Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 03-06-2015, 01:03   #1 (permalink)
Member: 2017675
Sonork: denden0608
Problem rsim 9pro on iphone 5s ios7
I have an iphone 5s locked to globe philippines. Im trying to use a digicel sim card here in Papua new Guinea it always got stuck on activation required part that always says invalid sim. What to do please help...
Old 03-06-2015, 03:45   #2 (permalink)
Member: 1069428
just try another rsim 9pro or another sim...,
The Following User Says Thank You to lailang For This Useful Post:
Old 03-06-2015, 13:59   #3 (permalink)
masterRt1994's Avatar
Member: 2105681
Sonork: Stoped Using...
Thanks Meter: 909
R-SIM 9 PRO ONLY SUPPORT 5C And 5S ON IOS 7.0.4 OR BELOW IF UR VERSION IS HIGH THEN USE R-SIM AIR 2 IF UR VERSION IS 7.0.4 OR BELOW THEN TRY WITH OTHER CARD.
The Following User Says Thank You to masterRt1994 For This Useful Post:
Old 03-07-2015, 02:23   #4 (permalink)
Member: 2017675
Sonork: denden0608
I see that's why because i have version 7.1.1, then i guess i have to use the rsim air 2..thanks
Old 03-07-2015, 02:39   #5 (permalink)
Member: 2017675
Sonork: denden0608
By the way, if i upgrade the version of my 5s to version 8, will the rsim9 pro work?
Old 03-07-2015, 19:20   #6 (permalink)
Member: 2105681
Thanks Meter: 909
sorry r-sim9pro not support 5s on ios8 u need to use R-SIM AIR 2
Old 03-11-2015, 14:49   #7 (permalink)
Member: 2328086
9pro support 5c/5s until 8.2 but carrier imsi without GID. Work good on KDDI Japan 4405001/4405401 on 5s 7.1.2-8.2
Old 05-04-2015, 02:33   #8 (permalink)
Member: 2388682
I was going to create a new thread about the problem that I am having but I found this thread..
Here it goes..
I have an iPhone 5s iOS7 that is originally from T-Mobile.. I bought this device from someone who told me that it worked for him using the Air2 sim but he no longer had it.. so I got this Air2 mini from a friend and when I insert the simcard into the phone it gives the menu to select the carrier.. HOWEVER, it only gives me about 6 seconds before the white screen with the apple logo shows up and locks my phone.. when I unlock the device I get this menu that says ACTIVATION required and then I get the SIM NOT VALID message.
When I insert the simcard without the Air2 I am able to see the dots as for the signal but again I get the activation required message. ALSO, sometimes it says- phone activated with cdma network. for roaming enter a simcard.
What can i do in this case beside factory unlocking the device.
Id really appreciate your help.
Page generated in 0.22849 seconds with 8 queries
