:01 PM > Writing 86/131 userdata_25.img_6202247...01/09/2020 12:02:01 PM > OK 01/09/2020 12:02:01 PM > Writing 87/131 userdata_26.img_7708550...01/09/2020 12:02:01 PM > OK 01/09/2020 12:02:01 PM > Writing 88/131 gpt_backup0.bin_7728123...01/09/2020 12:02:01 PM > OK 01/09/2020 12:02:01 PM > Writing 89/131 gpt_main1.bin_0...01/09/2020 12:02:03 PM > OK 01/09/2020 12:02:03 PM > Writing 90/131 xbl.elf_6...01/09/2020 12:02:03 PM > OK 01/09/2020 12:02:03 PM > Writing 91/131 xbl.elf_774...01/09/2020 12:02:03 PM > OK 01/09/2020 12:02:03 PM > Writing 92/131 gpt_backup1.bin_8187...01/09/2020 12:02:03 PM > OK 01/09/2020 12:02:03 PM > Writing 93/131 gpt_main2.bin_0...01/09/2020 12:02:05 PM > OK 01/09/2020 12:02:05 PM > Writing 94/131 xbl2.elf_6...01/09/2020 12:02:05 PM > OK 01/09/2020 12:02:05 PM > Writing 95/131 xbl2.elf_774...01/09/2020 12:02:05 PM > OK 01/09/2020 12:02:05 PM > Writing 96/131 gpt_backup2.bin_2043...01/09/2020 12:02:05 PM > OK 01/09/2020 12:02:05 PM > Writing 97/131 gpt_main3.bin_0...01/09/2020 12:02:07 PM > OK 01/09/2020 12:02:07 PM > Writing 98/131 gpt_backup3.bin_2043...01/09/2020 12:02:07 PM > OK 01/09/2020 12:02:07 PM > Writing 99/131 gpt_main4.bin_0...01/09/2020 12:02:08 PM > OK 01/09/2020 12:02:08 PM > Writing 100/131 boot.img_6...01/09/2020 12:02:09 PM > OK 01/09/2020 12:02:09 PM > Writing 101/131 recovery.img_10246...01/09/2020 12:02:11 PM > OK 01/09/2020 12:02:11 PM > Writing 102/131 recovery.img_20614...01/09/2020 12:02:13 PM > OK 01/09/2020 12:02:13 PM > Writing 103/131 tz.mbn_30982...01/09/2020 12:02:13 PM > OK 01/09/2020 12:02:13 PM > Writing 104/131 tz.mbn_31494...01/09/2020 12:02:13 PM > OK 01/09/2020 12:02:13 PM > Writing 105/131 emmc_appsboot.mbn_32006...01/09/2020 12:02:13 PM > OK 01/09/2020 12:02:13 PM > Writing 106/131 emmc_appsboot.mbn_32518...01/09/2020 12:02:14 PM > OK 01/09/2020 12:02:14 PM > Writing 107/131 raw_resources.img_33030...01/09/2020 12:02:14 PM > OK 01/09/2020 12:02:14 PM > Writing 108/131 raw_resources.img_34054...01/09/2020 12:02:14 PM > OK 01/09/2020 12:02:14 PM > Writing 109/131 rpm.mbn_35078...01/09/2020 12:02:14 PM > OK 01/09/2020 12:02:14 PM > Writing 110/131 rpm.mbn_35206...01/09/2020 12:02:14 PM > OK 01/09/2020 12:02:14 PM > Writing 111/131 hyp.mbn_35334...01/09/2020 12:02:15 PM > OK 01/09/2020 12:02:15 PM > Writing 112/131 hyp.mbn_35462...01/09/2020 12:02:15 PM > OK 01/09/2020 12:02:15 PM > Writing 113/131 pmic.elf_35590...01/09/2020 12:02:15 PM > OK 01/09/2020 12:02:15 PM > Writing 114/131 pmic.elf_35718...01/09/2020 12:02:15 PM > OK 01/09/2020 12:02:15 PM > Writing 115/131 devcfg.mbn_35846...01/09/2020 12:02:15 PM > OK 01/09/2020 12:02:15 PM > Writing 116/131 devcfg.mbn_35878...01/09/2020 12:02:15 PM > OK 01/09/2020 12:02:15 PM > Writing 117/131 NON-HLOS.bin_35910...01/09/2020 12:02:18 PM > OK 01/09/2020 12:02:18 PM > Writing 118/131 sec.dat_57926...01/09/2020 12:02:18 PM > OK 01/09/2020 12:02:19 PM > Writing 119/131 keymaster.mbn_58054...01/09/2020 12:02:19 PM > OK 01/09/2020 12:02:19 PM > Writing 120/131 keymaster.mbn_58182...01/09/2020 12:02:19 PM > OK 01/09/2020 12:02:19 PM > Writing 121/131 cmnlib.mbn_58310...01/09/2020 12:02:19 PM > OK 01/09/2020 12:02:19 PM > Writing 122/131 cmnlib.mbn_58438...01/09/2020 12:02:19 PM > OK 01/09/2020 12:02:19 PM > Writing 123/131 cmnlib64.mbn_58566...01/09/2020 12:02:19 PM > OK 01/09/2020 12:02:19 PM > Writing 124/131 cmnlib64.mbn_58694...01/09/2020 12:02:20 PM > OK 01/09/2020 12:02:20 PM > Writing 125/131 dp_AP_signed.mbn_58822...01/09/2020 12:02:20 PM > OK 01/09/2020 12:02:20 PM > Writing 126/131 dp_MSA_signed.mbn_58950...01/09/2020 12:02:20 PM > OK 01/09/2020 12:02:20 PM > Writing 127/131 gpt_backup4.bin_59387...01/09/2020 12:02:20 PM > OK 01/09/2020 12:02:20 PM > Writing 128/131 gpt_main5.bin_0...01/09/2020 12:02:22 PM > OK 01/09/2020 12:02:22 PM > Writing 129/131 gpt_backup5.bin_2043...01/09/2020 12:02:22 PM > OK 01/09/2020 12:02:22 PM > Writing 130/131 gpt_main6.bin_0...01/09/2020 12:02:22 PM > Skipped! 01/09/2020 12:02:22 PM > Writing 131/131 gpt_backup6.bin_2043...01/09/2020 12:02:22 PM > Skipped! 01/09/2020 12:02:22 PM > Reading partitions...01/09/2020 12:02:26 PM > OK 01/09/2020 12:02:26 PM > Formating RCT...01/09/2020 12:02:31 PM > OK 01/09/2020 12:02:31 PM > Formating MPT...01/09/2020 12:02:35 PM > OK 01/09/2020 12:02:35 PM > Finalizing...01/09/2020 12:02:37 PM > OK 01/09/2020 12:02:37 PM > Writing firmware done! 01/09/2020 12:02:37 PM > Performed by 3.0.2.04 Software version. 01/09/2020 12:02:37 PM > Elapsed Time: 12:05:10 AM 01/09/2020 12:09:10 PM > Please, select Reset FRP Method! 01/09/2020 12:09:12 PM > -------------------------------------------------------------------------------- 01/09/2020 12:09:12 PM > Checking data...01/09/2020 12:09:13 PM > OK 01/09/2020 12:09:13 PM > Platform: LG Qualcomm 01/09/2020 12:09:13 PM > Selected port: COM158 01/09/2020 12:09:13 PM > Selected model: H873 01/09/2020 12:09:13 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 01/09/2020 12:09:13 PM > Reading info... 01/09/2020 12:09:15 PM > Model ID: LG-H873 01/09/2020 12:09:15 PM > IMEI: 355469-08-731873-7 01/09/2020 12:09:15 PM > Android version: 9 01/09/2020 12:09:15 PM > Battery level: 44% 01/09/2020 12:09:24 PM > Mode: Normal 01/09/2020 12:09:24 PM > Switching to Download mode...01/09/2020 12:09:49 PM > OK 01/09/2020 12:09:49 PM > Reading partitions... 01/09/2020 12:09:49 PM > Initializing flash...01/09/2020 12:09:51 PM > OK01/09/2020 12:09:57 PM > OK 01/09/2020 12:09:57 PM > Reading BOOT...01/09/2020 12:09:58 PM > Failed! 01/09/2020 12:09:58 PM > LAF Error: 80000119. 01/09/2020 12:09:58 PM > Trying second method... 01/09/2020 12:09:58 PM > Connecting to server...01/09/2020 12:09:59 PM > OK 01/09/2020 12:09:59 PM > Octopus smart card is present. 01/09/2020 12:09:59 PM > Checking smart card...01/09/2020 12:10:05 PM > OK 01/09/2020 12:10:05 PM > Username: oct_v2E5FgQ 01/09/2020 12:10:05 PM > Authorizing...01/09/2020 12:10:07 PM > Failed! 01/09/2020 12:10:07 PM > Login error: Wrong password! 01/09/2020 12:10:07 PM > Performed by 3.0.2.04 Software version. 01/09/2020 12:10:07 PM > Elapsed Time: 12:00:58 AM 01/09/2020 12:10:12 PM > -------------------------------------------------------------------------------- 01/09/2020 12:10:12 PM > Connecting to server ...01/09/2020 12:10:14 PM > OK 01/09/2020 12:10:14 PM > Username: oct_v2E5FgQ 01/09/2020 12:10:14 PM > Authorizing...01/09/2020 12:10:15 PM > Failed! 01/09/2020 12:10:15 PM > Login error: Wrong password! 01/09/2020 12:10:47 PM > -------------------------------------------------------------------------------- 01/09/2020 12:10:47 PM > Connecting to server ...01/09/2020 12:10:48 PM > OK 01/09/2020 12:10:48 PM > Username: oct_v2E5FgQ 01/09/2020 12:10:48 PM > Authorizing...01/09/2020 12:10:50 PM > OK 01/09/2020 12:10:50 PM > Checking balance...01/09/2020 12:10:52 PM > OK 01/09/2020 12:10:52 PM > Your balance: 300 credits. 01/09/2020 12:11:02 PM > Please, select Reset FRP Method! 01/09/2020 12:11:05 PM > -------------------------------------------------------------------------------- 01/09/2020 12:11:05 PM > Checking data...01/09/2020 12:11:06 PM > OK 01/09/2020 12:11:06 PM > Platform: LG Qualcomm 01/09/2020 12:11:06 PM > Selected port: COM158 01/09/2020 12:11:06 PM > Selected model: H873 01/09/2020 12:11:06 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 01/09/2020 12:11:06 PM > Reading info... 01/09/2020 12:11:07 PM > Model ID: LG-H873 01/09/2020 12:11:07 PM > IMEI: 355469-08-731873-7 01/09/2020 12:11:07 PM > Android version: 9 01/09/2020 12:11:07 PM > Battery level: 45% 01/09/2020 12:11:08 PM > Mode: Emergency 01/09/2020 12:11:08 PM > Initializing flash...01/09/2020 12:11:10 PM > OK 01/09/2020 12:11:11 PM > Platform: msm8996 01/09/2020 12:11:11 PM > SW version: 01/09/2020 12:11:11 PM > LGH873AT-00-V30b-CAN-XX-SEP-17-2019-ARB00+0 01/09/2020 12:11:11 PM > Android version: 9 01/09/2020 12:11:11 PM > LAF Version: 1.1 01/09/2020 12:11:11 PM > Product ID: CH32S181106002507 01/09/2020 12:11:11 PM > IMEI: 355469-08-731873-7 01/09/2020 12:11:11 PM > Target operator: GLOBAL 01/09/2020 12:11:11 PM > Hardware: rev_10 01/09/2020 12:11:11 PM > Reading partitions...01/09/2020 12:11:16 PM > OK 01/09/2020 12:11:16 PM > Reading BOOT...01/09/2020 12:11:17 PM > Failed! 01/09/2020 12:11:17 PM > LAF Error: 80000119. 01/09/2020 12:11:17 PM > Trying second method... 01/09/2020 12:11:17 PM > Connecting to server...01/09/2020 12:11:19 PM > OK 01/09/2020 12:11:19 PM > Octopus smart card is present. 01/09/2020 12:11:19 PM > Checking smart card...01/09/2020 12:11:24 PM > OK 01/09/2020 12:11:24 PM > Username: oct_v2E5FgQ 01/09/2020 12:11:24 PM > Authorizing...01/09/2020 12:11:26 PM > OK 01/09/2020 12:11:26 PM > Checking balance...01/09/2020 12:11:28 PM > OK 01/09/2020 12:11:28 PM > Checking operation...01/09/2020 12:11:31 PM > OK 01/09/2020 12:11:31 PM > Sending device information...01/09/2020 12:11:33 PM > OK 01/09/2020 12:11:33 PM > Get credits, needed for current operation...01/09/2020 12:11:34 PM > OK 01/09/2020 12:11:34 PM > Your balance: 300 credits. 01/09/2020 12:11:34 PM > To perform "Reset FRP" operation you need to have 100 credits. 01/09/2020 12:12:05 PM > Reading partitions...01/09/2020 12:12:10 PM > OK 01/09/2020 12:12:10 PM > Checking partition...01/09/2020 12:12:10 PM > Failed! 01/09/2020 12:12:10 PM > Error code: 120CASEDZ0 01/09/2020 12:12:10 PM > Performed by 3.0.2.04 Software version. 01/09/2020 12:12:11 PM > Elapsed Time: 12:01:09 AM | |
