02-11-2014, 22:14 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2126389 Status: Offline Thanks Meter: 0 | Carrier network restarting after unlock lock screen I have iPhone 5 successfully unlocked with R-SIM 9 Pro. To use 3g I need to enable Data Roaming. But I have some strange problem, I think it is not normal r-sim behavior. 1. Data roaming auto turning off after few minutes/seconds. Usually when the phone is in stand by. 2. When I unlock via slide to unlock, the carrier network is restarting. I cannot call in first 20-30 seconds, and if someone call me he will receive voice that I am currently offline. Is there solution for these two problems? |
02-12-2014, 04:25 | #2 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | Check your iphone for a liquid damage if not then store your ios and check to see if you got the same problem if still exists then point your finger at the rsim which it could be defective. |
02-12-2014, 11:53 | #3 (permalink) |
Member: 2126389 Status: Offline Thanks Meter: 0 | I checked there is no water damage. You mean to restore factory settings via itunes? I am not sure I will be able to activate the phone after that, because don't have original carrier sim card. |
02-13-2014, 00:25 | #6 (permalink) |
Freak Poster Join Date: Nov 2010
Member: 1449117 Status: Offline Thanks Meter: 35 | Hey I feel like there is an issue with iRoseTool Lately, I have also had this issue. Just use Neterteam patch and activate properly first making sure iPhone is activated. Then use iRosetool after if you need to force it into 3G |
02-15-2014, 18:58 | #7 (permalink) |
Member: 2126389 Status: Offline Thanks Meter: 0 | After itunes restore, the phone started working normally. It is working even without iRoseTool and Neterteam. Maybe it it was broken, because I was edited CarrierBundle files. Thanks to all. |
02-15-2014, 19:36 | #8 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | That is true you have modify the ios of your iphone by going to the ifile and because of this I always advice you guys do not do the way through the ifile if you are not familiar with what it since you could Easley delete or modify a vital file on your ios. |
