01-31-2014, 08:20 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2118173 Status: Offline Thanks Meter: 2 | iPhone 5S locked to AT&T - R-Sim 9 Pro I have successfully managed to unlock my phone with R-SIM 9 Pro with T-Mobile sim. Call = OK SMS = OK 2G = OK I am trying to get 3G/4G/LTE if that's possible. I have what I am assuming at this point, a 128k nano sim, I'm wondering what are my next steps. Irose tool only allows me to force 2G. I've read in other posts that a 64k sim is required for any luck with 3G, but that was for people with Sprint issues, would it apply for AT&T as well? I'd appreciate a response to my thread, Thank you for your time and understanding |
The Following User Says Thank You to Ericg625 For This Useful Post: |
01-31-2014, 10:07 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | You need to buy a 39.01a T-Mobile SIM on eBay and cut it down. It's gonna be a tight fit inside the iPhone 5S with the R-SIM, but that's what you have to use. |
The Following User Says Thank You to SIMTester For This Useful Post: |
01-31-2014, 15:48 | #4 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | Yes if the sim card is too thick then just take a a boxcutter and scrape it on the opposite side of the gold ship carefully and make it thinner in a different way you will ruin your rsim and your motherboard so remember never force things into the iphone. |
The Following User Says Thank You to futur For This Useful Post: |
01-31-2014, 19:14 | #5 (permalink) |
Member: 2118173 Status: Offline Thanks Meter: 2 | Thank you for the response, Will purchasing that specific type of T-Mobile sim help enable 4G/LTE service for me? Also will that require me to use the same iR0se tool to enable the patch? Thank you for your time |
01-31-2014, 20:45 | #6 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | Yes after you get your edge just hit 3g, also 64k comes in mico and nano if I am not mistaked just look on ebay but if not then use the cutterbox trick on the general size sim after you resize it down to the nano size. Good Luck. |
01-31-2014, 21:18 | #7 (permalink) |
Member: 2118173 Status: Offline Thanks Meter: 2 | Ok thank you. I found it on eBay, does it matter whether it's regular size or micro? There are options for one or the other, I just want to make sure I purchase the correct card. Then I will resize it to nano. Thanks again. |
01-31-2014, 22:16 | #8 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | Make sure it says 64k and then look for the size but if you can combine both then it would be much better so let say if they have it in a micro and general size then prefer the micro since the micro will be thinner than the general size which is the old big size and if you got to choose among micro and nano being both 64k then go for the nano. Good Luck |
02-01-2014, 08:12 | #13 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | 64K doesn't matter. I have SIMS that say 64K(straighttalk and some Simple Mobile) that don't get 3G. It has to be a specific SIM card like 39.01a. |
02-01-2014, 15:53 | #14 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | T Mobile 3G Micro Sim Card for iPhone 4 4S Unactivated Tmobile Sim Ver 39 01A | eBay Hopefully this will help, just click on the above link. |
02-01-2014, 16:01 | #15 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | New T Mobile Nano Sim for iPhone 5 5c 5S GSM Unactivated Tmobile Sim 3G | eBay Oh buy this one it's even better since it's the nano size and it's cheaper. Good Luck and special thanks to SIMTester for helping around as well. |
