03-15-2022, 22:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Q730TM IMEI Repair issue [Solved] Card S/N : 000106AC6D -------------------------------------------------------------------------------- Connecting to server 0...OK Username: OCTOPUS1500CR Authorizing...OK Checking balance...OK Your balance: 400 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000183A3EE Checking data...OK Platform: LG MTK Selected port: COM6 Selected baudrate: 921600 Selected model: Q730TM Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM40 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730TM9AT-00-V10q-310-240-DEC-21-2020-ARB00+0 LAF Version: 1.1 Product ID: LS01S200915001668 IMEI: 354590-11-xxxxx-x Target operator: LAO Hardware: rev_11 Battery level: 68% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-xxxx-x Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: OCTOPUS1500CR Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 400 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM40 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM59 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .13014E47.314A3950.38100973.1B2787CD eMMC flash chip: Unknown: G1J9P8 Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q730TM_35459011xxxxxx_15-03-2022_16-05-17.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! New IMEI A: 354660-11-xxxxx-x Finalizing... Rebooting phone... IMEI successfully fixed! Performed by 3.1.7 Software version. Attention support: The problem is for Boost phone of this model, LG Modem and Serial Port do not appear when phone is in File Transfer mode. For LG Model and Serial Port, must put phone DIAG mode (##3424#). But for this, ask SPC, so cannot do if SPC is not known. For this unlock, I know LG Modem port also show while in download mode (Firmware Update) so I put device to Firmware Update and modem port show and process continue and take credits but not perform IMEI repair truly, as log say. So need refund credits and need method to read SPC for this model, for enable LG Modem port when phone is power ON. (Or maybe some other way to enter DIAG mode) Thank you |
03-16-2022, 16:39 | #3 (permalink) |
Member: 1815016 Status: Offline Thanks Meter: 77 | That was first thing I tried, because I know 000000 is now default code on Samsung and maybe some others, since several years now. But phone said "code incorrect". So need new way to read SPC on Sprint/Boost Stylo 6 |
