02-07-2014, 23:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1889273 Status: Offline Thanks Meter: 12 | rsim ,sim, or iphone problem ?? Someone knows what happens? I tried it in another iphone 5 tmobile and i can make calls with claro operator using the same chip my iphone tmobile apper no service with claro |
02-08-2014, 20:40 | #3 (permalink) |
Freak Poster Join Date: Jan 2003
Member: 20520 Status: Offline Thanks Meter: 0 | Try deleting with ifile t-Mobile bundle in library/carrier bundles and copy carrierlab one time in same folder and rename copy to name of deleted carrier. If dont work download with cydia cdma patch from cydia.neterteam.com . Search irosetool in Google and install |
02-14-2014, 17:42 | #6 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | The usa carriers have signed an agreement to share the information for blocked imei but that is only for the usa and not for overseas so really it don't make any sense to me, the new carrier you are trying to use is it a cdma or a gsm carrier also sometimes it's the sim card you are using it could has some codes on it that will not work as we have the issue with sisi tmobile sim in the usa. |
02-15-2014, 17:40 | #7 (permalink) |
Member: 1889273 Status: Offline Thanks Meter: 12 | i tried this sim card in another iphone 5 tmobile and works good but in my iphone 5 tmobile appear no service this is GSM sim card (claro carrrier ) only movistar carrier work in my iphone 5 tmobile and is blaclisted in USA , what i need to do with sim code?? |
02-15-2014, 19:49 | #8 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | Sorry my friend but I heard from a customer who was traveling overseas the same scenario as you, so it sounds to me that for some reason some carriers will not work overseas as well which I don't have the answer for this, the only thing I can suggest is try a different version or even different card of that carrier who knows maybe you are running through the same issue as the sisi sim card from tmobile. |
02-16-2014, 14:49 | #10 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | That one on the right the claro one is no good since I can tell from the gold chip being clipped partially. I have faced this issue several times when I was cutting a few sim cards from T-Mobile the old big style and whenever I cut them down they never worked for me since the gold chip on the back side is much bigger size than the one it was designed for the micro or the Nano although some of the general size they come with the small size chip but I can tell you almost positively that this chip is no good so I suggest maybe you grape a smaller size chip from this carrier and try it out. Good luck. |
