Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Bada Platform
Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750
Old 03-30-2013, 01:31   #1 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Samsung Bada secret Codes :)
Important The below codes are not for noobs. If you by-chance brick your phone. I am no-where responsible. You can regain your firmware by flashing it to the phone. That is no Problem :P :P
Note-P.S- All the codes can be entered using the dialer...The code will be executed after you enter the last # ( i.e. if you just enter the codes below, it will execute it without permission
*2767*3855#
Think twice before you use this code. It is a Factory reset code. This will wipe off all your data be it in the internal memory or the external memory. I advice you people to use this code with the External SD card and the SIM removed.
Once you have entered this code, There is no way you can stop it.
*#197328640#- This code is used to enter the Service mode. You can change settings here and run some tests. Any changes except for the camera part will no crash your FW.
*#0228#- This code gives you information about your phone battery.
*#7465625#- This code can be used to check the status of SIM lock, Network LOCK,etc.
Codes to get Firmware Version Information
*#4986*2650468# - SW Version, HW Version, MP, RF Cal Date, CSC Version, CSC Model Spec, FFS Version, RC2 Version
*#1234# - SW Version and CSC Version
*#1111# - FTA SW Version
*#2222# - FTA HW Version
Wi-Fi and Bluetooth testing codes
*#526# - Wi-Fi Manual MFG Test Mode
*#232337# - BT RF Test Mode
Code to launch various factory tests
*#0*# - LCD test
*#0673# OR *#0289# - Melody test
*#0842# - Vibration test
*#2663# OR *#2664# - TM Command
*#4097*4097# - GPS menu
*#272*time* - csc pre configuration
example *#272*1423* ( if the time is 14:23)
*#0002*28346# - Another service menu
*#0228#- Battery test
*#232337#- Bluetooth addrs
*#5239870*# - Admin settings
*#66225*# Motion Calibration
gps menu -
*#4097*4097#
PS- Many users have complained that the motion sensor calibration code is resulting in the incorrect functioning of the Accelerometer. If you encounter such a problem or if you want to use the Motion sensor Calibration code, Please be sure to place the phone on a flat surface and wait for about a minute!
And tell me how you like it!
Source
Xda Developers and Google
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 07-16-2014, 19:38   #2 (permalink)
Member: 1082487
hold pwrkey+upvol+menu ur prob solv
The Following User Says Thank You to manojkunwar For This Useful Post:
Page generated in 0.12748 seconds with 8 queries
