iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides , Tutorials and News |
12-10-2010, 13:05 | #138 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1334937 Status: Offline Thanks Meter: 0 | salam to all i had problem to sync with iyune , and when i did clean the hosts on my pc : removed all where is mentionned apple things,, on : C:\ windows/system32/drivers/etc . I did restore my iphone via itune with a new fw 4.2 and i did kicked recovery mode with tinyumbrella ,its works fine , and now i unlocked my iphone 3g via repo.ultrasn0w.com 1.2 . all working fine , thanks to all for the hard job they done to make it easy for everyone , baraka *****ou fikoum . |
12-10-2010, 17:56 | #139 (permalink) |
No Life Poster Join Date: Oct 2008 Location: dubai
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | i have solved the error 1015 while restore by tiny umberlla many times ,,,, escpecially in the case of v4.2.1 ...the phone have updated (moderm firmware lover than 06.15 or the custome ralready tried to unlock) |
12-10-2010, 20:23 | #140 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1263932 Status: Offline Thanks Meter: 181 | Errors 10xx: This mostly means that the baseband was not updated. This is what you want to not lose your unlock. If you have upgraded your baseband to the version included with iOS 4.1 already, you cannot unlock, but you can use the iPad baseband trick (install baseband 6.15 from iPad). It is NOT recommended to upgrade your baseband if you have still the one from iOS 4.0.2 or older. Please note that "Exit Recovery" (by any tool) only works with iOS 4.1 or lower. For 4.2.1 the Kick out of Recovery does not work. Either you upgrade the baseband (which avoids the error message and boots normal), or you use unsupported methods to upgrade to 4.2.1. 4.2.1 is still tethered anyway, which means you need a computer to boot your device every time you turn it off or battery is empty. Users that need an unlock or don't want a tethered boot should remain with their current version until something better comes out. |
12-11-2010, 18:31 | #142 (permalink) |
Member: 1263932 Status: Offline Thanks Meter: 181 | Tell us what you're doing. What firmware versions are installed, what version you try to install and how, what is in your hosts file, what shsh versions are on Cydia etc. |
12-12-2010, 15:44 | #145 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | I have iphone 2g a 1203 it give error 23 pls help me this problem is hardware r software pls guide me any body [email protected] |
12-12-2010, 16:23 | #146 (permalink) | |
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | Quote:
12-14-2010, 13:52 | #149 (permalink) | |
Member: 1263932 Status: Offline Thanks Meter: 181 | Quote:
Or you disabled to sync songs. Check the Music tab when you select your iPhone. If it still doesn't work, ask Apple. | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
