12-20-2021, 11:46 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: saudia
Member: 1021853 Status: Offline Thanks Meter: 27 | v510n imei repier error [Answered] Card S/N : 0001038B75 -------------------------------------------------------------------------------- Work ID: 0000000001FF1FBE Checking data...OK Platform: LG Qualcomm Selected port: COM96 Selected model: V510N Reading info... Found model sdx50mv2 at port COM95 Mode: Normal Firmware compiled date: Nov 18 2020 Firmware compiled time: 01:00:00 Firmware released date: Mar 23 2021 Firmware released time: 03:57:01 SW Version: MPSS.CE.2.1.c8-00147-SDX50MV2_RMTEFS_PACK- 1.237178.33 Fixing IMEI... New IMEI: 359761-07-784454-0 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-V510N Phone firmware version: LMV510NAT-00-V20s-LAO-COM-MAR-23- 2021+0 Kernel version: 4.14.117-perf+ (lgmobile@MCSBS10R28) (clang version 8.0.12 for Android NDK) #1 SMP PREEMPT Tue Mar 23 03:42:13 KST 202 Android version: 10 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: LGU Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...Failed! Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Your balance: 0 credits. |
12-20-2021, 13:25 | #3 (permalink) |
Member: 1021853 Status: Offline Thanks Meter: 27 | Welcome to Octoplus/Octopus Box LG Software version 3.1.6.01 Card S/N : 0001038B75 -------------------------------------------------------------------------------- Work ID: 0000000001FF42A2 Checking data...OK Platform: LG Qualcomm Selected port: COM319 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM319 Model ID: LM-V510N IMEI: 358655-10-304105-8 Android version: 10 Battery level: 54% Mode: Normal Firmware compiled date: Nov 10 2020 Firmware compiled time: 06:00:00 Firmware released date: Mar 23 2021 Firmware released time: 03:09:57 SW Version: MPSS.HE.1.5.2.c8-00160-SM8150_GENFUSION_PACK-1.237178.43 IMEI: 358655-10-304105-8 SPC: 000000 Fixing IMEI... New IMEI: 359761-07-784454-0 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Model ID: LM-V510N Phone firmware version: LMV510NAT-00-V20s-LAO-COM-MAR-23-2021+0 Kernel version: 4.14.117-perf+ (lgmobile@MCSBS10R28) (clang version 8.0.12 for Android NDK) #1 SMP PREEMPT Tue Mar 23 03:42:13 KST 202 Android version: 10 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: LGU Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...Failed! Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Work ID: 0000000001FF4400 Checking data...OK Platform: LG Qualcomm Selected port: COM319 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM319 Model ID: LM-V510N IMEI: 358655-10-304105-8 Android version: 10 Battery level: 54% Mode: Normal Firmware compiled date: Nov 10 2020 Firmware compiled time: 06:00:00 Firmware released date: Mar 23 2021 Firmware released time: 03:09:57 SW Version: MPSS.HE.1.5.2.c8-00160-SM8150_GENFUSION_PACK-1.237178.43 IMEI: 358655-10-304105-8 SPC: 000000 Fixing IMEI... New IMEI: 359761-07-784454-0 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM319 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM319 Model ID: LM-V510N IMEI: 358655-10-304105-8 Android version: 10 Battery level: 54% Mode: Normal Firmware compiled date: Nov 10 2020 Firmware compiled time: 06:00:00 Firmware released date: Mar 23 2021 Firmware released time: 03:09:57 SW Version: MPSS.HE.1.5.2.c8-00160-SM8150_GENFUSION_PACK-1.237178.43 IMEI: 358655-10-304105-8 SPC: 000000 Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001FF4481 Checking data...OK Platform: LG Qualcomm Selected port: COM319 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM319 Model ID: LM-V510N IMEI: 358655-10-304105-8 Android version: 10 Battery level: 55% Mode: Normal Firmware compiled date: Nov 10 2020 Firmware compiled time: 06:00:00 Firmware released date: Mar 23 2021 Firmware released time: 03:09:57 SW Version: MPSS.HE.1.5.2.c8-00160-SM8150_GENFUSION_PACK-1.237178.43 IMEI: 358655-10-304105-8 SPC: 000000 Fixing IMEI... New IMEI: 359761-07-784454-0 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001FF449E Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001FF44B2 Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: V510N Reading info... Found model LMV510NA: ÿh0 at port COM319 Model ID: LM-V510N IMEI: 358655-10-304105-8 Android version: 10 Battery level: 55% Mode: Normal Firmware compiled date: Nov 10 2020 Firmware compiled time: 06:00:00 Firmware released date: Mar 23 2021 Firmware released time: 03:09:57 SW Version: MPSS.HE.1.5.2.c8-00160-SM8150_GENFUSION_PACK-1.237178.43 IMEI: 358655-10-304105-8 SPC: 000000 Fixing IMEI... New IMEI: 359761-07-784454-0 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-V510N Phone firmware version: LMV510NAT-00-V20s-LAO-COM-MAR-23-2021+0 Kernel version: 4.14.117-perf+ (lgmobile@MCSBS10R28) (clang version 8.0.12 for Android NDK) #1 SMP PREEMPT Tue Mar 23 03:42:13 KST 202 Android version: 10 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: LGU Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...OK Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Platform: msmnile SW version: LMV510NAT-00-V20s-LGU-KR-MAR-23-2021+0 Android version: 10 LAF Version: 1.1 Product ID: VS02S191004006614 IMEI: 358655-10-304105-8 Target operator: LAO Hardware: rev_10 Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Writing security area... Please, put the phone in EDL Mode (Qualcomm 9008): 1. Press and hold "Vol-" and "Power" buttons. 2. As soon as the screen turns off, keep holding the "Vol-" and "Power" buttons and simultaneously press "Vol+" few times quickly. 3. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". Found port COM51 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions... ERROR :No active document Rebooting phone... Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: yU7z8f2Rcp Authorizing...OK Checking balance...OK Your balance: 0 credits. |
