Avengers Box (Multi Unlocker Box) |
01-04-2023, 18:25 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Honor X6 (VNE-LX2) frp issue u support frp remove many user did it via ISP they tried test point not worked MediaTek MT6762G Helio G25 (12 nm) i need method without dissemble phone Reading device Info ... Device Model : VNE-LX2 Device Firmware : VNE-L42CM 6.1.0.154(C185E1R2P1) Country : MIDDLE EAST and AFRICA Key Version : cmd is invalid Current Status : SAFE |
The Following User Says Thank You to profkefah For This Useful Post: |
01-04-2023, 19:02 | #2 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Action : Boot Info. Selected 0-By CPU:AUTO Exe version: Avengers Box MTK 0.8.1 Keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(25) : MediaTek PreLoader USB VCOM (Android) (COM25) [25] \\?\usb#vid_0e8d&pid_2000#5&3985650a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6765 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. Action : Meta Info. Selected Model: 0-By CPU:AUTO Exe version: Avengers Box MTK 0.8.1 Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(25) : MediaTek PreLoader USB VCOM (Android) (COM25) [25] \\?\usb#vid_0e8d&pid_2000#5&3985650a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... [1]Error: ?? [helio]Wait untill phone will start charging. [0]All done. Reading phone info. Model: VNE-LX2 Build number: VNE-L42CM 6.1.0.154(C185E1R2P1) Bootloader: INFO locked Action : Boot Info. Selected 0-By CPU:MT6575 Exe version: Avengers Box MTK 0.8.1 Keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(25) : MediaTek PreLoader USB VCOM (Android) (COM25) [25] \\?\usb#vid_0e8d&pid_2000#5&3985650a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... Helio connect da error, aborting. Error[0xc0030003]: STATUS_DA_SELECTION_ERR BBCHIP MT6765 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. |
01-05-2023, 08:06 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Lets explain for each log. First log: You not selected "bypass security" In case of secure phone you must select "bypass security" or use signed by huawei da, in your case. Second log: Most modern huawei phones have disabled or need authentification for meta mode. On mostly new huawei meta mode will not work. Last log: Your phone have MT6765 cpu and you selected MT6575 cpu. MT6575 cpu is very old(about 15 years old) and it's not compatible with your phone. This is why exe give cpu selection error. This phone must be supported, just try with "bypass security" Last edited by orbita; 01-05-2023 at 08:32. |
The Following 3 Users Say Thank You to orbita For This Useful Post: |
