Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > Avengers Box
Avengers Box (Multi Unlocker Box)
Old 11-22-2020, 15:23   #1 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
Itell A33 no signal after privacy lock remove
Phone Storage: EMMC
EXE: Avengers Spreadtrum Module 1.3
SELECTED: A33(W5001)
ACTION: Restore factory nvram
Start Detect phone...
Phone must be off with battery inside.
Long press "VOL -" key while inserting usb cable.
For some phones need to
Long press "VOL -"+ "VOL +" key while inserting usb cable.
Keep key untill boot complete.
Detected: SPRD U2S Diag (COM35)
Sending loader, keep boot key untill loader start.
Loader OK: Spreadtrum Boot Block version 1.1
Changing bautrate OK.
Send Second Loader.
New flash metod detected.
Manufacturer: itel
Hardware: sc7731e_1h10_v1.1.0
Hardware version: SC7731e_2_IRD_K_V1.1.0
Build product name: F3102
Build description: W5001P-user 8.1.0 OPM2.171019.012 412 release-keys
Product name: F3102
Transsion device name: itel A33
Build Id: OPM2.171019.012
Model: itel W5001P
Android Release: 8.1.0
Android Version: W5001P-F3102-8.1-OP-V068-20201013
Security patch: 2020-10-05
This phone have frp partition.
MatchesMask [w_fixnv1] [w_fixnv1] Size to download: 1024 KB
Reading w_fixnv1
IMEI 1: 358481109093740
IMEI 2: 358481109093757
Simlock Type: 4
Protecting IMEI_1 id: 0x5 len: 0x8
Protecting IMEI_2 id: 0x179 len: 0x8
Protecting BlueTooth id: 0x191 len: 0x8
Protecting BandSelect id: 0xD len: 0x1
Protecting WIFI id: 0x199 len: 0x14
Protecting SIMLOCK_SIGN id: 0x1A3 len: 0x280
Protecting SIMLOCK_PK id: 0x1A4 len: 0x228
Protecting SIMLOCK_CUSTOMIZE_DATA id: 0x1F0 len: 0xF5C
Protecting SIMLOCK_USER_DATA id: 0x1F1 len: 0x4D4
Protecting SIMLOCK_NVCONTROL_KEY id: 0x1F2 len: 0x1A0
Protecting SIMLOCK_KEY id: 0x1F4 len: 0xA0
Protecting SIMLOCK_CFG id: 0x7E4 len: 0x2B
Restoring done
Restoring done
Wait untill phone restart.
Log saved:
C:\Users\Talat Hussain Dar\Documents\spreadtrum_module\Saved_Logs\_358481 109093740_358481109093757_RestoreNvramFactoryPriva cy.txt
Total Time: 00:00:17
Done.
Old 11-22-2020, 15:37   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Usually this have nothing to do with signal, posible exists other problems.
Perform wipe after privacy reset.
If this not help, simple restore nv backup as exe warn you when you push privacy button.
The Following User Says Thank You to orbita For This Useful Post:
Old 11-22-2020, 16:17   #3 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
Thanks for fast answer
problem was that model was w5001P and i select w5001,
now i find "Repair Factory NVRM" opiton under w5001p model and it works and phone is working fine....
Thanks
The Following User Says Thank You to darmobiles For This Useful Post:
Old 11-22-2020, 16:23   #4 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
This is important, models contain inside some specific setting what is not compatible between.
You not specify wrong model selection in your post, so was imposible to guess it.
The Following 3 Users Say Thank You to orbita For This Useful Post:
Page generated in 0.12277 seconds with 8 queries
