09-14-2013, 21:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Samsung SCH-w299 Help needed..... On Dc Power Supply Reading 1-7 Fluctuation On PRess Power On RElease Itss 0 I Alredy Flash THe Phone After Flash It Restart n On Bt KEypaid Not Work SO i disconnect Battery n try to re power on Bt not on... I also Put Charger it show charging bt when i press Power key nothing Happen Charging Only........ One More thing I notice Battery Connector Middle Point (BSI) Supply misssing n it Goes On component Behind Battery Connector bt there is also no supply??.... In This Set Bsi Is there???...becauzz i not check before dead if yes supply way except bc behind resistance??>... if not other way to repair ???. Urgently reply needed Thanks In Advance |
09-14-2013, 23:31 | #2 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
You Should Check Lock Key, If Phone Locked Cellphone Won't Power On. | |
