03-21-2015, 06:58 | #1 (permalink) |
Insane Poster Join Date: Mar 2015
Member: 2366081 Status: Offline Thanks Meter: 4 | My 5s with Rsim 10 Can't recive calls but can make em |
08-08-2015, 00:34 | #3 (permalink) |
Member: 2366081 Status: Offline Thanks Meter: 4 | My 5s with Rsim 10 Can't recive calls but can make em Install isamteam repo and install packages a: , m . Gives u a 2g 3G option in carrier tan in menu . Unlockit.nz download Apn setting for your carrier bit u also can enter manually in carrier tab further down install biteyour Apple repo install mms fix and FaceTime . But after the rsim being unreliable I have switched to a xsim evo . Works perfect. Sent from my iPhone using Tapatalk |
08-08-2015, 02:38 | #4 (permalink) |
Junior Member Join Date: Nov 2005
Member: 203335 Status: Offline Thanks Meter: 2 | thanks for replying i got the data to work i had to use the plist from tmobile bunddle i got 4g noe the only problem i have is no incoming calls and no text untill i make a call i am getting closer the incoming call is realy a problem i do get voicemail notification but don recive calls i checked call forwarding and it is off any other idias again thans for info carupter |
08-08-2015, 02:48 | #5 (permalink) |
Member: 2366081 Status: Offline Thanks Meter: 4 | I had same issues . I ended up with getting incoming calls on 2g signal only . I could not get data for Internet or mms but could ale n receive calls n Sms in the end . I just had to install the isamteam repo and install packets a:1 and m . Hope this helps . Sent from my iPhone using Tapatalk |
08-08-2015, 02:51 | #6 (permalink) |
Member: 2366081 Status: Offline Thanks Meter: 4 | But I ended up buying a xsim evo the thing is brilliant it delivered ever thing rsim promised and way more reliable . just used the same isamteam repo packets that work on the rsim . I can send u screen shots of everything if u like . Sent from my iPhone using Tapatalk |
08-12-2015, 05:45 | #9 (permalink) |
Member: 203335 Status: Offline Thanks Meter: 2 | thanks i found it i get incoming calls with 2g only when i switch to 3g or lte i dont get incoming calls and dont get data the only way i get data is when i put my sim without the rsim i get data then i put the rsim with my sim and i get 3g as soon as i swich back to 2g so i can get incoming calls i loose the data do you have a fix where i get data and incoming calls at the same time my rsim air2 is stable locks up with my carrier realy good thanks for your help carlos |
08-12-2015, 07:07 | #10 (permalink) |
Member: 2366081 Status: Offline Thanks Meter: 4 | Have u gone to unlockit.nz to get apn settings ? Have u opened the cellular data network tab for manual input ? Also have u installed the repo biteyourapple. For this packet or insanelyi repo for this Sent from my iPhone using Tapatalk |
08-14-2015, 03:31 | #12 (permalink) |
Member: 203335 Status: Offline Thanks Meter: 2 | i have that set up does not get me the data with incoming calls i cant get both at the same time if you have anymore info i will be thankfull i will keep trying thanks for your time carlos |
08-14-2015, 03:32 | #13 (permalink) |
