Avengers Box (Multi Unlocker Box) |
02-18-2023, 21:43 | #1 (permalink) |
Freak Poster Join Date: Sep 2017 Location: anywhere
Member: 2754769 Status: Offline Thanks Meter: 276 | zte A5 2020 flash failed here is log Code: ACTION: Flash Firmware. Selected firmware: firmware_info.xml NV: Default Mode (protect calibration) Device Storage: EMMC Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key and insert usb cable. For some phones need to Long press "VOL -"+ "VOL +" key and insert usb cable. Detected: SPRD U2S Diag (COM22) [00:00:00] Sending loader. BOOT: SPRD3 Sending loader, keep boot key untill loader start. [00:00:03] Loader ok [00:00:03] Wait for loader.... Loader OK: ~"Spreadtrum Boot Block version 1.1 Changing bautrate OK. [00:00:04] [0]First boot done. [00:00:04] Sending second loader. [00:00:09] Second loader sent ok. New flash protocol detected. [00:00:09] Reading: system Error while read flash(1). [00:00:29] Reading: super System name: super Phone and firmware have same android [00:00:29] Reading: miscdata [00:00:29] Reading: l_fixnv1_a NVRAM saved to: C:\Users\Eth-Hab\Documents\spreadtrum_module\flashmode_nvram_backup\_867781047707739_10\_867781047707739_nvram_backup.tar Phone have super partition. NV_COMM disabled by user, skip [00:00:41] Format: uboot [1][A2][8] Error send frame. [00:00:41][FORMAT: uboot]Wrong responce. [uboot]Error Format: uboot ,aborting. Error while writing firmware, aborting. Exe version: Avengers Spreadtrum Module 2.1.8 Log saved: C:\Users\Eth-Hab\Documents\spreadtrum_module\Saved_Logs\_writepac__11.txt Total Time: 00:00:47 Done. |
02-18-2023, 21:58 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Post here please reading firmware log, need to check some. A5 2020 not have enabled read firmware in exe. Also will be very usefull if you will upload uboot file readed from this phone. Last edited by orbita; 02-18-2023 at 22:57. |
02-19-2023, 16:10 | #3 (permalink) | |
Member: 2754769 Status: Offline Thanks Meter: 276 | Quote:
Code: Spreadtrum 9863a_1h10_32b Board First 16 bytes from public rsa key. B731DBB6D7D84B3555F4EB1D2227F0DB *************** Phone Storage: EMMC SELECTED: A5 2020 ACTION: Backup Firmware Loader format:NEW Start Detect phone. Phone must be off with battery inside. Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM23) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. UID: TC6B22_16_8_28 *************** [S]Manufacturer: ZTE [S]Brand: ZTE [S]Device: P963F50_A [S]Model: ZTE Blade A5 2020 Build ID: RP1A.201005.001 CPU arhitecture: armeabi-v7a Build product name: s9863a1h10_go_32b Build description: s9863a1h10_go_32b_2g-user 11 RP1A.201005.001 20210302.155453 release-keys Product name: P963F50_A SW Version: GEN_GLB_P963F50_RV1.0.0B06 Board: s9863a1h10_go_32b Build Id: RP1A.201005.001 Android Release: 11 Android Version: GEN_GLB_A5_2020_RV1.0 Security patch: 2021-02-05 CPU NAME: SC9863A Backup phone nvram NV partition: l_fixnv1_a IMEI: 867781047795932 Config name: SC9863A_11_partitions.xml [B]Reading: prodnv [1]Reading: vbmeta_a [1]Reading: vbmeta_system_a [1]Reading: vbmeta_system_ext_a [1]Reading: vbmeta_vendor_a [1]Reading: vbmeta_product_a [19]Reading: l_modem_a [1]Reading: l_deltanv_a [14]Reading: l_ldsp_a [A]Reading: l_gdsp_a [1]Reading: pm_sys_a [1]Reading: gpsgl_a [1]Reading: gpsbd_a [A]Reading: wcnmodem_a [40]Reading: boot_a [8]Reading: dtbo_a [15F8]Reading: super [14]Reading: logo [6]Reading: fbootlogo [4A]Reading: socko_a [19]Reading: odmko_a [dhtb][6]Reading: trustos_a [dhtb][1]Reading: teecfg_a [dhtb][1]Reading: sml_a [2]Reading: persist [dhtb][1]Reading: uboot_a [dhtb][1]Reading: splloader | |
The Following User Says Thank You to ethhab For This Useful Post: |
02-19-2023, 16:30 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Thanks for sharing uboot. This phone have 3 version of firmwares what is not compatible between. Tomorow i'am will give you link to exe what will autodetect corectly firmware version of this phone model and will read firmware corectly. |
02-19-2023, 22:01 | #5 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Select from list zte 8010 and read firmware from A5 2020 working phone, it must read corectly firmware for this version of A5 2020. After try to flash your other phone using this readed firmware. Just hint, sprd phones can stuck on logo about 5 min after flash, if take more perform wipe from phone recovery or exe. Post here result, if it's success or not. |
The Following User Says Thank You to orbita For This Useful Post: |
