08-09-2017, 08:44 | #4651 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Lg p700 pattern remove done without data loss LG P700 PATTERN REMOVE DONE WITHOUT DATA LOSS VIA OCTOPUS BOX Last edited by Octopus box; 08-09-2017 at 10:01. |
The Following User Says Thank You to qaiser_ali123 For This Useful Post: |
08-09-2017, 10:48 | #4652 (permalink) |
Freak Poster Join Date: Feb 2010 Location: india (telangana state) Age: 46
Member: 1230663 Status: Offline Sonork: 100.1593487 Thanks Meter: 174 | E435 flash success E435 flash success Platform: LG Qualcomm Selected port: COM29 Selected model: E435 Reading info...OK Mode: Emergency Model ID: BS/LGE435/7D Performed by 2.7.2.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM29 Selected model: E435 Reading info...OK Mode: Emergency Model ID: BS/LGE435/7D Opening "e 435 V10F_00.oct"...OK Writing CUST...OK Writing BOOT_LOGO_IMAGE...OK Writing RECOVERY...OK Writing PERSIST...OK Writing SYSTEM...OK Writing MODEM...OK Writing APPS...OK Writing APPSSBL...OK Writing EXT...OK Writing OEMSBL...OK Writing QCSBL...OK Finalizing...OK Writing firmware done! Performed by 2.7.2.1 Software version. Last edited by Octopus box; 08-09-2017 at 11:43. |
The Following User Says Thank You to .::VENUGOPAL::. For This Useful Post: |
08-09-2017, 12:56 | #4653 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | LG, H870, ANDROID 7 "FRP" REMOVED WITH SUCCESS by OCTOPUS LG, H870, ANDROID 7 "FRP" REMOVED WITH SUCCESS by OCTOPUS upload image Quote:
BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
08-10-2017, 05:31 | #4654 (permalink) |
No Life Poster Join Date: Dec 2009 Location: INDIA Age: 36
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | LG P700 Flash Done LG P700 Flash Done: Last edited by Octopus box; 08-10-2017 at 06:12. |
The Following User Says Thank You to mr.luckytarun For This Useful Post: |
08-10-2017, 10:34 | #4655 (permalink) |
Freak Poster Join Date: May 2015
Member: 2397754 Status: Offline Thanks Meter: 98 | Unlock LG H443 successfully done Welcome to Octoplus/Octopus Box LG Software version 2.6.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM16 Selected model: H443 Reading info... Model ID: LG-H443 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 0% SW Version: H44312g Mode: Emergency Initializing flash...OK SW version: LGH443AT-01-V12g-310-410-AUG-18-2015+0 Android version: 5.1.1 LAF Version: 1.1 Product ID: CT68S151125003386 IMEI: 357494-06-335390-2 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.6.9 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM16 Selected model: H443 Reading info... Model ID: LG-H443 IMEI: 357494-06-335390-2 Android version: 5.1.1 Battery level: 68% SW Version: H44312g Mode: Normal Performed by 2.6.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM16 Selected model: H443 Reading info... Model ID: LG-H443 IMEI: 357494-06-335390-2 Android version: 5.1.1 Battery level: 68% SW Version: H44312g Trying to enable Diagnostics ports... Found model EAAAANVZ: ÿd at port COM16 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H443_357494063353902_10-08-2017_10-25-00.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "H443_357494063353902_10-08-2017_10-31-18.SEC" Switching to Normal mode... Found model EAAAANVZ: ÿd at port COM16 Writing security area...OK Rebooting phone... Found model EAAAANVZ: ÿd at port COM16 Phone successfully unlocked! Rebooting phone... Performed by 2.6.9 Software version. Last edited by Octopus box; 08-10-2017 at 11:04. |
The Following User Says Thank You to fast solution For This Useful Post: |
08-10-2017, 15:10 | #4656 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LS775 Service Disabled Done Code: Checking data...OK Platform: LG Qualcomm Selected port: COM233 Selected model: LS775 Reading info... IMEI: 356304-07-902615-5 Android version: 7.0 Battery level: 18% SW Version: LS775ZVA Mode: Normal Firmware compiled date: Nov 18 2016 Firmware compiled time: 04:00:00 Firmware released date: May 31 2017 Firmware released time: 16:17:06 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 356304-07-902615-5 SPC: 386374 MEID: 35630407902615 Mobile ESN: 802C7FC5 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 481382 NAM Name: Sprint User Lock Code: 9941 Opening "LS775_35630407476295_29-04-2017_16-49-52(1).sec"... Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LS775_356304079026155_09-08-2017_21-31-31.SEC" Writing security area... LAF Error: 80000121. Trying second method...OK Rebooting phone... Performed by 2.7.2 Software version. |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
08-10-2017, 15:11 | #4657 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG MS345 Gmail Reset Code: Checking data...OK Platform: LG Qualcomm Selected port: COM203 Selected model: MS345 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LGMS345 IMEI: 351608-07-241448-0 Android version: 5.1.1 Battery level: 93% SW Version: MS34510d Mode: Emergency Initializing flash...OK SW version: LGMS345AT-02-V10d-310-160-MAY-21-2015+0 Android version: 5.1.1 LAF Version: 1.1 Product ID: HD56S150614001320 IMEI: 351608-07-241448-0 Target operator: MPCS Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.7.2 Software version. |
08-10-2017, 15:12 | #4658 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG LS990 Flashing Code: Checking data...OK Platform: LG Qualcomm Selected port: COM195 Selected model: LS990 Reading info... IMEI: 352596-06-099454-9 Android version: 5.0.1 Battery level: 14% SW Version: LS990ZV8 Mode: Emergency Initializing flash...OK SW version: LS990ZVG_02 Android version: 5.0.1 LAF Version: 1.1 Product ID: PT01S140627002138 IMEI: 352596-06-099454-9 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS990ZV8_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.7.0 Software version. |
08-10-2017, 15:14 | #4659 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG D851 Gmail Reset Code: Checking data...OK Platform: LG Qualcomm Selected port: COM63 Selected model: VS985 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-D851 IMEI: 014088-00-323950-5 Android version: 6.0 Battery level: 53% SW Version: D85130e Mode: Emergency Initializing flash...OK SW version: LGD851AT-00-V30e-TMO-US-JUL-11-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: SM05S150214001820 IMEI: 014088-00-323950-5 Target operator: TMO Hardware: rev_10 Resetting Screen Lock... Reading partitions...OK Resetting screen lock successfully completed! Performed by 2.7.0 Software version. |
08-10-2017, 15:15 | #4660 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG LS980 Flashing Code: Checking data...OK Platform: LG Qualcomm Selected port: COM54 Selected model: LS980 Reading info... IMEI: 358635-05-951855-6 Android version: 4.4.2 Battery level: 53% SW Version: LS980ZVC Mode: Emergency Initializing flash...OK SW version: LS980ZVC_12 Android version: 5.0.2 LAF Version: 1.0 Product ID: YE01S131221000151 IMEI: 358635-05-951855-6 Target operator: OPEN Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS980ZVC_12.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.6.7 Software version. |
08-11-2017, 11:41 | #4661 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | ls676 unlock done Welcome to Octoplus/Octopus Box LG Software version 2.7.3 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM66 Selected model: LS676 Reading info... IMEI: 350358-54-959569-0 Android version: 6.0.1 Battery level: 44% SW Version: LS676ZV5 Mode: Normal Firmware compiled date: Jun 10 2016 Firmware compiled time: 00:00:00 Firmware released date: Jul 6 2017 Firmware released time: 13:57:58 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM-1.59782.1 IMEI: 350358-54-959569-0 SPC: 000000 MEID: 35030526000000 Mobile ESN: 808D1BB1 NAM Name: Sprint User Lock Code: 0000 Performed by 2.7.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM66 Selected model: LS676 Reading info... IMEI: 350358-54-959569-0 Android version: 6.0.1 Battery level: 45% SW Version: LS676ZV5 Mode: Normal Firmware compiled date: Jun 10 2016 Firmware compiled time: 00:00:00 Firmware released date: Jul 6 2017 Firmware released time: 13:57:58 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM-1.59782.1 IMEI: 350358-54-959569-0 SPC: 000000 MEID: 35030526000000 Mobile ESN: 808D1BB1 NAM Name: Sprint User Lock Code: 0000 Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.7.3 Software version. |
The Following User Says Thank You to Shohel_sst For This Useful Post: |
08-11-2017, 17:28 | #4662 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | LG P769 unlock done LG p769 unlock done Welcome to Octoplus/Octopus Box LG Software version 2.7.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Modem Selected model: P769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...OK IMEI: 013306-00-xxxxxx-4 Bluetooth address: 986:F7:2F:EE:F9 Wi-Fi MAC address: 10:68:3F:85:AD:87 Locks: Network Lock MCC=310 (USA) MNC=260 Unlocking... Reading EEPROM...OK Backup saved to "P769_013306005xxxxxx_11-08-2017_21-54-55.EEP" Writing EEPROM...OK Phone successfully unlocked! Thanks octopus box team Last edited by Octopus box; 08-11-2017 at 17:49. |
The Following User Says Thank You to sr8787 For This Useful Post: |
08-14-2017, 08:10 | #4663 (permalink) |
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | LG M151 Unlock Done LG M151 Unlock Done: Last edited by Octopus box; 08-14-2017 at 08:22. |
08-14-2017, 12:05 | #4664 (permalink) |
Freak Poster Join Date: Apr 2011 Location: BANGLADESH Age: 29
Member: 1553137 Status: Offline Sonork: 100.1652229 Thanks Meter: 56 | LG M200N RFP Reset done .-------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM441 Selected model: M200N Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M200n IMEI: 354965-08-025027-3 Android version: 7.0 Battery level: 21% SW Version: M20010a Mode: Emergency Initializing flash...OK SW version: LGM200nAT-00-V10a-222-88-JAN-06-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: CH31S170207001996 IMEI: 354965-08-025027-3 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! Performed by 2.7.3 Software version. Last edited by Octopus box; 08-14-2017 at 12:47. |
The Following User Says Thank You to jewelmajj For This Useful Post: |
08-14-2017, 15:01 | #4665 (permalink) |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | LG Phoenix 3 AT&T (M150) FRP Removed Operation Logs: ========== Code: Checking data...OK Platform: LG Qualcomm Selected port: COM43 Selected model: M150 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M150 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 84% SW Version: M15010g Mode: Emergency Initializing flash...OK SW version: LGM150AT-01-V10g-310-410-JAN-25-2017-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB42S17xx160086xx IMEI: xxxxxx-xx-xxxxxx-x Target operator: ATT Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! Performed by 2.7.2 Software version. |
The Following User Says Thank You to MR/TAMER_SiLver For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
