Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 04-06-2013, 13:42   #1 (permalink)
..::Nokian Care®::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
Post Here All Successfull Flashed Micromax Phones with Factory Flasher & File
# Share here your all successfull flash stories of Micromax Phones
# If possible make flashing manual for users help
Note:
Use this thread for share success stories & manual only.
Don't make any file, flasher & manual request here.
Most of them can be, anyway, downloaded Here
Thnx post will be deleted without any warning.
azam
The Following 4 Users Say Thank You to ..::Nokian Care®::.. For This Useful Post:
Old 04-06-2013, 14:21   #2 (permalink)
Member: 505794
Thanks Meter: 2,266
Micromax X456 Successfully flashed with manual
Micromax X456 flashing manual step by step
Download Flasher & Firmware From Here
Open FlashTool_v5.1220.00
Click on Scatter/Config File & select cfg File
Click on option & tick on USB Download/Readback now Scroll down to Backup and Restore & tick on Backup ->Download/Format -> Restore
Now finaly click on Download & plug USB cable to your powerd off phone
Wait for finished & Enjoy......(if failed try again)
Flashing Hints:No boot key needed for flash this phone just connect power phone.
azam
The Following 6 Users Say Thank You to ..::Nokian Care®::.. For This Useful Post:
Old 04-06-2013, 15:33   #3 (permalink)
Prem_India's Avatar
Member: 718725
Sonork: 100.1604953 QQ 2339690693
Thanks Meter: 6,702
Micromax X231 Flash Done (FlashTool_v5.1140.00)
Download Flash FIle And Flasher Here
Process Same
See Post 2
B.R.,
Prem_India
The Following 2 Users Say Thank You to Prem_India For This Useful Post:
Old 06-18-2013, 09:36   #4 (permalink)
Prem_India's Avatar
Member: 718725
Thanks Meter: 6,702
Micromax Canvas Viva A72 Flashed Done By OG Flash Tool
Google User Name/Password Remove Successfully
After Click On Download
Insert USB Cable
http://www.youtube.com/watch?v=JBwqzjUAUxs
Download Video
A72 Flash File And Flasher Download Here
B.R.,
Prem_India
Old 07-05-2013, 07:12   #5 (permalink)
Prem_India's Avatar
Member: 718725
Thanks Meter: 6,702
Micromax A25 Flash With OG Flash Tool AND Flasher
Micromax A25 Flash With OG Flash Tool And Flasher
OpenSP_Flash_Tool_v3.1207.03_forGoinee Folder
Double Click On Flash Tool.exe
Click On Scatter-Loading
GO TO A25_0201_T0370 Folder
Select MT6575_Android_scatter File
Than Click On Download
Insert Modified Cable OR Boot With Any China Box
Flash With Start
Micromax A25 Flashing Video
http://www.youtube.com/watch?v=s9MSi-48Ohs
Download Video
Download Flash File And Flasher Here
B.R.,
Prem_India
Old 09-01-2013, 13:36   #6 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
Micromax a-27 bolt flas done by og.
The software version “ZE25PAA_060A_V8_0_7” is confirmed.
Release note:
1. change power on-off animation;
2. add M! Zone+ launcher apk ;
3. add launcher for 2 games (tigerwoods & FIFA10)
BOOT KEY VOL DOWN,
FLAS FILE
http://www.moulnisky.com/index.php?d...60A_V8_0_7.rar
OK FLASHER HERE
http://www.moulnisky.com/index.php?d..._R2.9.7006.rar
The Following 3 Users Say Thank You to mobile house dinajpur For This Useful Post:
Old 11-20-2013, 19:11   #7 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 930
MICROMAX P362 TAB TOUCH NOTWORKING AFTER FLASH SUCCESSFULLY RECTIFIED WITH LATEST TOUCH FIX VERSION
BRO
PRASAD
The Following 5 Users Say Thank You to cellcare prasad For This Useful Post:
Old 01-03-2014, 07:45   #8 (permalink)
Prem_India's Avatar
Member: 718725
Thanks Meter: 6,702
MIcromax A52 Dead Recover & Repiar IMEI Done By OG Tool And Flasher
Flash Done
Repair IMEI
B.R.,
Prem_India
Old 02-28-2014, 09:04   #9 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Micromax A35 [Pattern/Google Lock Removed] Done
The Following User Says Thank You to .::TEJARAM::. For This Useful Post:
Old 03-03-2014, 14:51   #10 (permalink)
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Micromax A27 flash success
Old 03-10-2014, 10:15   #11 (permalink)
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
a65 successful flash
Old 03-21-2014, 08:28   #12 (permalink)
Member: 2141811
Thanks Meter: 38
Flashing Firmware Image Files Using The Rockchip Batch Tool
This is a quick guide to Flash single firmware image files onto your tablet. Manufacturers mainly provide single image files to upgrade tablets, as do some Rom Cookers for their custom firmwares. If you want to install a custom firmware or want to return your tablet back to a manufacturers stock rom, for warranty purposes etc this is sometimes the only way to do it. It is quite straightforward to do so here we go!
Firstly this is presuming that you have already installed the Rockchip drivers for your tablet if not follow my guide here: http://www.freaktab.com/showthread.p…-for-flashing!
STEP 1
Make sure your tablet is charged. Download the Rockchip batch tool
Rockchip Batch Tool Download
STEP2
Unzip the file and start the RKBatchTool program, and use the firmware path selector to find your firmware image.
Now put your tablet into recovery mode or flash mode as it is sometimes called and connect it to your PC. As you will see you will see that your device is connected, indicated by the green box. If you are upgrading from say a manufacturers Rom to a new version that hit the upgrade button, if you are installing a custom firmware that usually it is the restore button.
Step 3
Once you have done this the software will send the firmware to your tablet and the flashing process will begin, you will see firmware loading on the RockchipBatchTool screen, just leave it to do its work and be patient and be careful not to knock or touch anything while it is flashing. Once the process has completed your tablet will disconnect from the program and the green box will not be highlighted. Now the tablet will begin to flash and reboot with your new firmware on it!
The Following User Says Thank You to bishnuprasad884 For This Useful Post:
Old 04-04-2014, 10:04   #13 (permalink)
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
A-27 FULL FLASH DONE
Old 04-09-2014, 13:01   #14 (permalink)
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Micromax A72 [Pattern/Google Lock Removed] Done
Old 04-12-2014, 11:53   #15 (permalink)
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Micromax X-291 flash success
Page generated in 0.29610 seconds with 9 queries
