07-21-2021, 23:49 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: JAMAICA
Member: 293299 Status: Offline Thanks Meter: 266 | Blu Dash L4 LTE D0500UU FRP removal failed Selected model: 0-By CPU MT6737M [auto]Action: Reset FRP Will be used loader: MTK_AllInOne_DA.bin Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(209) : MediaTek USB Port (COM209) [209] \\?\usb#vid_0e8d&pid_0003#6&688a3b8&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6737 CPU code: 335 Target config: 1 Secure boot enabled: true Need serial link authorization: false Need download agent authorization: false Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(209) : MediaTek USB Port (COM209) [209] \\?\usb#vid_0e8d&pid_0003#6&688a3b8&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... [emmi]EMMC CID: 13014E51324A393551 Error Load Custom Preloader. BBCHIP MT6737M flash id: 13014E51324A393551 Boot Fail.!!!. [0]All done. |
07-22-2021, 13:52 | #3 (permalink) |
Member: 293299 Status: Offline Thanks Meter: 266 | Exe version: NCKDongle AndroidMTK 2.7.6 Selected model: 0-By CPU MT6737M [auto]Action: Reset FRP Will be used loader: MTK_AllInOne_DA.bin Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(209) : MediaTek USB Port (COM209) [209] \\?\usb#vid_0e8d&pid_0003#6&688a3b8&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... [emmi]EMMC CID: 13014E51324A393551 Error Load Custom Preloader. Error Load Custom EMMI. BBCHIP MT6737M flash id: 13014E51324A393551 Boot Fail.!!!. [0]All done. I am using da from firmware I got on needrom |
07-22-2021, 15:15 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Problem come from unsupported by exe flash id. Try to load in exe preloader or firmware(not need to flash , just load) and execute opperation again. It must work. Also will be good if you will provide debug log with security bypass opperation. Will need to check why exe give this error on security bypass. This will help to fix problem and add feature support for this phones. |
07-22-2021, 16:52 | #6 (permalink) |
Member: 293299 Status: Offline Thanks Meter: 266 | check this log Exe version: NCKDongle AndroidMTK 2.7.6 Selected model: 0-By CPU MT6737M [auto]Action: Reset FRP Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(209) : MediaTek USB Port (COM209) [209] \\?\usb#vid_0e8d&pid_0003#6&688a3b8&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6737 CPU code: 335 Target config: 1 Secure boot enabled: true Need serial link authorization: false Need download agent authorization: false Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... |
07-22-2021, 16:52 | #7 (permalink) |
07-23-2021, 11:35 | #8 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am asked for debug log not exe log, exe log you posted already before. Provide please debug log. To open backup location, you can press in exe button called "open backup location" In this way will be more easy to find needed files. |
07-24-2021, 06:44 | #10 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Hi. I'am not see in this log any info about preloader initialisation. Need to tick debug log checkbox, execute process, and after get debug log. If you will get debug log before executing process, will not be usefull. Contact me please by skype, will be more easy and fast to solve in this way. |
