04-11-2021, 07:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | Unlock Failed X210APM [Solved] Welcome to Octoplus/Octopus Box LG Software version 3.1.1.02 Card S/N : 000000440D -------------------------------------------------------------------------------- Connecting to server 0...OK Username: ekramkst Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Work ID: 0000000000DC40DE Checking data...OK Platform: LG Qualcomm Selected port: COM61 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-265648-0 Android version: 8.1.0 Battery level: 47% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-265648-0 Bluetooth address: AC:F6:F7:66:05:9F Wi-Fi MAC address: AC:F6:F7:CD:5F:3C SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ekramkst Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210APM_355437102656480_11-04-2021_ 11-51-55.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LMX210APM_355437102656480_11-04-2021_ 11-58-09.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210AP* ’h at port COM61 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ekramkst Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing...Failed! Error code: KLQWHCKAWF Performed by 3.1.1.02 Software version. |
04-12-2021, 08:11 | #6 (permalink) | |
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | Quote:
Welcome to Octoplus/Octopus Box LG Software version 3.1.1.02 Card S/N : 000000440D -------------------------------------------------------------------------------- Work ID: 0000000000DD14B7 Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 3.1.1.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000DD14E1 Checking data...OK Platform: LG Qualcomm Selected port: COM61 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-265648-0 Android version: 8.1.0 Battery level: 38% Trying to enable Diagnostics ports... Found model LMX210AP: ’h at port COM61 Reading info... Model ID: LM-X210APM IMEI: 355437-10-265648-0 Android version: 8.1.0 Battery level: 38% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-265648-0 Bluetooth address: AC:F6:F7:66:05:9F Wi-Fi MAC address: AC:F6:F7:CD:5F:3C SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Login error: Wrong username! Failed! Performed by 3.1.1.02 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: ekramkst Authorizing...OK Checking balance...OK Your balance: 0 credits. -------------------------------------------------------------------------------- Work ID: 0000000000DD1541 Checking data...OK Platform: LG Qualcomm Selected port: COM61 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-265648-0 Android version: 8.1.0 Battery level: 38% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-265648-0 Bluetooth address: AC:F6:F7:66:05:9F Wi-Fi MAC address: AC:F6:F7:CD:5F:3C SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ekramkst Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 0 credits. To perform "Unlock" operation you need to have 0 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190607000950 IMEI: 355437-10-265648-0 Target operator: ATT Hardware: rev_10 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.1.1.02 Software version. | |
06-29-2023, 22:15 | #8 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
I cant find the model on the List. I would like to try unlocking one over SD CArd Method | |
06-30-2023, 06:55 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unlock operation for this phone is supported, you can try to unlock it. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
06-30-2023, 22:42 | #12 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Great phone Unlocked Code: Welcome to Octoplus/Octopus Box LG Software version 3.2.3 Card S/N : 01000XXXXX -------------------------------------------------------------------------------- Work ID: 00000000020F2ACC Checking data...OK Platform: LG Qualcomm Selected port: COM109 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-169xxxx Android version: 8.1.0 Battery level: 66% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-169xxxx Bluetooth address: AC:F6:F7:2E:B8:0D Wi-Fi MAC address: 64:C2:DE:99:30:9F SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: yurais Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS02S190515007591 IMEI: 355437-10-169xxxx Target operator: ATT Hardware: rev_10 Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.2.3 Software version. Last edited by yurais; 06-30-2023 at 22:52. |
The Following 2 Users Say Thank You to yurais For This Useful Post: |
