06-13-2013, 08:57 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hyderabad INDIA
Member: 892484 Status: Offline Sonork: not using Thanks Meter: 916 | flashing is final solution here flash file link Welcome to the ./downloads/Karbonn/ folder of the support area for your service center |
07-26-2013, 16:42 | #7 (permalink) |
Product Supporter Join Date: Mar 2008 Location: India
Member: 718725 Status: Offline Sonork: 100.1604953 QQ 2339690693 Thanks Meter: 6,702 | hi If you have miracle box than flash with it Select og flash file and write You mobile will be okay Check here http://forum.gsmhosting.com/vbb/f715...e-box-1692308/ B.R., Prem_India |
The Following User Says Thank You to Prem_India For This Useful Post: |
07-27-2013, 06:23 | #9 (permalink) | |
Freak Poster Join Date: Nov 2011 Location: surat in gujrat
Member: 1684564 Status: Offline Thanks Meter: 25 | same error Quote:
i try gaba sir but same eror i one by one select file but sploder ubootloder and system file not done i also many tool use but same i use dregon but not result Last edited by bhadreshdesai; 07-27-2013 at 06:29. | |
08-15-2013, 04:57 | #12 (permalink) |
Freak Poster Join Date: Jun 2011 Location: kolkata Age: 39
Member: 1596162 Status: Offline Sonork: 100.1616391 Thanks Meter: 146 | karbonn a6 KARBONN A6 DONE ERROR .................. 1. OPEN YOUR MTK BOX III 1.98 AND CHECKBOX. 2. UNCHECK SCEN PINOUT,SELECT COM. 3. REMOVE YOUR MOBILE BATTERY THEN INSERT USB CABLE IN YOUR PC AND PRESS VOL + AND INSERT BATTERY THEN INSTALL DRIVER. 4. AGEIN PROSES NUMBER 3. 5. GO MTK BOX III AND SELECT YOUR COM PORT AND SELECT KARBONN A6 FLASH FILE THEN STARS 6. UNCHECK MTK BOX III (9) SYSTEM OPTION AND OK ,YOUR FLASHING WHEN DONE,THEN REMOVE USB CABLE. 7. OPEN UpgradeDownload TOOL AND SEME PROSESS (3) 8. UpgradeDownload LOAD FLASH FILE CLICK START DOWNLOAD,YOUR FLASHING 100% DONE |
The Following User Says Thank You to 4star For This Useful Post: |
09-24-2013, 07:28 | #13 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: india kerala,MALAPURAM EDAKKAR
Member: 1224654 Status: Offline Sonork: jaheer Thanks Meter: 61 | karbonn a6 download error Quote:
sir when i update file in this tool showing baudrate failed pls helpme sir.set condition was pattern lock.i format in volcano, set dead | |
