01-13-2021, 21:45 | #1 (permalink) |
Freak Poster Join Date: Dec 2017 Location: venezuela caracas
Member: 2790129 Status: Offline Thanks Meter: 64 | unlock lg LM-X210CM FAIL [Answered] Card S/N : 000003616A -------------------------------------------------------------------------------- Connecting to server ...OK Username: octoplus001 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Work ID: 00000000006AB0BE Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 355513-10-204292-9 Android version: 8.1.0 Battery level: 14% Mode: Normal Firmware compiled date: Jul 08 2019 Firmware compiled time: 22:00:00 Firmware released date: Jul 25 2019 Firmware released time: 16:22:51 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.205920.1.212452.1 IMEI: 355513-10-204292-9 Bluetooth address: 98:B8:BA52:37 Wi-Fi MAC address: 98:B8:BA:4D:BD:B1 SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.0.8 Software version. -------------------------------------------------------------------------------- Work ID: 00000000006AB0FC Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 355513-10-204292-9 Android version: 8.1.0 Battery level: 14% Mode: Normal Firmware compiled date: Jul 08 2019 Firmware compiled time: 22:00:00 Firmware released date: Jul 25 2019 Firmware released time: 16:22:51 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.205920.1.212452.1 IMEI: 355513-10-204292-9 Bluetooth address: 98:B8:BA52:37 Wi-Fi MAC address: 98:B8:BA:4D:BD:B1 SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: octoplus001 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_355513102042929_13-01-2021_ 15-38-31.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LMX210CM_355513102042929_13-01-2021_ 15-45-59.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210CM* ÿh at port COM12 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: octoplus001 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing...Failed! Error code: KLQWHCKAWF Performed by 3.0.8 Software version. me consumio 100 creditos y me dejo el imei en 0 , por favor reintregrar los creditos |
01-14-2021, 14:14 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, write back security backup to restore your device and plesae write in English. Does your device request for Unlock codes? |
