iPhone 5 ios 8.1.2 jailbroken can't activate R-SIM 9PRO I'm using R-SIM 9 pro,works with chip but not without it. Can't activate... Any packeges I should install etc.? |
No one knows how to fix activation failed? |
input another sim card select your locked carrier click accept then restart and activate |
You need the chip at all times under your SIM card. |
You must define what carrier it is locked. Verizon cost 40$ At&T 40$ Uk Vodafone, Orage cost 55$ Sprint cost 120$( but you can't reset, because iphone will be relocked again). |
uk orange i5 support by server please Quote:
not available for i5c / i5s... yet, but if someone else have this service till i6/ i6+ kindly let me know by pm urgently for the same uk orange. Br :) |
Nope still nothing.. |
Also why can't I dial the number to check how much money I have on my sim card but I can call and receive calls? |
Got it working I installed patch A from the repo isamteam .com (the one that says ios 8.x), then after respring, opened the the newly created app "r-sim" tapped on the first blue button, installed the apn. re insert the sim, use at t, i5 then I used ios 7.0 - 7.06 instead of 7.1.x. And that's it, i still have to check if i can receive calls, apparently i can make calls. also i have to check data and sms |
So can anyone assist me over skype or anyhow? Please :/ |
You need USSD: Open Cydia, make sure commcenter patch is installed, if not add source repo apt.chinasnow and then install it, install iFile, go into iFile, go to /var/mobile/Library/Carrier Default.Bundle, click on carrier.plist, Property List Viewer, turn on SupportsSupplementaryServicesOver3GPP, and restart. Sometimes, you need to add that boolean string to the bundle that you're using(Carrier Bundle.bundle instead). |
Well it's not working anymore anyways.. |
