Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 06-14-2013, 12:55   #1 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
Karbonn A21 Dead. [Solution Need]
I GOT A KARBONN A21 IN DEAD MODE.
NO ANY FASTBOOT MODE, NO ANY RECOVERY MODE
NOT CHARGING, FULLY DEAD .
WHEN CONNECT IN USB THERE IS (ZEUS Flash Device) ONLY SHOWS
I TRY STOCK FLASHER AND FILE BUT NOT WORKING
PLEASE HELP ME TO SOLVE THIS ISSUE
THANKS
Old 07-09-2013, 15:59   #2 (permalink)
Member: 291418
THANKS
if you do not care about further damage (and cannot claim warranty) then you can try this... it is intended for karbonn a9+/cherry flare.. since both a9+ and a21 have same msm8225 chipset it might work.
qpst (qualcomm product support tool) can be used to fix bricked phones which is being detected as HS USB QDloader 9008..
Tools Needed:
  1. Dead Phone (When u connect to PC it should install Qualcomm HS-USB QD Loader 9008 Driver) Download Link
  2. QPST.2.7.399 Download link
  3. Flare Revival kit Download Link
  4. PC with 32 bit Windows (XP/Vista/7/8) (64bit casus problem in QPST installation)
Here is full tutorial Download link
Source: XDA
Old 09-16-2013, 11:50   #3 (permalink)
amit.alag's Avatar
Member: 373527
Thanks Meter: 68
but port is not show where connect?
Old 09-28-2013, 17:49   #4 (permalink)
Member: 2035883
operation failed
I followed the instructions as said but nothing happens I waited for 2 hrs for phone to detect the drivers but in vain.
DURING THE OPERATION PHONE WAS CONNECTED WITH USB CABLE AND NO PHONE BATTERY.
SYSTEM DETAILS WINDOWS XP SP3
my phone details
KARBONN A21
DETECTS AS QUAL COMM MMC
COM4
Old 11-16-2013, 15:58   #5 (permalink)
Member: 1971792
I AM GETTING THIS ERROR
IMAGE DOWNLOAD FAILED. COOKIE(IF PRESENT) NOT RECEIVED
I HAVE screen shot but i don`t know how to attach hear
plzzz sir help me it`s urgent plzzzz plzzzz
Old 11-16-2013, 16:24   #6 (permalink)
Member: 1971792
failed with this error
image download failed. cookie(if present) not received
i have screen shot but i can`t know how to post hear
plzz help me for fix this error plzzz plzzz
Old 11-28-2013, 10:09   #7 (permalink)
Member: 1181433
Thanks Meter: 6
sir i have karbonn a21
press power on
after karbonn logo
hang with blue display (crystals shows on display moves)
how to flash
pls reply soon
regards
Old 12-03-2013, 13:32   #8 (permalink)
Member: 1181433
Thanks Meter: 6
Tools Needed:
  5. installation)
Source: XDA
i follow tle instrution but when press download
shows
could not find file EMMcBLd.HEX on any search path
Old 12-03-2013, 14:34   #9 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,087
bro you need karbonn a21 bp firmware
press vol down + power
if mobile same as pic
insert usb
install driver
see in device manager
qualcom 9006 port
use emmc write tool with bp firmware
after write imei your mobile on
if not on press volup power,this time your mobile enter in fast boot mode( green )
then mobile flash with ap firmware
if mobile totally dead & device manager qualcomm 9008 com appear
then use qpst tool
and rename this two filename in qpst tool according to your phone bp firmware
bp firmware folder inside .hex and .mbn file name
open bp firmware folder
select .hex file rename option and copy name and paste in qpst phone program flasher name same as pic
mbn file name copy and past in qpst tool
boot image mbn file
load xml & patch file in a21 bp firmware same as pic
select bp firmware in path 2
press download
after this prosess
your mobile not on
your mobile enter in qpst download mode or fast boot mode and see in device manager
qualcom 9006 port appear(auto convert 9008 to 9006)
if enter qpst download mode
agan flash bp firmware with emmc download tool
then write ap in fast boot mode
Old 12-04-2013, 10:01   #10 (permalink)
Member: 1181433
Thanks Meter: 6
mobile same as pic
insert usb
install driver
qualcom 9006 port
how to use emmc write tool with bp firmware
link for bp firmware
and thanks a lot 4 reply
Old 12-04-2013, 12:47   #11 (permalink)
Member: 1792140
Thanks Meter: 6,087
mobile same as pic
insert usb
install driver
qualcom 9006 port
EASY SOLUTION
select bp firmware in emmc tool and run
Old 12-04-2013, 16:32   #12 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Originally Posted by umesh gaba View Post
EASY SOLUTION
where to download bp firmware
Old 12-06-2013, 13:56   #13 (permalink)
Member: 822223
Thanks Meter: 6
how flash dead karbonn a27 handset plz. help...........
Old 12-06-2013, 14:06   #14 (permalink)
Member: 822223
Thanks Meter: 6
kindly give bp firmware of karbonn a27 handset...............plz........
Old 12-07-2013, 21:57   #15 (permalink)
Member: 1050877
Thanks Meter: 115
insert usb
install driver
qualcom 9006 port
then use qpst tool
boot image mbn file
press download
after this prosess
your mobile not on
After pressing Download a error msg
Image Download Failed.Cookie(if present) not received
How to solve
Page generated in 0.21047 seconds with 9 queries
