Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 03-01-2015, 09:58   #1 (permalink)
Member: 2354958
R-sim 10 iphone 5 Sim not valid
Hi,
I plugged my r-sim 10 in my softbank iphone 5 with a b-mobile sim card. The r-sim menu opened, i choose softbank than i5 then for 4G sim card, M2(m1 same).
-> i restarted my iphone and i have to activate my sim and get SIM not valid.
thanks
Old 03-01-2015, 13:30   #2 (permalink)
Member: 2332510
Thanks Meter: 5
Is your sim is 4g sim or 3g sim, if it is 3g sim, try to run r-sim 10 in io 6.x.- ios 8.x mode.
Old 03-01-2015, 13:51   #3 (permalink)
Member: 2354958
I tried same problem.
Old 03-26-2015, 04:09   #4 (permalink)
Member: 2368853
You need to first use the Rsim with your real/current SIM which your phone is locked to.
If the automatic carrier selection doesn't pop up then go to settings and then to Phone and then to Sim Application
run the Sim application and choose the carrier that the PHONE is locked to (confused me the first few times)
then turn off when it says to restart.
pop out your old sim and put the new one in (again with the Rsim attached).
The Rsim will imitate whatever carrier you had set it to and you won't be asked for activation.
Sometimes it takes a few tries to get it to work
Old 01-19-2017, 09:03   #5 (permalink)
Member: 2674460
Post Iphone 5s rsim10+
Could someone help me setup rsim 10+ phone locked to us at&t trying to access another network all i get is no service
Old 02-12-2017, 16:56   #6 (permalink)
Member: 568
Sonork: 100.1646534
Thanks Meter: 5
Here is video with easy step-by step tutorial manual to get back you lost pop-up menu to setup R-SIM correctly.
Here is direct link to video tutorial manual -
Here is direct link to play list with many video tutorials for R-SIM setup...
Direct link to YouTube channel is APPLOGGER.CF
Page generated in 1.63547 seconds with 8 queries
