12-02-2022, 11:27 | #1 (permalink) |
Freak Poster Join Date: Oct 2009 Location: indonesia
Member: 1150705 Status: Offline Thanks Meter: 11 | repair imei failed Lm-V510N [Answered] Card S/N : 000204977A -------------------------------------------------------------------------------- Work ID: 0000000001BFA8AC Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 56% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 353238-10-712506-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Work ID: 000000000192BC05 Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 57% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 353238-10-712506-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001BFA98A Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 58% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 353238-10-712506-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Work ID: 000000000192BCC0 Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 58% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 353238-10-712506-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Work ID: 000000000192BD28 Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 59% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 353238-10-712506-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001BFAA63 Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 60% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 353238-10-712506-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 60% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Performed by 3.2.0 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001BFAA87 Checking data...OK Platform: LG Qualcomm Selected port: COM123 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM123 Model ID: LM-V510N IMEI: 358655-10-436526-6 Android version: 9 Battery level: 60% Mode: Normal Firmware compiled date: Nov 08 2019 Firmware compiled time: 05:00:00 Firmware released date: Jan 23 2020 Firmware released time: 11:08:17 SW Version: MPSS.HE.1.5.c4-00336-SM8150_GENFUSION_PACK- 1.221935.24 IMEI: 358655-10-436526-6 SPC: 000000 Fixing IMEI... New IMEI: 358655-10-436526-6 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.0 Software version. no pop up asking usb debugging permission i tired to reinstall driver still no working |
