06-03-2010, 14:57 | #363 (permalink) |
No Life Poster Join Date: Mar 2008 Location: hungphongmobile.vn
Member: 733209 Status: Offline Sonork: 1001620525 Thanks Meter: 426 | CU575 UNLOCK DONE Last edited by Octopus box; 06-03-2010 at 15:28. |
The Following 2 Users Say Thank You to hung phong For This Useful Post: |
06-04-2010, 01:09 | #366 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | "YELLOW SCREEN & Unavailable Wallpaper file" Full Repair with Octopus Box Only with Direct Unlock! |
The Following 3 Users Say Thank You to 69eyes For This Useful Post: |
06-05-2010, 13:41 | #367 (permalink) |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | kp107 unlock tested Code: Platform: LG Infineon Selected port: COM34 Selected baudrate: 921600 Selected model: KP107 Please reconnect battery... Phone found. Sending preloader...OK Sending loader...OK Reading info. Please wait... Flash ID: 01001A01 Flash type: AMD IMEI: 358306-02-520021-x Reading codes. Please wait... ---------------------------------------------------------------------------------- Unlock code: 7998 1491 To finish the operation, please perform the following steps: 1. Insert the original SIM card and type 2945#*20001# 2.Go to menu>Settings>Security>SIMLOCK and enter the code. |
The Following 3 Users Say Thank You to MR PROTEC For This Useful Post: |
06-06-2010, 14:22 | #368 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | kp 500 write arabic language ok!!!! Log file "C:\Program Files\GsmServer\Octopus\LOG\06-06-2010_05-34-11.log" created. 2010/06/06 05:34:28 ?.? > Welcome to Octopus box software version 1.2.8 2010/06/06 05:35:31 ?.? > ---------------------------------------------------------------------------------- 2010/06/06 05:35:31 ?.? > Platform: LG Infineon 2010/06/06 05:35:31 ?.? > Selected port: USB 2010/06/06 05:35:31 ?.? > Selected model: KP500 2010/06/06 05:35:31 ?.? > Disconnect battery and connect USB cable to phone... 2010/06/06 05:35:45 ?.? > Reading info. Please wait... 2010/06/06 05:35:45 ?.? > IMEI: 352317-04-126365-0 2010/06/06 05:35:55 ?.? > Opening "KP500AT-00-V10k-ARB-XXX-APR-24-2009+0.oct"...2010/06/06 05:35:55 ?.? > OK 2010/06/06 05:35:55 ?.? > Writing Firmware... 2010/06/06 05:58:00 ?.? > Writing Firmware done! 2010/06/06 05:58:00 ?.? > Disconnected. |
The Following 4 Users Say Thank You to sirnavid2010 For This Useful Post: |
06-07-2010, 14:03 | #369 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Macedonia Age: 49
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | GU230 unlocked by reading codes THANKS TO OCTOPUS TEAM gu230 unlock ok by reading codes |
The Following 3 Users Say Thank You to trenac For This Useful Post: |
06-08-2010, 00:35 | #370 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | GD510 Unlock Ok in Seconds.. Code: Welcome to Octopus box software version 1.3.3 ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM6 Selected baudrate: 921600 Selected model: GD510 Please reconnect battery, press and hold power button...Canceled! Disconnected. ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: GD510 Disconnect battery and connect USB cable to phone... Reading info. Please wait... Phone not respond! Reconnecting in safe mode... Please reconnect USB cable This mode only supports firmware writing. Please use COM Cable for unlocking. Disconnected. ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM39 Selected baudrate: 921600 Selected model: GD510 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info. Please wait... IMEI: 359929-03-546664-5 Reading codes. Please wait... Backup saved to "GD510-359929035466645_08-06-2010_09-31-19.eep" ---------------------------------------------------------------------------------- Unlock code: 7376 1971 8464 5591 MCC: 505 (Australia) MNC: 03 (Vodafone) To finish the operation, please perform the following steps: 1. Insert the original SIM card and type 2945#*510# 2.Go to menu>Settings>Security>SIMLOCK and enter the code. USE GW300 UART CABLE.. otherwise via Test Point LITTLE MASTER |
The Following 3 Users Say Thank You to Little_Master For This Useful Post: |
06-09-2010, 19:58 | #371 (permalink) |
No Life Poster Join Date: Oct 2009 Location: JAM Exploring Simlock 3!!! Age: 36
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | Welcome to Octopus box software version 1.3.3 ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM10 Selected baudrate: 921600 Selected model: KP100 Please reconnect battery... Disconnected. ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM18 Selected baudrate: 921600 Selected model: KP100 Please reconnect battery... Phone found. Sending preloader...OK Sending loader...Failed! Disconnected. ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM18 Selected baudrate: 921600 Selected model: KP100 Please reconnect battery... Phone found. Sending preloader...OK Sending loader...OK Reading info. Please wait... Flash ID: 01001A01 Flash type: AMD IMEI: 358479-02-155937-6 Selecting output file... Reading EEPROM into file "KP100-358479021559376.EEP"... Reading EEPROM done! Reading codes. Please wait... ---------------------------------------------------------------------------------- Unlock code: 6271 1265 To finish the operation, please perform the following steps: 1. Insert the original SIM card and type 2945#*20001# 2.Go to menu>Settings>Security>SIMLOCK and enter the code. |
The Following 3 Users Say Thank You to GSM_STREET For This Useful Post: |
06-10-2010, 09:09 | #372 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | AGAIN KP500 FLASH OK ONLY WITH OCTOPUS BOX. Welcome to Octopus box software version 1.2.8 ---------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KP500 Disconnect battery and connect USB cable to phone... Reading info. Please wait... IMEI: 359858-03-746194-2 Opening "KP500AT-00-V10k-ARB-XXX-APR-24-2009+0.oct"...OK Writing Firmware... Writing Firmware done! Disconnected. |
The Following 3 Users Say Thank You to sirnavid2010 For This Useful Post: |
06-10-2010, 18:17 | #373 (permalink) |
Freak Poster Join Date: Dec 2007 Location: IRaN,Teh,7HoZ Age: 36
Member: 649578 Status: Offline Sonork: 100.1592568 Thanks Meter: 70 | cu720 imei change tested Code: Platform: LG Qualcomm Selected port: COM58 Selected model: CU720 Mode: Normal Phone model: CU720 SW Version: CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI: 011783-00-196230-5 Bluetooth adress: 00:21:FB:F5:A6:A2 Fixing IMEI... New IMEI: 358748-03-834315-0 Prepairing loader...OK Sending loader...OK Reading security area... Backup saved to "CU720-011783001962305_10-06-2010_21-38- 14.sec" Erasing security area...OK Writing security area...OK IMEI successfully fixed! Rebooting phone... |
The Following 4 Users Say Thank You to jam_mobile For This Useful Post: |
06-11-2010, 03:56 | #375 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Ph country
Member: 1104730 Status: Offline Thanks Meter: 446 | kh1200 unsupported/flash/unlock done Welcome to Octopus box software version 1.3.5 ---------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM2 Selected model: KH1200 Mode: Normal Phone model: KW120612 SW Version: KH1200-M6250D-V10i-AUG-22-2007-KKR IMEI: 354207-01-635532-6 Bluetooth adress: 00:1C:62:A6:68:96 Firmware compiled date: Aug 14 2006 Firmware compiled time: 11:00:00 Firmware released date: Aug 22 2007 Firmware released time: 12:47:56 User lock code: 7885 ---------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM2 Selected model: KH1200 Mode: Normal Phone model: KW120612 SW Version: KH1200-M6250D-V10i-AUG-22-2007-KKR IMEI: 354207-01-635532-6 Bluetooth adress: 00:1C:62:A6:68:96 Unsupported firmware version! Please, contact to support. ---------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM2 Selected model: KH1200 Mode: Normal Phone model: KW120612 SW Version: KH1200-M6250D-V10i-AUG-22-2007-KKR IMEI: 354207-01-635532-6 Bluetooth adress: 00:1C:62:A6:68:96 Before writing firmware, please fully charge phone battery. Opening "KW120615_00.oct"...OK Reading NVM... Reading NVM done! Backup saved to "KH1200-354207016355326_11-06-2010_10-36- 13.nvm" Switching to Download mode...OK Erasing EFS...OK Writing Firmware...OK Phone startup...OK Writing NVM... Writing NVM done! Writing Firmware done! Rebooting phone... ---------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM2 Selected model: KH1200 Mode: Normal Phone model: KW120615 SW Version: KH1200-M6250D-V10l-APR-07-2009-KKR IMEI: 354207-01-635532-6 Bluetooth adress: 00:1C:62:A6:68:96 Firmware compiled date: Aug 14 2006 Firmware compiled time: 11:00:00 Firmware released date: Apr 28 2009 Firmware released time: 19:34:16 ---------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM2 Selected model: KH1200 Mode: Normal Phone model: KW120615 SW Version: KH1200-M6250D-V10l-APR-07-2009-KKR IMEI: 354207-01-635532-6 Bluetooth adress: 00:1C:62:A6:68:96 Sending loader...OK Switching to test mode... Wait phone startup...OK Searching signatures... Signature #1...OK, not patched Patching... Signature #1...OK Phone successfully unlocked! Rebooting phone... |
The Following 4 Users Say Thank You to Babyunlocker For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
