Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 02-11-2014, 22:14   #1 (permalink)
Member: 2126389
Carrier network restarting after unlock lock screen
Hi,
I have iPhone 5 successfully unlocked with R-SIM 9 Pro.
To use 3g I need to enable Data Roaming.
But I have some strange problem, I think it is not normal r-sim behavior.
1. Data roaming auto turning off after few minutes/seconds. Usually when the phone is in stand by.
2. When I unlock via slide to unlock, the carrier network is restarting. I cannot call in first 20-30 seconds, and if someone call me he will receive voice that I am currently offline.
Is there solution for these two problems?
Old 02-12-2014, 04:25   #2 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
Check your iphone for a liquid damage if not then store your ios and check to see if you got the same problem if still exists then point your finger at the rsim which it could be defective.
Old 02-12-2014, 11:53   #3 (permalink)
Member: 2126389
I checked there is no water damage.
You mean to restore factory settings via itunes? I am not sure I will be able to activate the phone after that, because don't have original carrier sim card.
Old 02-12-2014, 16:26   #4 (permalink)
Member: 1938435
Thanks Meter: 208
R-SIM will activate the phone. What patch did you install after jailbreaking?
Old 02-12-2014, 18:16   #5 (permalink)
Member: 2126389
I install iRoseTool only.
Should I install something other?
Old 02-13-2014, 00:25   #6 (permalink)
Member: 1449117
Thanks Meter: 35
Hey I feel like there is an issue with iRoseTool Lately, I have also had this issue. Just use Neterteam patch and activate properly first making sure iPhone is activated. Then use iRosetool after if you need to force it into 3G
Old 02-15-2014, 18:58   #7 (permalink)
Member: 2126389
After itunes restore, the phone started working normally.
It is working even without iRoseTool and Neterteam.
Maybe it it was broken, because I was edited CarrierBundle files.
Thanks to all.
Old 02-15-2014, 19:36   #8 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
Thanks to all.
That is true you have modify the ios of your iphone by going to the ifile and because of this I always advice you guys do not do the way through the ifile if you are not familiar with what it since you could Easley delete or modify a vital file on your ios.
Page generated in 0.14929 seconds with 8 queries
