Avengers Box (Multi Unlocker Box) |
01-31-2019, 15:13 | #31 (permalink) |
Insane Poster Join Date: Apr 2016
Member: 2566222 Status: Offline Thanks Meter: 12 | Alcatel 5041c software showing unlocked but phone still locked here is the log Exe version: Avengers Box MTK 0.5.9 Selected model: Alcatel OT-5041C Action: Unlock Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [42]Detected: MediaTek USB Port_V1632 (COM42) \\?\usb#vid_0e8d&pid_0003#5&3191b6ef&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [19]META Port Detected: MediaTek USB VCOM (Android) (COM19) USB\VID_0E8D&PID_200E&MI_01\6&9AA30B1&0&0001 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6739,S01 [AP]APP_VER: alps-mp-o1.mp1-V1.112_k39tv1.bsp_TMP4 Making target channel configuration, wait... Making tunnel configuration, wait... Rebooting to meta, wait.... [META]BaseBand CPU : MT6739 [META]SW_VER : MOLY.LR12A.R3.MP.V10.3.P9 [META]HW_VER : TK_MD_L4_HW Phone imei[1] : Start direct unlock[SIM1] Simlock checksum is ok. frame_magic: caacd8 frame_len: 24f code_size: 253 Direct unlock done All done. Help needed from team |
01-31-2019, 15:32 | #32 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am really not understand, why is so hard to follow exe hints and read update thread. Will try my luck again here and will use little bigger font, hope this will help. TO UNLOCK THIS PHONE NEED TO USE DATABASE. DATABASE NEED TO DOWNLOAD FROM SUPPORT. Hope this will help you to solve your problem. |
The Following User Says Thank You to orbita For This Useful Post: |
01-31-2019, 15:37 | #33 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
For this cases we added for our users flash mode acces in exe. Is easy to use, just need to select flash mode this time and try again. | |
01-31-2019, 15:56 | #34 (permalink) | |
Member: 2566222 Status: Offline Thanks Meter: 12 | Im unable to find database please provide link Quote:
Im unable to find database please provide link its urgent please help me | |
01-31-2019, 16:05 | #35 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | To find database, you must acces support(setting tab in exe, acces support) We maked acces support very easy, need only to press 1 button in exe. Please explain where is your problem, really can't understand. |
01-31-2019, 16:15 | #36 (permalink) |
Member: 2566222 Status: Offline Thanks Meter: 12 | Problem solve by selecting database file Problem solve by selecting database file Exe version: Avengers Box MTK 0.5.9 Selected model: Alcatel OT-5041C Action: Unlock Will be used database connection. Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [42]Detected: MediaTek USB Port_V1632 (COM42) \\?\usb#vid_0e8d&pid_0003#5&3191b6ef&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [19]META Port Detected: MediaTek USB VCOM (Android) (COM19) USB\VID_0E8D&PID_200E&MI_01\6&9AA30B1&0&0001 ChipID: MT6739,S01 Using Algo 5. Starting META using port[COM19], wait... BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R3.MP.V10.3.P9 MODEM HW Version : TK_MD_L4_HW IMEI location: OTP IMEI[1] : IMEI[2] : 000000000000000 [1]Reading simlock info: Block1(N): Locked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [1]Unlocking target, wait Direct Unlock Done. [2]Reading simlock info: Block1(N): Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [2]Unlocking target, wait Direct Unlock Done. All done. Thanks for your support But sorry for irritating you |
01-31-2019, 17:33 | #37 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | It's not about irritating here. Simple need to be little more carefull and read info when you do some. This will help you to solve more easy and fast problem. |
01-31-2019, 17:59 | #38 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 61
Member: 206710 Status: Offline Thanks Meter: 13 | Thank you for the answer but the same what I need is to read bootloader code... :-( Regards kiricu Exe version: Avengers Box MTK 0.5.9 Selected model: 0-By CPU MT6737T Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM4) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... First stage DA fail, aborting BBCHIP MT6737T [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware Boot Fail.!!!. All done. |
01-31-2019, 18:38 | #39 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Try to search this forum about mtk secure boot information. Also, try to follow exe hint and select phone by model. This is update thread, not user learning thread. Please create your own thread in such cases, not need to spam update thread with offtopic mesages. I'am understand, your problem is very important for you, but let's provide some respect to others, ok? |
02-02-2019, 06:50 | #40 (permalink) |
Insane Poster Join Date: Mar 2016 Age: 31
Member: 2544984 Status: Offline Sonork: Salatiel net Thanks Meter: 11 | Please ADD support for new Vodafone Smart E9 direct unlock, read firmware, Frp. MT6739WA are secure boot and ask authentication file. I trust Nck team can solve it. |
02-05-2019, 10:11 | #41 (permalink) |
Major Poster Join Date: Feb 2014 Location: kerala
Member: 2135872 Status: Offline Thanks Meter: 9 | pls replay me team oppo a83 user lock unlock fail Action : Format UserData. Selected OPPO:A83 Exe version: Avengers Box MTK 0.5.7 Reinsert phone battery. Battery must be charged. Keep VOL- button untill inserting USB cable. Detected : MediaTek PreLoader USB VCOM (Android) (COM41) Phone detected...Please wait BBCHIP: 6763 1 ca01 Using Algo 3. Helio MT6763 phone detected, swithing to helio api Loading Custom Preloader Helio connect da error, aborting. BBCHIP MT6763 [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware Boot Fail.!!!. All done. |
03-25-2019, 13:00 | #44 (permalink) | |
Junior Member Join Date: Mar 2015
Member: 2370488 Status: Offline Thanks Meter: 0 | Quote:
