Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 12-16-2014, 18:14   #1 (permalink)
Member: 2303032
Thanks Meter: 2
iPhone 5 ios 8.1.2 jailbroken can't activate R-SIM 9PRO
I'm using R-SIM 9 pro,works with chip but not without it.
Can't activate...
Any packeges I should install etc.?
The Following User Says Thank You to Croatian For This Useful Post:
Old 12-16-2014, 20:38   #2 (permalink)
Member: 2303032
Thanks Meter: 2
No one knows how to fix activation failed?
Old 12-17-2014, 18:40   #3 (permalink)
Member: 2312474
Thanks Meter: 9
input another sim card select your locked carrier click accept then restart and activate
Old 12-17-2014, 21:11   #4 (permalink)
Member: 1938435
Thanks Meter: 208
You need the chip at all times under your SIM card.
Old 12-17-2014, 22:10   #5 (permalink)
Member: 2274130
Thanks Meter: 16
Can't activate...
You need factory unlock?
You must define what carrier it is locked.
Verizon cost 40$
At&T 40$
Uk Vodafone, Orage cost 55$
Sprint cost 120$( but you can't reset, because iphone will be relocked again).
Old 12-17-2014, 22:35   #6 (permalink)
Member: 2136133
Verizon cost 40$
At&T 40$
uk orange iphone 5s how much?
Old 12-18-2014, 07:13   #7 (permalink)
cabezaadrian10's Avatar
Member: 1239963
Sonork: Coming Soon
Thanks Meter: 42
uk orange i5 support by server please
sorry my friend but uk orange by server average is up to i5 clean devices, usd 55.00 processed in 5 working days.
not available for i5c / i5s... yet, but if someone else have this service till i6/ i6+ kindly let me know by pm urgently for the same uk orange.
Old 12-18-2014, 16:07   #8 (permalink)
Member: 2303032
Thanks Meter: 2
Nope still nothing..
Old 12-18-2014, 16:22   #9 (permalink)
Member: 2303032
Thanks Meter: 2
Isn't it supposed to work without the chip? Like in the video?
Also why can't I dial the number to check how much money I have on my sim card but I can call and receive calls?
Old 12-22-2014, 12:33   #10 (permalink)
Member: 2315191
Got it working
I installed patch A from the repo isamteam .com (the one that says ios 8.x), then after respring, opened the the newly created app "r-sim" tapped on the first blue button, installed the apn. re insert the sim, use at t, i5 then I used ios 7.0 - 7.06 instead of 7.1.x.
And that's it, i still have to check if i can receive calls, apparently i can make calls. also i have to check data and sms
Old 12-25-2014, 13:09   #11 (permalink)
Member: 2303032
Thanks Meter: 2
So can anyone assist me over skype or anyhow?
Please :/
Old 12-25-2014, 17:18   #12 (permalink)
Member: 1938435
Thanks Meter: 208
No unlock chip or are you using the RSIM 9 Pro?
Old 12-25-2014, 17:23   #13 (permalink)
Member: 1938435
Thanks Meter: 208
You need the chip; the video is probably the old SAM trick that was patched by Apple 2 years ago.
You need USSD: Open Cydia, make sure commcenter patch is installed, if not add source repo apt.chinasnow and then install it, install iFile, go into iFile, go to /var/mobile/Library/Carrier Default.Bundle, click on carrier.plist, Property List Viewer, turn on SupportsSupplementaryServicesOver3GPP, and restart. Sometimes, you need to add that boolean string to the bundle that you're using(Carrier Bundle.bundle instead).
Old 12-25-2014, 17:24   #14 (permalink)
Member: 1938435
Thanks Meter: 208
I think the worldwide service supports it but it's about $100.
Old 12-26-2014, 17:53   #15 (permalink)
Member: 2303032
Thanks Meter: 2
Well it's not working anymore anyways..
Page generated in 0.26649 seconds with 8 queries
