Avengers Box (Multi Unlocker Box) |
07-16-2021, 17:17 | #1 (permalink) |
Crazy Poster Join Date: Mar 2018 Location: Mozambique
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | Avgns Mtk problema frp pop4 pro Selected model: Tecno POP 4 Pro [auto]Action: Reset FRP Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(10) : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10) [10] \\?\usb#vid_0e8d&pid_2000#6&61482&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 3K=x)]U3:^sZ<--n,Ǖob0bX*KK#<y鞷AXA]ꙋoUu8ZtJÜ:̝֩*JyCqvUөU vPt8 $#^~FɲN _i31GpMj6_מ=2zOJvA? E^.fc^y aH` YN鯧<%`^ky趻ƪslp<J}_9n IG, oo\Lħ{PID_0003 |
The Following User Says Thank You to joaquimpanete For This Useful Post: |
07-16-2021, 18:42 | #2 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. | |
The Following User Says Thank You to orbita For This Useful Post: |
07-19-2021, 10:02 | #6 (permalink) |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | help boss please even so it's not accepting to run it just shows these letters like a virus I don't think it's a problem this techno pop4 pro cpu Action : Boot Info. Selected Tecno:POP 4 Pro Exe version: Avengers Box MTK 0.7.8 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(10) : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10) [10] \\?\usb#vid_0e8d&pid_2000#6&61482&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 3K=x)]U3:^sZ<--n,Ǖob0bX*KK#<y鞷AXA]ꙋoUu8ZtJÜ:̝֩*JyCqvUөU vPt8 $#^~FɲN _i31GpMj6_מ=2zOJvA? E^.fc^y aH` YN鯧<%`^ky趻ƪslp<J}_9n IG, oo\Lħ{PID_0003 |
07-19-2021, 10:42 | #7 (permalink) | |
If you select phone from list, not need to use "bypass security" But if you want to use it for some reason, you must connect phone in right mode(brom mode). MTK phone have 2 modes when it boot. \\?\usb#vid_0e8d&pid_2000 aka preloader mode. This mode is not posible to use on bypass security. Also exists \\?\usb#vid_0e8d&pid_0003 aka brom mode. This mode need to be used on bypass security. Phone will enter in this mode, if you will Code: For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. It's not phone problem, it's not exe problem. Just perform right connection and all will be ok. In your case we have wrong connection mode, and no matter how many times you will try. Untill you will not connect phone corectly, it will not work. Code: Detected(10) : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10) [10] \\?\usb#vid_0e8d&pid_2000#6&61482&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} | |
07-19-2021, 11:16 | #8 (permalink) |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | Mr. Orbita help boss please Mr. Orbita you are a good guy to answer my doubts Mr I have another question, what is the Bypass security no avgnsMtk option, please do not understand this ........... |
07-19-2021, 11:20 | #9 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | https://ibb.co/RHT5R1V see the pic i hope u understand |
The Following User Says Thank You to saqib2009 For This Useful Post: |
07-19-2021, 11:25 | #10 (permalink) | |
Usually secure boot phones will not allow to boot without "custom loader" In this case can be used "bypass security" and connect phone in brom mode. If phone is listed, inside exe have included already this "custom da" and not need to use this function. If you still want, you can use this function always, it will not do any harm. Just need to connect phone in right way. | |
07-19-2021, 11:27 | #11 (permalink) |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | I ask for a complete explanation as Mr. orbit explains in full and you just show me an image not as I explain his function...................... |
07-19-2021, 11:52 | #12 (permalink) |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | mr. Orbita solution MR. orbita https://i.postimg.cc/8cTY8Lvt/GSMUNHAVA-SOLUTION.png I have a cell from Mobicel Astro does not accept to remove account with avgn spd nor in Fasboot Mode also does not run, and this one, option of fasboot never accept to reset frp cell spd .... |
07-19-2021, 12:26 | #13 (permalink) | |
If bootloader is locked, you can't use fastboot. Need to use flash mode, if phone will not accept default loader, need to make custom loader using phone firmware. After you can reset frp. | |
07-19-2021, 12:36 | #15 (permalink) |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | I received a message on gsmfurum that said it will be removed by people from publishing spam I don't understand what and it helps............................................. .................................................. .................................................. ... |
