07-02-2018, 09:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | how to solved this erreur BaseBand CPU :MT6580 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (28Gb+8192Mb) HYNIX 0x2058494e5948 EMMC FW VERSION: 16:00:00:00:00:00:00:00 EMMC CID: 90014A2058494E5948 : 00000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : DA USB VCOM Port (COM8) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x6a800000 - LEN: 0x10000000 FORMAT EMMC FLASH : BEGIN: 0x7a800000 - LEN: 0x6b780000 [1003]Error: S_INVALID_BBCHIP_TYPE Wait untill phone will start charging. All done. |
07-02-2018, 10:28 | #3 (permalink) |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | RELOADER version: MTK_BLOADER_INFO_v21 name: preloader_hct6580_weg_a_l.bin CPU: MT6752 CUSTOM NAME: CUST Flash style: EMMC Flash definitions in preloader: 9 [1]Type: MCP(eMMC+DDR2) CID: 1501004B3758564D42 [2]Type: MCP(eMMC+DDR2) CID: 90014A483847316505 [3]Type: MCP(eMMC+DDR2) CID: 90014A483847326404 [4]Type: MCP(eMMC+DDR2) CID: 90014A2058494E5948 [5]Type: MCP(eMMC+DDR2) CID: 90014A483447316404 [6]Type: MCP(eMMC+DDR2) CID: 90014A483447326111 [7]Type: MCP(eMMC+DDR2) CID: 90014A484147346404 [8]Type: MCP(eMMC+DDR2) CID: 1501004B3858564D42 [9]Type: MCP(eMMC+DDR2) CID: 1501004B385530304D load adress: 0x200d00 PRELOADER END Android Info Build ID: MMB29K Display ID: MMB29K.G950FXXU1APFO Version: 7.0 Build Date: Sat Mar 17 12:08:01 CST 2018 Model: SM-G950 Brand: samsung Device: hero2qltechn Manufacturer: samsung Region: US Mediatek Version Release: ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P55 Android Info END NVARAM IMEI[1] from NVRAM: 358654631659879 |
07-02-2018, 13:34 | #5 (permalink) |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | solved problem CM2 Code: Scatter Load Ok , BaseBand : MT6752 , Project : hct6580_weg_a_l , Storage : EMMC Files found : 9 , Set to Flash : 8 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A193B9CF8053 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A193B9CF8053 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x05EC4395858ED8293FD58010D9AE5E6F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6752 , Project : hct6580_weg_a_l , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3998 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000000E4300000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hct6580_weg_a_l.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:07:37 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:18 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:08:14 Reconnect Power/Cable! |
07-02-2018, 14:21 | #6 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Is really so hard to modify 1 line in text editor? I'am even explaied how to make this. You know what is text editor, right? I'am not asked you about, was pretty sure you know what meen text editor in windows. This tool not check cpu when perform firmware write? In this case is very easy to get dead phone by incorect flashing. |
The Following User Says Thank You to orbita For This Useful Post: |
