FREE CELLULAR FIX for Passcode Locked & Disabled iPhone/iPad (Apple Tech) If you have an iphone or ipad passcode locked / disabled, it is now possible to bypass icloud and activate your device. Your device needs to be already FactoryActivated to use this method. If you just erase or restore, bypass iCloud and then add a passcode that’s not the same thing. This will not work. You need a checkra1n compatible device with a passcode or FactoryActivated device. how you can activate CALLS and CELLULAR DATA on your passcode locked/disabled iDevices using Apple Tech 752 Sliver 4.2, powerful iCloud Bypass tool for macOS High Sierra. NOTE: Before you do anything we are not responsible for what you do with your device. This is still in beta, we still need to do more tests and make compatible with all devices, if this method doesn’t work you should wait for new update or try again step by step. jailbreak with checkra1n use the software to read your activation data restore your device to the latest iOS (ipsw) jailbreak again and bypass icloud using software relay device info and activate your device done Follow the video tutorial, If it does not work on the first try, that’s normal. Just keep trying again and always click relay device info before activating the device. Eventually, you’ll get lucky, some devices took me 10 or more tries. For now, this method is only compatible with passcode locked/disabled devices. However, developers will always looking for ways to add features to Sliver and will continue to update and improve it. Download Silver 4.2 ( macOS High Sierra ) Download Silver 4.2 ( windows version ) FREE CELLULAR FIX for Passcode Locked & Disabled windows tools If this software doesn’t work with your macOS, you can try using the manual files with terminal, since this tool only supports Hight Sierra Mac OS you may want to try terminal files using command lines to activate your device. This method was created and developed by @hpegar from twitter. How to Fix CELLULAR for Passcode Locked & Disabled iPhone/iPad! MANUAL METHOD 1. DEVICE MUST BE PASSCODE OR DISABLED Download this files ( put the files into the desktop ) 2.Connect device and jailbreak with checkra1n EXECUTE “IPROXY 2222 44” in new window or tcprelay Exec 1.sh ( new terminal window) RESTORE IPHONE Latest VERSION JAILBREAK AGAIN RUN THIS COMMAND – “scp -r -P 2222 /Users/YOURUSERNAME/Desktop/ssh\ files/3/Library/ [email protected]:/private/var/wireless/“ EXEC 2.h and copy the GUID Example (86FA201C-9D8C-4DAF-BF6D-2AF8669F5ED0) REPLACE /00000-000/ THIS WITH RANDOM GUID PROVIDED ON 2.sh EXECUTE THIS “scp -r -P 2222 /Users/YOURUSERNAME/Desktop/ssh\ files/4/Library [email protected]:/private/var/containers/Data/System/0000000-0000000-000000/“ done All thanks to @hpegar |
but my question about passcode there is any way to just disable passcode and keep all information inside. i just need to find the email or phone number for the owner of this iPhone i have it on hand. :confused::confused: |
No Solution :( |
https://myicloud.info/how-disable-pa...-with-carrier/ |
thank s for the good solution |
tested and working iphone 6s thanks appletech |
iF bypassed will Reset/Relock? Sent from my SAMSUNG-SM-G935A using Tapatalk |
br |
