05-13-2014, 16:27 | #32 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2175513 Status: Offline Thanks Meter: 1 | Mine two but yesterday i put the sprint sim whit the rsim and turned celullar data on and off and sim apoications menu apear but when i tried mi sim it does not apear even if i do the same turning on the cellular data maybe our sims are no working good or we need a diferrent sim ill try a diferente sim and ill give feedback |
The Following User Says Thank You to rwsker For This Useful Post: |
05-14-2014, 18:01 | #35 (permalink) |
Freak Poster Join Date: May 2014 Location: INDIA
Member: 2184652 Status: Offline Thanks Meter: 103 | steps by indian reseller The steps are easy.. 1 turn off cellular data and 3g and everything in cellular.. 2 insert sim and rsim and select carrier and accept message then restart.. 3 quickly go to settings when phone turns on and make sure that cellular is turned off.. 4 if you have sprint then you dont need rpatch but if you have any other carrier you need a rpatch installed. But the twist here is that only activation code in rpatch must be inserted and the toggle to enable the patch must be turned off (This must have been the first step) 5 now your phone must return you with a activation required screen . This is normal. 6 Quickly restart and when your phone boots up quickly go to irose and click on force 3g ( clicking on force 3g can also be done before inserting the rsim in step one) 7 Now you must have signals . 8 Now go to cellular data and turn on everything ( required for incoming calls and sms) 9 If this doesn't work for you then you can try all this in force 2g mode If found with rsim air 2 sprint is almost giving 99% stable signals but with other carriers its giving like only 60% |
05-14-2014, 22:36 | #36 (permalink) |
Temporary banned !! Join Date: Feb 2014
Member: 2127068 Status: Offline Thanks Meter: 51 | It looks like my R-Sim Air 2 came broken, i spoke with the seller and he said that will ship a new one to me, also he said that the new one that is coming is an updated version (i know is a lie) but anyways i have to wait two more weeks to test it since is coming from china! |
05-16-2014, 03:35 | #39 (permalink) | |
Member: 2184652 Status: Offline Thanks Meter: 103 | Quote:
Same answers from all resellers. Sent from my iPhone using Tapatalk | |
05-24-2014, 03:00 | #44 (permalink) |
Member: 2127068 Status: Offline Thanks Meter: 51 | Guys get ready, monday afternoon will be the release date for the 7.1.1 Jailbreak!! Let's pray for it!! |
The Following User Says Thank You to Darlingjose For This Useful Post: |
