01-09-2022, 23:45 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Q730TM Unlock Question [Answered] Work ID: 0000000002170433 Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: Q730TM Connecting to phone... Phone found at port COM3 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730TM9AT-00-V10x-310-240-OCT-01-2021- ARB00+1 LAF Version: 1.1 Product ID: LS01S200914000854 IMEI: 354590-11-27xxxxx Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-279533-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM3 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM5 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .13014E47.314A3950.381008C0.972E77B3 eMMC flash chip: Unknown: G1J9P8 Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q730TM_3545901127xxxxx_09-01-2022_14- 23-39.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! New IMEI A: 354527-11-43xxxx Finalizing... Performed by 3.1.6 Software version. -- Selected USB connection type Work ID: 0000000002170552 Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: Q730TM Connecting to phone... Phone found at port COM3 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730TM9AT-00-V10x-310-240-OCT-01-2021- ARB00+1 LAF Version: 1.1 Product ID: LS01S200914000854 IMEI: 354590-11-27xxxxx Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-279533-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM3 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM5 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .13014E47.314A3950.381008C0.972E77B3 eMMC flash chip: Unknown: G1J9P8 Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q730TM_3545901127xxxxx_09-01-2022_14- 40-20.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! Performed by 3.1.6 Software version. -------------------------------------------------------------------------------- Last edited by Octopus support; 01-10-2022 at 08:45. |
01-10-2022, 08:46 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. We added your one more attempt. Please, download and install latest test Software v. 3.1.6.02 from Support Area (Path:/SOFTWARE/Octoplus LG/TEST SOFTWARE/install_octoplus_octopus_LG_3.1.6.02.exe) Then repeat operation once again and post here results. We will check it. Note: Read attentive Software instructions. Quote:
01-10-2022, 19:23 | #3 (permalink) |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Welcome to Octoplus/Octopus Box LG Software version 3.1.6.02 Card S/N : 0000098F7F -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000218085B Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: Q730TM Connecting to phone... Phone found at port COM3 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730TM9AT-00-V10x-310-240-OCT-01-2021- ARB00+1 LAF Version: 1.1 Product ID: LS01S200914000854 IMEI: 354590-11-27xxxxx Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-27xxxxx Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM3 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM5 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .13014E47.314A3950.381008C0.972E77B3 eMMC flash chip: Unknown: G1J9P8 Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q730TM_3545901127xxxxx_10-01-2022_12- 17-22.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! Performed by 3.1.6.02 Software version. Last edited by Octopus support; 01-11-2022 at 08:44. |
01-11-2022, 08:43 | #5 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | We added your one more attempt. Please, read attentive Software instruction and repeat operation once again.
01-11-2022, 12:41 | #6 (permalink) | |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Quote:
