06-08-2021, 19:01 | #1 (permalink) |
Major Poster Join Date: Apr 2017
Member: 2704016 Status: Offline Thanks Meter: 9 | Stylo 5 Reset FRP question [Answered] please refund. user: virtualvlep thanks in advance Welcome to Octoplus/Octopus Box LG Software version 3.1.1.03 -------------------------------------------------------------------------------- Work ID: 00000000011AADB9 Checking data...OK Platform: LG Qualcomm Selected port: COM119 Selected model: Q720MS Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q720MS IMEI: 356284-10-101120-3 Android version: 9 Battery level: 2% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ720MSAT-02-V20d-310-160-NOV-20-2020-ARB00+0 Android version: 10 LAF Version: 1.1 Product ID: CY71S190713002977 IMEI: 356284-10-101120-3 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is not present. Checking Activations...OK Username: virtualvlep Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Too low balance to provide the security operation! Your balance: 2 credits. To perform "Reset FRP" operation you need to have 100 credits. Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- Work ID: 00000000011AADF2 Checking data...OK Platform: LG Qualcomm Selected port: COM119 Selected model: Q720MS Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q720MS IMEI: 356284-10-101120-3 Android version: 9 Battery level: 2% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ720MSAT-02-V20d-310-160-NOV-20-2020-ARB00+0 Android version: 10 LAF Version: 1.1 Product ID: CY71S190713002977 IMEI: 356284-10-101120-3 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is not present. Checking Activations...OK Username: virtualvlep Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 102 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "Q720MS_356284101011203_08-06-2021_11-36-25.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OKFailed! Could not find Security partition! Performed by 3.1.1.03 Software version. |
