02-26-2018, 12:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Khénifra
Member: 1252738 Status: Offline Sonork: 100.1627617 Thanks Meter: 28 | Doogee BL7000 FRP any help !!! i need any help or file to remove frp from Doogee BL700 NCKBox error in any operation read info or frp remove. Doogee BL7000 with MT6750T cpu. please any help. |
02-26-2018, 17:27 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | hi nagagega Most posible your problem is very important for you. But without any info and logs is really imposible to guess your problem. If you want help, try to follow our rules and post exe log and problem description. |
02-27-2018, 17:10 | #3 (permalink) | |
Major Poster Join Date: Jul 2015
Member: 2432275 Status: Offline Thanks Meter: 6 | Quote:
2. Install Notepad ++ on your computer 3. In the folder with the firmware, locate the scatter.txt file and open it through Notepad ++ 4. Locate the b section in the text file "frp" and then copy the value of the linear_start_addr and partition_size fields. Close the scatter.txt file 5. Run the program for flash SP Flash Tool and in the field "File with scattered data" you specify the file of the scatter.txt file 6. Switch to the Format tab in the SP Flash Tool and specify 7. Manual format flash Region EMMC_USER To the beginning Address [HEX] (values linear_start_addr) In the format Length [HEX] (values of partition_size) 8. Then click the Start button and connect the smartphone to the computer to erase the values of the FRP Well done | |
02-27-2018, 17:15 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | goger77, i'am really not understand. Why you confuse user and post fake solution? Counter increasing? User most posible have phone with signed loader and he must use custom signed loader. And he not have time or knowlege to read exe hint, what sugest him how to solve problem. All info from your post our exe do auto from very long time, posible from time when google introduced frp. Belive me, i'am know very well how work frp in mtk phones and not need to teach me about |
02-27-2018, 17:38 | #5 (permalink) | |
Once again, I did not want to offend you. | |
