01-22-2014, 08:22 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2110498 Status: Offline Thanks Meter: 0 | My methods to activating 3G data (iphone 5 sprint) 2. Install APN Configuration from unlockit fill your carrier and country. 3. Add isamteam repo 4. Install "A" in the isamteam repo 5. Install "L" in the isamteam repo 6. Turn off your device 7. Remove your r sim 8. Insert sim card without rsim 9. Pop up window will appear to show the iphone is need to be activated 10. Insert your sim card with rsim 11. Restart 12. Install ir0se tool from rsim5/nano4g/ 13. Open ir0se tool and click force 3G 14. Tadaaah, work like charm. P.S. Im using rsim 9 pro and it worked well ( call, messaging, imess, facetime, 3G data ) |
01-22-2014, 21:25 | #10 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Moldova Age: 39
Member: 1767456 Status: Offline Sonork: 1621131 Thanks Meter: 62 | Well actual is not Hardware problem is a R-sim Firmware Problem !!! Hardware - he mean that 128k/256k sim card use different chip than 32/64k sim cards ... So atm only 32/64k sim are compatible with R-sim and other unlock products ... For me for example only for iPhone 4S - work - 32/64/128/256k SIM on 80% of locked iPhones For iPhone 5/5c/5s - we still waiting Firmware FIX ... |
01-22-2014, 22:02 | #11 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | 3G works on 25% of 64K SIMs in the USA for iPhone 5. I tried many different SIM cards here, and only 2 out of 8 regular SIMs cut to nano size got 3G/4G signal(no LTE of course). The method above is only necessary for Sprint iPhone 5. You do not need it for AT&T or other GSM iPhone 5/5C/5S. Only iRose patch is necessary for those unless you have 64K SIM card that supports 3G with R-SIM. |
01-23-2014, 06:57 | #15 (permalink) | |
Member: 2110498 Status: Offline Thanks Meter: 0 | Quote:
Or you can use force 2G button in irose tools. | |
