01-05-2021, 19:25 | #1 (permalink) |
Junior Member Join Date: May 2007 Location: mexico
Member: 517524 Status: Offline Thanks Meter: 1 | unlock fail lg 210 apm [Answered] Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 000000000058307A Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 000000000058314D Checking data...OK Platform: LG Qualcomm Selected port: COM72 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 3539300000000-2 Android version: 8.1.0 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20q-310-410-FEB-10-2020-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS01S180921001930 IMEI: 353934000000000077-2 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via SD Card (Recommended Operation) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: miniphone01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Can't found Micro SD cards Please, connect Micro SD card to PC then repeat operation again. NOTE: SD card must be formatted in FAT or FAT32 file system and size must be lower than 32 GB! Failed! Rebooting phone... Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 000000000058320B Checking data...OK Platform: LG Qualcomm Selected port: COM72 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 3539000000077-2 Android version: 8.1.0 Battery level: 97% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20q-310-410-FEB-10-2020-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS01S180921001930 IMEI: 353934-09-366477-2 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via SD Card (Recommended Operation) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: miniphone01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Can't found Micro SD cards Please, connect Micro SD card to PC then repeat operation again. NOTE: SD card must be formatted in FAT or FAT32 file system and size must be lower than 32 GB! Failed! Rebooting phone... Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583418 Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583451 Checking data...OK Platform: LG Qualcomm Selected port: COM72 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 353934000000002 Android version: 8.1.0 Battery level: 97% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20q-310-410-FEB-10-2020-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS01S180921001930 IMEI: 353934-09-366477-2 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via SD Card (Recommended Operation) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: miniphone01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Reconnecting phone...OK Initializing flash...OK Sending loader... Reconnecting phone...OK Initializing flash...OK Prepairing loader... Executing loader... Reconnecting phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583904 Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 000000000058392A Checking data...OK Platform: LG Qualcomm Selected port: COM72 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 35393400000000-2 Android version: 8.1.0 Battery level: 95% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20q-310-410-FEB-10-2020-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS01S180921001930 IMEI: 35393400000002 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via wipe security Unlocking... Switching to Normal mode... Found model LM-X210APMX210APM20q at port COM141 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583A89 Checking data...OK Platform: LG Qualcomm Selected port: COM141 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583B0D Checking data...OK Platform: LG Qualcomm Selected port: COM141 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583B45 Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583B81 Checking data...OK Platform: LG Qualcomm Selected port: COM141 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 3539340000000002 Android version: 8.1.0 Battery level: 93% Trying to enable Diagnostics ports... Found model LMX210AP: ÿh at port COM141 Reading info... Model ID: LM-X210APM IMEI: 3539340000000002 Android version: 8.1.0 Battery level: 94% Mode: Normal Firmware compiled date: Oct 24 2019 Firmware compiled time: 07:00:00 Firmware released date: Feb 10 2020 Firmware released time: 14:58:31 SW Version: MPSS.JO.3.0.c12-00036-8937_GENNS_PACK-1.220702.1.229846.1 IMEI: 353934000000002 Bluetooth address: 00:57:C1:5C:A9:AF Wi-Fi MAC address: 00:57:C1:FD:44:B0 SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: miniphone01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 10 credits. To perform "Unlock" operation you need to have 0 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210APM_3539000000_30-12-2020_14-53-21.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000583D6E Checking data...OK Platform: LG Qualcomm Selected port: COM141 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 35393400000000-2 Android version: 8.1.0 Battery level: 98% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20q-310-410-FEB-10-2020-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS01S180921001930 IMEI: 353934000000000000-2 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via wipe security Unlocking... Switching to Normal mode... Found model LMX210AP: ÿh at port COM141 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: miniphone01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 10 credits. To perform "Unlock" operation you need to have 0 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items... Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 000000000058417B Checking data...OK Platform: LG Qualcomm Selected port: COM141 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 3539340000000000-2 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: Oct 24 2019 Firmware compiled time: 07:00:00 Firmware released date: Feb 10 2020 Firmware released time: 14:58:31 SW Version: MPSS.JO.3.0.c12-00036-8937_GENNS_PACK-1.220702.1.229846.1 IMEI: 35393000000000-2 Bluetooth address: 00:57:C1:5C:A9:AF Wi-Fi MAC address: 00:57:C1:FD:44:B0 SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: miniphone01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 10 credits. To perform "Unlock" operation you need to have 0 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210APM_35393400000000_30-12-2020_15-20-23.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: miniphone01 Authorizing...OK Checking balance...OK Your balance: 10 credits. -------------------------------------------------------------------------------- Work ID: 0000000000584408 Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: M430 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Work ID: 000000000058444A Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: M430 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M430 IMEI: 356114-08-613739-4 Android version: 7.0 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM430AT-00-V10i-CRK-US-MAR-30-2018-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: VS03S180723001852 IMEI: 35611400000000000-4 Target operator: CRK Hardware: rev_10 Reset FRP operation for M430 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 3.0.7.08 Software version. hola intente liberar este equipo .. y solo consumio creditos help ... |
