how to solved this erreur ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (28Gb+8192Mb) HYNIX 0x2058494e5948 EMMC FW VERSION: 16:00:00:00:00:00:00:00 EMMC CID: 90014A2058494E5948 : 00000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : DA USB VCOM Port (COM8) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x6a800000 - LEN: 0x10000000 FORMAT EMMC FLASH : BEGIN: 0x7a800000 - LEN: 0x6b780000 [1003]Error: S_INVALID_BBCHIP_TYPE Wait untill phone will start charging. All done. |
If you 1000% sure about your firmware, open firmware scatter with some text editor and edit Project: MT6580 in scatter header. |
RELOADER version: MTK_BLOADER_INFO_v21 name: preloader_hct6580_weg_a_l.bin CPU: MT6752 CUSTOM NAME: CUST Flash style: EMMC Flash definitions in preloader: 9 [1]Type: MCP(eMMC+DDR2) CID: 1501004B3758564D42 [2]Type: MCP(eMMC+DDR2) CID: 90014A483847316505 [3]Type: MCP(eMMC+DDR2) CID: 90014A483847326404 [4]Type: MCP(eMMC+DDR2) CID: 90014A2058494E5948 [5]Type: MCP(eMMC+DDR2) CID: 90014A483447316404 [6]Type: MCP(eMMC+DDR2) CID: 90014A483447326111 [7]Type: MCP(eMMC+DDR2) CID: 90014A484147346404 [8]Type: MCP(eMMC+DDR2) CID: 1501004B3858564D42 [9]Type: MCP(eMMC+DDR2) CID: 1501004B385530304D load adress: 0x200d00 PRELOADER END Android Info Build ID: MMB29K Display ID: MMB29K.G950FXXU1APFO Version: 7.0 Build Date: Sat Mar 17 12:08:01 CST 2018 Model: SM-G950 Brand: samsung Device: hero2qltechn Manufacturer: samsung Region: US Mediatek Version Release: ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P55 Android Info END NVARAM IMEI[1] from NVRAM: 358654631659879 |
solved problem CM2 Code: Scatter Load Ok , BaseBand : MT6752 , Project : hct6580_weg_a_l , Storage : EMMC |
Is really so hard to modify 1 line in text editor? I'am even explaied how to make this. You know what is text editor, right? I'am not asked you about, was pretty sure you know what meen text editor in windows. :( This tool not check cpu when perform firmware write? :confused: In this case is very easy to get dead phone by incorect flashing. |
S_INVALID_BBCHIP_TYPE Done by Greate Nck Dongle :) Quote:
it's working for me, it's simple to edit, thanks a lot orbita |
