02-13-2021, 12:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Unlock LG LMX210APM fail [Answered] Welcome to Octoplus/Octopus Box LG Software version 3.1.0 (Lite) Card S/N : 0100004D30 -------------------------------------------------------------------------------- Work ID: 000000000093A1B1 Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 Bluetooth address: 98:B8:BA:C6:C0:AC Wi-Fi MAC address: 98:B8:BA:3C:64:FE SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Please, check that your IMEI is correct. If your phone's IMEI is "000000000000000", please perform Repair IMEI operation. Do You want to continue? Canceled! Performed by 3.1.0 Software version. -------------------------------------------------------------------------------- Work ID: 000000000093A212 Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 Bluetooth address: 98:B8:BA:C6:C0:AC Wi-Fi MAC address: 98:B8:BA:3C:64:FE SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Login error: Wrong username! Performed by 3.1.0 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: arafathadji1 Authorizing...OK Checking balance...OK Your balance: 120 credits. -------------------------------------------------------------------------------- Work ID: 000000000093A261 Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 Bluetooth address: 98:B8:BA:C6:C0:AC Wi-Fi MAC address: 98:B8:BA:3C:64:FE SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: arafathadji1 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 120 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210APM_000000000000000_13-02-2021_ 11-15-46.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LMX210APM_000000000000000_13-02-2021_ 11-22-12.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210AP* ÿh at port COM12 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: arafathadji1 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing...Failed! Error code: KLQWHCKAWF Performed by 3.1.0 Software version. -------------------------------------------------------------------------------- Work ID: 000000000093A9C9 Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 Bluetooth address: 98:B8:BA:C6:C0:AC Wi-Fi MAC address: 98:B8:BA:3C:64:FE SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Please, check that your IMEI is correct. If your phone's IMEI is "000000000000000", please perform Repair IMEI operation. Do You want to continue? Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: arafathadji1 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 20 credits. To perform "Unlock" operation you need to have 0 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Canceled! Performed by 3.1.0 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: arafathadji1 Authorizing...OK Checking balance...OK Your balance: 20 credits. |
