ZTE General ZTE phones discussion, firmwares, solution, help |
12-26-2012, 14:37 | #77 (permalink) |
Junior Member Join Date: Mar 2008
Member: 737664 Status: Offline Sonork: [email protected] Thanks Meter: 1 | ZTE blade hard reset CODE -*983*987# |
12-26-2012, 14:41 | #78 (permalink) |
Member: 737664 Status: Offline Sonork: [email protected] Thanks Meter: 1 | How to reset unlock pattern in android phone zte Blade CODE -*983*987# 100% OK |
The Following User Says Thank You to dti For This Useful Post: |
12-27-2012, 10:16 | #79 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: INDIA
Member: 530721 Status: Offline Thanks Meter: 157 | Quote:
The Following User Says Thank You to Sandeep Mobiles For This Useful Post: |
01-06-2013, 06:45 | #80 (permalink) |
Freak Poster Join Date: Mar 2009 Location: India
Member: 997585 Status: Offline Sonork: [email protected] Thanks Meter: 17 | reply for zte light blade v9 pattern lock.... 1. Press urgent call in idle mode 2. input *983*987#,it will go to the factory reset interface and customer can reset the handset to Default. Note:This method will delete all the personal information in the phone. 100000000000000% dnt forget to click thanks |
The Following User Says Thank You to rawkiss For This Useful Post: |
02-12-2013, 23:56 | #83 (permalink) | |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Quote:
usage: fastboot [ <option> ] <command> commands: update <filename> reflash device from update.zip flashall flash boot + recovery + system flash <partition> [ <filename> ] write a file to a flash partition erase <partition> erase a flash partition getvar <variable> display a bootloader variable boot <kernel> [ <ramdisk> ] download and boot kernel flash:raw boot <kernel> [ <ramdisk> ] create bootimage and flash it devices list all connected devices continue continue with autoboot reboot reboot device normally reboot-bootloader reboot device into bootloader help show this help message options: -w erase userdata and cache -s <serial number> specify device serial number -p <product> specify product name -c <cmdline> override kernel commandline -i <vendor id> specify a custom USB vendor id -b <base_addr> specify a custom kernel base address -n <page size> specify the nand page size. default: 2048 C:\zte\fastboot>-w Der Befehl "-w" ist entweder falsch geschrieben oder konnte nicht gefunden werden. C:\zte\fastboot>fastboot-windows.exe -w < waiting for device > erasing 'userdata'... OKAY [ 1.844s] erasing 'cache'... OKAY [ 0.453s] finished. total time: 2.297s C:\zte\fastboot> | |
04-08-2013, 12:44 | #85 (permalink) |
No Life Poster Join Date: Nov 2008 Location: india Age: 49
Member: 901335 Status: Offline Sonork: 100.1652281 Thanks Meter: 151 | google lock solution is home + power +volume up press . and after start set remove power button and there will appear wipe data factory . use back buttn to select option . enjoy . tested by me . |
The Following User Says Thank You to bigmarsa For This Useful Post: |
05-19-2013, 09:00 | #87 (permalink) |
Junior Member Join Date: May 2013
Member: 1940886 Status: Offline Sonork: zte blade san francisco Thanks Meter: 0 | zte blade san francisco i could some one tell me what to do coz i just woke up with my phone loading and cant use it! dont khnow what to do pls need help thanks |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
3110 Need to Unlock & Reset | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-22-2001 08:35 |
how can you reset the life timer without using a data cable for a 5125 TDMA phone? | PiNoY_bOy204 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-23-2001 12:46 |
HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-26-2001 05:33 |
5190 patial flashes - why are they so hard to find? | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-14-2001 03:18 |
