Avengers Box (Multi Unlocker Box) |
04-23-2022, 10:57 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | OPPO CPH2119 FRP not remove :( Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(28) : MediaTek USB Port_V1632 (COM28) [28] \\?\usb#vid_0e8d&pid_0003#6&332e6dd3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6779 CPU code: 725 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [50c00]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_oppo6779.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(28) : MediaTek USB Port_V1632 (COM28) [28] \\?\usb#vid_0e8d&pid_0003#6&332e6dd3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6779 0 ca00 Using Algo 1. Helio MT6779 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6779 [48]Storage UFS Block size: 4096 UFS CID: 4B4D3856373030314A4D2D423831300000000000 UFS FW VERSION: 31:32:30:30:00:00:00:00 lu0_size: 0x400000 [0.004 GB] lu1_size: 0x400000 [0.004 GB] lu2_size: 0x1dcb000000 [119.172 GB] FULL LENGTH: 0x1dcb800000 [119.180 GB] Build ID: RP1A.200720.011 Display ID: RP1A.200720.011 release-keys Version: 11 Version: 11 Build Date: Thu Nov 11 22:38:30 CST 2021 This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR13.R1.TC16.Q.SP.V50.P13 [helio]Wait untill phone will start charging. [0]All done. Code: [MISC]Action: Reset To Factory. Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(28) : MediaTek USB Port_V1632 (COM28) [28] \\?\usb#vid_0e8d&pid_0003#6&332e6dd3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6779 CPU code: 725 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [50c00]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_oppo6779.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(28) : MediaTek USB Port_V1632 (COM28) [28] \\?\usb#vid_0e8d&pid_0003#6&332e6dd3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6779 0 ca00 Using Algo 1. Helio MT6779 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6779 [48]Storage UFS Block size: 4096 UFS CID: 4B4D3856373030314A4D2D423831300000000000 UFS FW VERSION: 31:32:30:30:00:00:00:00 lu0_size: 0x400000 [0.004 GB] lu1_size: 0x400000 [0.004 GB] lu2_size: 0x1dcb000000 [119.172 GB] FULL LENGTH: 0x1dcb800000 [119.180 GB] Resetting userdata. Error: STATUS_UNKNOWN_STORAGE_SECTION_TYPE [helio]Wait untill phone will start charging. [0]All done. Code: Exe version: Avengers Box MTK 0.7.9 Selected model: 0-By CPU ELBRUS [auto]Action: Reset FRP Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(28) : MediaTek USB Port_V1632 (COM28) [28] \\?\usb#vid_0e8d&pid_0003#6&332e6dd3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6779 CPU code: 725 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [50c00]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_oppo6779.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(28) : MediaTek USB Port_V1632 (COM28) [28] \\?\usb#vid_0e8d&pid_0003#6&332e6dd3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6779 0 ca00 Using Algo 1. Helio MT6779 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6779 [48]Storage UFS Block size: 4096 UFS CID: 4B4D3856373030314A4D2D423831300000000000 UFS FW VERSION: 31:32:30:30:00:00:00:00 lu0_size: 0x400000 [0.004 GB] lu1_size: 0x400000 [0.004 GB] lu2_size: 0x1dcb000000 [119.172 GB] FULL LENGTH: 0x1dcb800000 [119.180 GB] Resetting userdata. Error: STATUS_UNKNOWN_STORAGE_SECTION_TYPE Phone have OTP partition. Modem version: MOLY.LR13.R1.TC16.Q.SP.V50.P13 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
04-23-2022, 12:51 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Try to select this loader from \DA_path directory. Code: \DA_path\MTK_AllInOne_DA.bin |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
04-23-2022, 17:42 | #3 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello , Phone returned to owner Please check this issue and fix in next update Thanks... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
